Vireland posted this some time ago.
These are pretty raw, I didn't clean them up, but the information is all there. Note the L-bracket and metric screw size you'll need to secure the new switching power supply to the cabinet that aren't included...
General notes:
The part number for the single plug black wires is wrong on the wires. It says 19-3096-09, but the diagram from the current manual (page E-22/23) identifies the short black leads as 19-3096-08. Either the manual or the part needs to be changed so they agree
Somehow I came up short on 1/2" and 3/4" screws by a few. I didn't count at the beginning, so I'm not sure if the amount provided isn't enough, or if my kit just didn't have enough screws in the bags.
Some of the leads are too short for the lighting plugs. I had to move boards at the end of the instructions that I installed near the beginning, and even then a few BARELY had enough wire and too much tension. Lights 3 and 12 specifically. Probably should be made 2" longer at least.
Might want to mention at the beginning that the customer needs to buy a couple small L brackets and two 4-M4 screws plus 2 pan head wood screws for the new switching supply they'll be installing as they're not included in the kit.
Step 6.The warning “DO NOT remove all the large boards at once – if you do...” needs to be at the BEGINNING of the FIRST paragraph after the 6>. Putting it on the second paragraph is too late for awesome people like me. Fortunately (?) I’ve spent so much time with these boards, I can see the placement in my head with my eyes closed, so it was no biggie, but for less confident users, this could be annoying/problematic the way it is now.
Also, on the 2nd paragraph of step 6, you’re asking to use #4 ½” SMS, but the screws are labeled with the PART NUMBER not the SIZE on the bags. So the screws should have the part number listed next to the size (“#4 ½” SMS [82-000004-08]” for example) in the instructions and/or the bags of screws should have the size of the screws printed on them along with the part number.
For step 7, it's a similar suggestion to step 6 beginning to make the warning more clear about removing and replacing one by one in order instead of talking about how to take them all out in order one by one in order so you don't miss one. It becomes more clear after the 2nd paragraph of 7>, but some of that information could be moved to the beginning of 7>.
The second paragraph of step 7 talks about installing single RGB GI board 15-0051-00. This doesn't exist. What's in the kit is part number 15-004151-04, which is a strip of 8 boards you need to snap off into individual boards. This isn't covered in the instructions at all. The packing slip also has the part number listed as 15-004151-04. The only place where it's called 15-0051-00 is on step 7. Also the packing slip says there are 24, when in reality there are 3 strips of 8 you have to break off into 24 pieces, so that's not quite right, either.
Also, on Step 7 it should say something about board 11 that will be dealt with later. Something like "(Calm your titties, board 11 will be replaced in Step 14)"
Step 9 in the instructions needs quite a few changes
The part number on the instructions are 15-0028-00. The part number of the parts in the box are 15-004128-04. Also, the parts in the box need to be snapped apart, which is not discussed in the instructions.
Also:
1- The part number for the 4-40 1/4" screws (80-002104-04) should be added to the instructions, and the screw size should be added to the part bag label for better matching.
2- The part number for the insulating paper (70-009010-00) should be added to the instructions and maybe add "insulator" to the parts bag label for better matching.
3- The part number for the new mounting bracket for the rollovers (10-000155-00) should be added to the instructions and maybe add "rollover bracket" to the parts bag label for better matching.
Step 10
Part number 15-0028-00 is wrong. It should be 15-00428-04. #4 1/2" screws should have part number noted (82-000004-08).
Step 11
Step 12
Terminology is wrong here. It says to use Single GI RGB LED boards, but it's actually talking about using 15-00428-04 RGB LED boards in the just- made GI RGB rollover brackets.
Step 14
Step 15
The part number for the PCB mounting bracket should be noted next to its name in the instructions (10-005035-00)
STEP 18
For Step 18, it's actually better to leave the playfield UP initially until J802 is disconnected because it's at the front of the PCB box, toward the coin door. Once the cable is disconnected and slipped out of the zip ties, THEN lay the playfield down to pull the cord out the back of the PCB box. Also, a copy of the printed diagram from the manual showing WHERE J802 IS would be very helpful, it's kind of hidden by a wad of cables and not easy to find visually. I've attached a screen grab to include with the update.
Also, the instructions say to pull J800, but no word about JUSB next to that, which is also a mini-USB connector. On the Computer CPU board end, both these are wired to the same plug. NOTE: YOU ONLY PULL ONE OF THEM - the J800, even if they're physically connected on the computer board end like they are on early ECLEs.
(The problem is both the JUSB and J800 are the same cable, split into two cables at the header block on the PC motherboard. So the instructions to remove just the J800 is wrong because the best you can do if you have to keep JUSB is to just disconnect J800 since they’re physically the same cable. If you have this configuration, you leave it plugged in on the computer header end and just unplug J800 usb on the other end, leaving the other plugged in.)
STEP 19
Where is the Mini-b end of the 6ft USB cable you connect to the back of the CPU board supposed to be plugged in? J800? JUSB? It doesn't say. Also, the 6ft USB 2.0 to Mini-b cable needs the part number listed (19-003100-06).
