(Topic ID: 152038)
WOZ light boards: did all ECLE's have issues?
By BillySastard
8 years ago
  • 27 posts
  • 18 Pinsiders participating
  • Latest reply 5 years ago by GRB1959
#1 8 years ago
I have a line on a nice HUO ECLE. I'd be the third owner and the current owner said he hasn't had any light board problems. He doesn't think the original owner had to switch out any boards either because he only owned it for a very short time and he never said anything to the current owner.
So did all ECLE's have light board issues, or were they hit and miss? This pin is obviously out of warranty so if one went out I'd be footing the bill for it. I'm guessing they're not cheap.
The other thing that scares me about buying it is the three hour ride in the back of my pickup. Three hours of the finest winter roads that northern Indiana and Illinois have to offer.
#2 8 years ago
Others will be able to give a more specific date but I believe the new 7.5v light boards were in games either September 2013 or October 2013 and going forward. My ECLE is from Oct 2013 and has the 7.5v boards.
What is the build date on the back of the game? That will help determine if it has the newer light boards. Based on hearing feedback from other early WOZ owners I would think the game would have had a light board problem long ago if it still had the older boards in it.
#3 8 years ago
I haven't had any light board issues - Aug '13.
#4 8 years ago
Quoted from wtatumjr:
Yeah the cut over to the newer boards must have occurred earlier then I thought then. On games that had the older boards it seems like they were going out fairly often.
#5 8 years ago
I'm sorry - Aug 20th 2014...not 2013. I've had other problems but JJP addressed them promptly and quite fairly even if a little out of warranty so I'd expect the same of the light boards
#6 8 years ago
My build was Dec 2013, and I am currently having a light board issues (at first thought it was just 5.05 issues but apparently not) Had to contact support this morning, but from everything I've heard, they will take great care of me.
#7 8 years ago
June 2014, I have replaced three boards I think up to this date. I would say I am probably in the normal (possible)failure rate within that first year. Overall I haven't really had any major issues.
#8 8 years ago
I have the 7.5v boards and haven't had any issues. Not sure of the build date as I'm not near the machine but was not an early game.
#9 8 years ago
I've got a very early edition; 5/13. It came with all 5v boards. I had to replace 2, maybe three, with the newer 7.5v boards within the first year. The last one was replaced in 12/13. All the remaining 5v boards are holding up just fine. So far. Knock on wood.......
#10 8 years ago
I had some issues with the connector wires between light boards early on where I needed to replace two connectors. The biggest thing is that when on thing goes out everything downstream does as well. It is quite easy to fix things though. Since then in the last two years the only problems I have had are two broken rubbers.
#11 8 years ago
I'm waiting to hear back on build date.
Is there anyone out there that has had a light board failure after the pins warranty? Did JJP make you pay for replacements? If so how much were they?
#12 8 years ago
Mine was built 03/23/14 I have had no issues at all light boards or anything else.
#13 8 years ago
The most recent board I had replaced was done under warranty. Though, they gave me a hard time about it. I was told mine was out of the warranty period though I do recall Jack extending the warranty on light boards another year. When I had mention that, I was told that was not true. So, take it for what it is worth. In the end they did warranty the light board but I'm more than certain that is the last one they will replace for me.
A single led was $35 I think?
#14 8 years ago
Duplicate
#15 8 years ago
4/14 no issues.
#16 8 years ago
Quoted from pinstyle:
I've replaced 2 GI LED Boards (7/2014 and 12/2014), the invoice says they are $12.99, but both of mine were replaced for free and I just had to pay to ship the old ones back. My game was delivered 2/2014.
According to the manual the single GI boards made from 9/2013 to 3/2014 are different than after 3/1/14 so I think I needed a couple of the "after 3/1/14" boards to make my game rock solid. No board issues since 12/2014.
#17 8 years ago
I had an earlier 5v game. Now with its third owner and still no light board issues.
#19 8 years ago
All 5V boards in mine with zero issues.
Dave
#20 8 years ago
My WOZECLE has a build date of 10/24/2013 and has the upgraded 7.5 volt LED light boards. My 7.5 volt LED light boards do not have the daughterboard enhancement board. I have not had any LED light board issues on my game.
I haven't had any playfield issues with my WOZECLE (chipping clear coat or lifting artwork). As I understand it some of the earlier Bader playfields had issues with the paint adhering properly to the wood playfield which was later corrected on the playfield production line after this was discovered.
Based on this just because a game has a Bader playfield doesn't necessarily mean that game will have a playfield problem. I have no idea of the dates for the early playfield manufacturing process when this issue was corrected. I haven't heard of the Mirco playfields having this issue.
Hopefully others will chime in with their build dates and what else to look for and their experiences with WOZECLE.
Gord
#21 8 years ago
#22 8 years ago
Pinside burp
#23 8 years ago
Mine was built in August 2015.. No issues.
#24 8 years ago
I have the 7.5 volt boards (came without buffer boards) Only have an issue in the winter. We have a hot air system. It appears that the dryer it is more static charges in the air and more likely that boards will freeze color wise while playing. Sometimes it will fix itself during a game otherwise a reboot is needed. I have replaced several boards with the newer boards with buffer but still have issues when the heat is blasting.
No issues at all during the warmer months, and have not had a board fail altogether.
2 years later
#25 5 years ago
Zombie thread alert!
How does one identify which light board set they have?
#26 5 years ago
They either have 5v or 7.5v the later ones
Some are 1.4version
#27 5 years ago
Quoted from jfesler:
The version number is printed on each WOZ light board PCB. My WOZECLE has a manufacturing date of 10/24/2013 and photos of a couple of the light boards are shown below.
Gord
$ 130.00
$ 29.99
Hardware
Classic Game Rooms
$ 24.50
13,000
St. Clair Shores, MI
13,000 (OBO)
$ 29.00
Filament Printing
$ 259.99
Pinball Mod Co.
$ 115.00
Pinball Mod Co.
9,250
Mt Zion, IL
$ 43.00
The MOD Couple
$ 85.99
$ 95.00
Pinball Mod Co.
$ 50.00
Duke Pinball
Stephenson, VA
Pinball Photos LLC
$ 225.00
Pinball Mod Co.
$ 159.00
Pixels Arcade Games
$ 199.00
Pixels Arcade Games
This page was printed from https://pinside.com/pinball/forum/topic/woz-light-boards-did-all-ecles-have-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
