Developed a few issues with my WOZ after a recent move. Looking for a bit of guidance as to what might be the underlying issues. Engineer is visiting tomorrow. Machine was treated extremely gently in the move, and cab still looks perfect. Only thing was that when I came to switch it on the first time, BIOS boot screen came up saying there'd been an unexpected shutdown (I don't remember it). Hasn't happened again though.
- Winged Monkey monorail does not work - including at system boot.
- Added LED kits are dead - illuminated state fair balloon, haunted forest eyes, under pf kit.
- Spotlights all dead.
- Topper illumination no longer works.
- Throne room picture of wizard no longer illuminates.
- Throne room torches no longer illuminate.
- Witch no longer raises or lowers, nor do her well mounted LEDs work. Target still works normally, but her hurry up no longer ticks down and stays at maximum value, but can be awarded. Fireball Frenzy jackpots no longer work.
- No toy tests save for the castle doors work.
- No coil tests work.
- However all mechs and coils work normally in normal gameplay except for the winged monkey's monorail and the witch.
Game behaves perfectly otherwise.
I'm hoping it's a fuse issue, but seems like remarkably disparate things. The only one that I'd experienced before was when I first got it, a single time the toy and coil tests didn't work, but then rebooted it and all fine.
Oh, and another thing is that slings are double, triple or quadruple (or more) firing sometimes, so had to turn the pulse timing down to prevent coil burn out. But that occurred before the move. Assume the switches need adjusting and it's completely unrelated to the other stuff.
Thanks in advance for any help.
