I have a WOZ ECLE with 2.0 light board upgrade (which I did not perform). It's been working fine with 6.x software for about 8 months since I bought it. Played a game on 6.x SW immediately before upgrade, and everything worked as expected. I upgraded the SW from 6.8.x to 7.0.4 (full install) today. After upgrade, everything seems to have worked OK based on 1 quick play test. I removed the witch plastic cage and lifted the playfield to adjust the witch on her rods. When I put the playfield back down, and tested the game, I noted that none of the LEDs were working as expected. Wrong colors, wrong (or none) showing for specific events.
Tested most switches, and everything seems OK.
Started testing single LEDs, and none of the expected LEDs light for the listed test (something else will light).
Ran LED test (all) and all LEDs are on, for white. When I change colors using enter button, they do not match. So, I get the following:
White->all show White
Red-> all show Blue
Green-> all show Red
Blue-> all show Green
Maybe it was the SW upgrade, or maybe I bumped a cable when I lifted the playfield. I've been looking at the jumpers between boards, etc, looking for something loose, but cannot see anything yet.
Can someone help me solve this, or point me in the right direction? I see lots of posts, but haven't come across my problem yet.
Thanks,
-Adam
