I had another issue with the castle gate which I fixed but before that I had a sound issue. every once in a while, the sound like the voices and sound fx went really really quiet while the music was still at the same level. kinda sounded like when you first put the audio jack on like a chirp then quiet or chirp then loud.
- I tried bending down the audio jack connections on the sound bar to make sure they were tight.
- I went into and around the metal box and jiggled any and all wires surrounding the audio cables to try to reproduce the chirp without success.
it seems to come and go.
the lighting issue happened about a week after I fixed the gate issue.
but it also comes and goes. either 3/4 of the lights are off all together or all the lights are one and they flash RGB (White) on every led. the latter actually just happened today, I opened the table and tapped on the metal box containing the bulk of the hardware and was able to reproduce the RGB white light I described. Soon after I took the cover off everything turned back to normal.
- I once again tried wiggling any and all connections to try to isolate the loose connections or discovery a shorted lead or something.
- I looked over ever pcb, fuse etc. nothing burned, all fuses looked fine
- i put all the wires back inside and put the lid back on making sure all wires were not getting pinched.
one time when I moved the table back into position the 3/4 light went out but I moved it a little more and they were back on. but like I said I tugged on almost every wire and failed to get it to reproduce the issue.
and everything is working... at least for now.
it's a little difficult to troubleshoot things that aren't broken broken.
I had 2 golden tees that kept freezing at least once every other day or daily. took 4 weeks to figure that one out. if I can get help to zero in on what might be affecting my woz I would greatly appreciate it.
thank you
