Someone here posted about this on another thread. He said the lower pop ring scrapes against the ball guide on/near the crystal ball, leaving metal shaving to get spread all over the playfield. Sure enough I looked close at mine and he was right. Sparkly metal shavings around the loop by the spinner and the crystal ball and all around that pop area. I was able to pickup the shavings with a slightly damp cloth and it looks ok, and doesn't appear to be ground into the clear at this point but this is really a weak design. He also said that he took out the pop ring, and ground it down with a dremel, so it no long rubs on the ball guide, but I don't want to do that. First of all the thought of tearing down a pop on my brand new game doesn't thrill me and also that would weaken the pop ring assembly, and could cause problems later on. I decided to put a small dab of teflon grease on the area where the metal touches and that seems to help, but this is a definite problem... The area I put the teflon lube is in an area that the ball cannot get to, so it won't spread or anything just keep the metal from scraping/shaving at least for a while. Can anyone else confirm that their game does or does not have this problem?
Suggestions to fix without tearing things down?
Thanks,
Tom
