Does JJP intend to improve general illumination on WOZ or is it what it is? Anyone have any insight on this? Thanks.
Quoted from davep999888:Does JJP intend to improve general illumination on WOZ or is it what it is? Anyone have any insight on this? Thanks.
I love, love, love the WOZ, but my suspicion is once this run is done, there's no looking back.
I think the same follows suite for Stern. No money to be made on an old product, time to move forward.
Quoted from txstargazer3:They just did with software update 2.0 last night.
I saw someone say that, that they've turned on some other lights dimly or something? What exactly changed, and how much of a difference does it really make?
I dunno, adding a couple spots doesn't seem like a big deal to me. My Shadow has a couple spots on the slings that aren't factory, it improves the game.
Quoted from Aurich:I saw someone say that, that they've turned on some other lights dimly or something? What exactly changed, and how much of a difference does it really make?
I just added overhead dimming led track lighting to my game room. I also have a hard time seeing my JP, and many other games in the past.
I might do some sort of kit to WOZ, but my track dimming track lighting is doing the trick.
Oh, and I thought after 2.0 the the game was brighter.
Quoted from PEN:I just added overhead dimming led track lighting to my game room. I also have a hard time seeing my JP, and many other games in the past.
I have halogen tracks, with the lights all aimed away from the games. I rarely want to play in absolute darkness myself. Tell you what though, if I do my Star Trek Premium's lighting is up to the task. Damn that game is bright.
I installed the pinballbulbs.com kit and love it. I didn't really realize how dim it was until it got brighter. Great to play now without any overhead lights on.
Quoted from DylanFan71:I installed the pinballbulbs.com kit and love it. I didn't really realize how dim it was until it got brighter. Great to play now without any overhead lights on.
Highly recommended. I have indirect halogen sconces and overhead indirect tras\ck lighting (both dimmable), and usually play with uniformly dim room lighting (not 'lights out'). And have played a couple of WOZs on location with various room lighting. The PBB kit makes a world of difference. It's easy to see the entire flipper area, the pf artwork, even the ball coming down the right orbit (to time mid-right flipper shots). Makes the game FAR more playable and enjoyable IMO.
I've also got a halogen fixture over my games where WOZ is. I aimed a couple of the lights towards WOZ and they are on a dimmer to balance it out. I like the way it looks.
And to your original question, no. If they did intend to do something, they probably would have by now. So it is what it is. They did make some lighting changes in 2.0 to make it a bit less bad, but the game needs some auxiliary light sources.
Quoted from TaylorVA:New code seems to have brightened the GI. Part of that may be that the LEDS are not so bright and constantly flashing.
The other part is the way they are trying to have indirect light (under a frosted column) light an area. It was never going to be super bright. It's refracted light.
Quoted from markmon:I'm a little biased for the pinballbulbs.com kit but here is my side by side in the same pitch black room. In reality both the before and after are a little brighter but my camera sucked in the dark.
image.jpg 47 KB
The kit lights up the playfield nicely, but you're still stick with the non-illuminated playfield plastics. I hope this issue is addressed for future titles.
There are frosted column lights under the plastics in the lower portion of the PF that are now lit up soft white for GI (instead of being part of the light show in the earlier versions)
It helps alot, but i'd still like a little bit more light down there.
pinball bulbs. I have seen markmons work and it always looks great. I have not seen WOZ but he does this to every game he owns that is not bright enough to play in the dark.
If I had gotten my WOZLE I would have added this kit and then waited and hoped for manufacturer fix in the long run.
I wish there was a way to turn down the insert brightness. The four settings (cold, cool warm and normal) don't do much.
The current level of illumination was designed this way on purpose. If JJP really wanted to change this, they would. The end user might not like how it turned out, so this is where the kit comes in.
Pinballbulbs kit is a great way to go!
Well thought out and covers everything!
If you want to improve the Spots on top, either our Op-Max White or Sunlight, or our flat top 4SMD-12SMD starting at $.99-$2.00, you only need 2 bulbs, house and throne, are a great addition and more then double the light then the 3 LED that are siliconed in....An easy $2-$4 solution that helps the 2 spots tremendously.
Art
cometpinball
Quoted from lordloss:The current level of illumination was designed this way on purpose. If JJP really wanted to change this, they would. The end user might not like how it turned out, so this is where the kit comes in.
So when the hobbit comes out with a different system...
Quoted from SteveP3:So when the hobbit comes out with a different system...
When Hobbit comes out with a different system we will call it learning from you're mistakes. I always assumed that was what good manufacturers did. When you design the next version of something, you try to fix anything you did wrong the last time. Sometimes that can't happen because of costs, or unrealistic expectations. But in this case, they would be foolish to not change it. Heck, I've been a supporter of JJP and will be happy to admit they missed with the GI design because there are lights over my game adding more light. But it isn't as big a deal as people make it out to be. Add lights to the game, add lights over the game, whichever you prefer. Job done.
Hi Jack!!!
I've said this before, but the message seems to get lost. The original design for the GI was not this. It was independent from and different than the inserts. The supplier drastically raised his prices and tried to change things. JJP was forced to change the setup and went with the same system as the inserts and used the tubes to bring the light up to the top of the playfield. Jack said this in a post on the Google Group quite a while ago. I've posted it in the past, I don't feel like digging it up again right now. So don't be surprised at all when TH's GI is completely different than WOZ.
Quoted from ChadH:Anyone have a before/after pic of the brighter GI with 2.0?
