Quoted from attitude05:I'm wondering if I have a dead coil.
Quoted from zaphX:More than likely you had a solder wire break.
You might be able to inspect it from underneath.
Harder to check all the wiring to the coil lugs with out taking things apart.
I'd suspect the thin wires from the coil windings to the lugs. Easy to have a crack or break you can't see, you have to dig around them.
Assuming both sets of leaf blade switches register on the screen. Go into Tests - Switches - Dedicated, slowly push the flipper button in. First lowers than uppers should register on screen.
And more recently I have had a few coils that were in fact dead. I didn't tear them apart to see what happened. This is something I haven't run into in all my years until this year.
