Just got this WOZ today. Worked out an issue with the 20v due to a blown fuse. All of a sudden most of the lights went out a couple hours later Any suggestions?
20191231_185208 (resized).jpgLooks like a LED board right after W6 failed. Maybe #29.
This will help you.
Please check out page C-54 in the manual ( you can download it at jerseyjackpinball.com ) that page shows the data harness path. From W6 to #29, to #1, to #2, to #3, etc. etc.
Please go into Tests - LEDs - All LEDs, this turns any working all white. Lift playfield and lean on backbox. You can see the working ones kind of glow.
They are wired in series, a straight line. Find the last working one, the one after it that is out is the bad one. With the power on, you can by pass the data harnesses on the LED boards, bypass the bad one, and turn off in settings. ( be sure and turn it back on when you replace it ) this will help you identify a bad one.
As an example, say #15 was out. You can run the data harness from red on W2, to green on #16 instead of #15. If the rest light up, you know #15 is the bad one.
With the power on you can move data harnesses. They go red to green from board to board. Don't mess with the power connectors with the power on.
Quoted from LTG:Looks like a LED board right after W6 failed. Maybe #29.
This will help you.
Thanks a ton, bypassed the first board and its working again. Lot of happy folks here that wanted to try it.
Quoted from PokerJake:Thanks a ton, bypassed the first board and its working again. Lot of happy folks here that wanted to try it.
You can order new ones from jerseyjackpinball.com - Store - Parts - Wizard Of Oz.
This page was printed from https://pinside.com/pinball/forum/topic/woz-lighting and we tried optimising it for printing. Some page elements may have been deliberately hidden.