Here is an after pic - this is stock with 2.0 software. No more pulsing yellow brick road inserts to blind you. My playfield LEDs are set to "cool" and I have 7.5v LEDs in the lower GI. It is just fine, now - equal in GI brightness to other widebodies I have owned in the past.
woz-GI.jpgQuoted from PinballCharlie:Here is an after pic - this is stock with 2.0 software. No more pulsing yellow brick road inserts to blind you. My playfield LEDs are set to "cool" and I have 7.5v LEDs in the lower GI. It is just fine, now - equal in GI brightness to other widebodies I have owned in the past.
woz-GI.jpg 70 KB
whats the room lighting like? Looks to be completely off.
Quoted from TaylorVA:whats the room lighting like? Looks to be completely off.
No ambient lighting in this picture - gameroom was dark.
Definitely a step in the right direction. Add in a couple spots for the flipper area and call it done.
Quoted from DaveH:When Hobbit comes out with a different system we will call it learning from you're mistakes. I always assumed that was what good manufacturers did. When you design the next version of something, you try to fix anything you did wrong the last time. Sometimes that can't happen because of costs, or unrealistic expectations. But in this case, they would be foolish to not change it. Heck, I've been a supporter of JJP and will be happy to admit they missed with the GI design because there are lights over my game adding more light. But it isn't as big a deal as people make it out to be. Add lights to the game, add lights over the game, whichever you prefer. Job done.
Heh sorry I guess I missed the mark with my original comment - my point was that it seems to be somewhat common knowledge that they're coming up with another implementation for The Hobbit, so the other fella's comment about "The current level of illumination was designed this way on purpose. If JJP really wanted to change this, they would" seemed funny to me; since the current system was obviously a 'miss' and they knew it. We're in agreement completely, my wording may not have conveyed my little joke very well.
woz-GI.jpg 70 KB
A nice change but did not go far enough. The others still pulse. I don't want any pulsing.
woz-GI.jpg 70 KB
I also notice here that TOTO has different colors....do they ever change? Mine always stays a dull orange...and the white under the lower slings on mine are green. I do have 5v bds...wonder if that has something to do with it...and i do have 2.0 installed.
Quoted from Vyzer2:I also notice here that TOTO has different colors....do they ever change? Mine always stays a dull orange...and the white under the lower slings on mine are green. I do have 5v bds...wonder if that has something to do with it...and i do have 2.0 installed.
Are you saying the GI lamps underneath your slings are always green? If that is the case, you have lost the red and/or blue signal on those specific LED boards and they need to be replaced.
TOTO lights are usually pale orange, unless the mode is no longer available, then they turn red.
woz-GI.jpg 70 KB
Agreed....now the GI is pure white during gameplay and looks fine....adding a couple of spots? I've done that to several of my games...no biggie.....I've now lowered my overhead halogen 20w to about 15% and more than enough.....mark
Quoted from PinballCharlie:Are you saying the GI lamps underneath your slings are always green? If that is the case, you have lost the red and/or blue signal on those specific LED boards and they need to be replaced.
Yes they are green (actually one is green, and one is white) thought that was normal till I looked at your pic and saw a video....Ill ask for a new board.
As to toto..look at the pic you posted..the first t looks orange, 2nd red, then ?, last one blue??? Ive never seen them all look different.
Quoted from Vyzer2:Yes they are green (actually one is green, and one is white) thought that was normal till I looked at your pic and saw a video....Ill ask for a new board.
Ah - yes, I see what you are saying. The (T) light is a 5v, so it is dimmer with a slightly different hue. The (O) is a newer 7v board. The other "T" and "O" are off, but some of the GI light from the outlanes is leaking through.
Quoted from Craig:The only problem with the added spots on the WOZ is the fact that it sits next to my LOTR, which looks downright murky by comparison.
Sounds like you need the pinball bulbs lord of the rings kit to solve that
Me, too! But I think LOTR is supposed to be a darker, earthier, more ominous looking game. No rainbows shooting out of your ass when you're playing that game...
Youre right flashy bright lite shows don't go with Lord of the Rings.
I wonder how JJP will handle the Hobbit lighting, it can't be all bright and rainbows like WOZ. I bet they do dark and sinister lighting for Hobbit, and still make it work incredibly! Light shows can be greens, and gold, and white led explosions! Should be really cool...still...
Tom
Quoted from beelzeboob:Me, too! But I think LOTR is supposed to be a darker, earthier, more ominous looking game. No rainbows shooting out of your ass when you're playing that game...
Pathetic. I OWN a WOZ and love it - but I write about no rainbows shooting out of your ass when you're playing LOTR and I get thumbs-downed.
I'm the biggest supporter of JJP outside PanzerFreak, I think, but now I finally see how ridiculously sensitive some people are. Give it a rest...you can't even joke about the friggin' color scheme of the game?
Don't know what the offense was - the rainbows, my ass, or the combination of the two. Get a sense of humor.
EDIT: By the way, you can see the difference in the machines in the avatar photo of my wife playing them - they're side by side.
Quoted from beelzeboob:Pathetic. I OWN a WOZ and love it - but I write about no rainbows shooting out of your ass when you're playing LOTR and I get thumbs-downed.
Clearly you are insensitive.
EVRYONE knows that only unicorns have rainbows that shoot out of their asses.... so suggest otherwise is mean-spirited and deserving on a thumb-down and also no dessert before bedtime.
No anti-JJP, anti-MMr, anti-metal band or anti-Led-lighting is to be tolerated.... also, sarcasm is banned.
This page was printed from https://pinside.com/pinball/forum/topic/woz-general-illumination-does-jjp-intend-to-improve-this and we tried optimising it for printing. Some page elements may have been deliberately hidden.
