(Topic ID: 87617)
WOZ Fan Club - members only
By TigerLaw
7 years ago
  • 13,195 posts
  • 660 Pinsiders participating
  • Latest reply 3 hours ago by Rager170
  • Topic is favorited by 303 Pinsiders
11 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 13,195 posts in this topic. You are on page 246 of 264.
#12251 10 months ago
Quoted from Darkfader:
How do you remove the stainless steel guards that are behind the Optos so I can reflow the solder connections?
Take the ramp off and unbolt them.
#12252 10 months ago
Question:
I want to change the battery on the motherboard of my ECLE.
Change while the machine is running, because of the BIOS settings?
#12253 10 months ago
Quoted from waynetrane:
Yes please. Game turned on.
#12254 10 months ago
Question:
Watch out for the fan next to the battery. It draws blood.
#12256 10 months ago
Anyone have a set of 7.5 boards they want to sell? Or at least the rainbow and witch castle boards? Thanks!
#12257 10 months ago
I went to change the battery on my RR Woz and when I took the cover off of the electronics in the cabinet, this cable came off. I think it controls the crystal ball, as it is not currently working.
Can someone tell me where this cable connects? Photos would be apprciated.
Thanks,
Rob
Cable.pdf
#12258 10 months ago
Quoted from rrosenhouse:
Check the pinouts for the motherboard in the manual.
#12259 10 months ago
Can someone tell me if there is a way to level to castle playfield left to right? Mine is over one degree slanted. Thanks!
#12260 10 months ago
Quoted from HornerSyndrome:
It sits on posts doesn’t it? Could you put a washer on one of the posts before you screw it back down? I haven’t tried this so just a thought.
#12261 10 months ago
Are you still able to cradle a ball? The pf might not be perfectly level by design.
If you change the pf angle, you may lose the rebound effect. If you can cradle the ball as it is now, it's probably ok. If the ball rolls toward the tip preventing the ability to cradle, then yeah, the angle would need an adjustment.
I was able to drastically increase the playability of the castle playfield by moving the left post at the exit to the right hole (closer to the flipper.)
After doing this, the ball had a significantly greater tendency to bounce back toward the flipper keeping it in play.
It requires a focused effort to drop the flipper waiting for the rebound, and then immediately cradle before the next shot.
#12262 10 months ago
I bought my RR, new, in 2014, first run. Everything I have been through, I have never seen this. At start up, will not progress from there. [email protected] LTG, or, anybody else have a clue? Thanks.
#12263 10 months ago
Quoted from Nokoro:
Correct it sits on 4 post. Before adding washers or adding anything I would check that the four post are all screwed down firmly into the main playfield. It might be a matter of where one or two of the post aren't screwed down thus the pf is off. Once this is confirmed then make certain that the playfield is sitting on all four post.
In theory, the 4 post are the same length so if they're screwed into the main pf correctly and then the castle pf is sitting on all 4 the castle pf would be level to the main pf!
#12264 10 months ago
Quoted from HIPPY:
That looks like the cmos (coin) battery on the motherboard is dead and needs to be replaced.
#12265 10 months ago
Quoted from bigbadmiker:
Thanks for the reply. Just so I can understand the screen, what tells you that?
#12266 10 months ago
Quoted from HIPPY:
“All settings were reset to default values...
Cmos battery allows the bios settings to stay saved while the PC is off. I’ve seen it plenty of times with computers and arcade machines.
#12267 10 months ago
Thank you.
#12268 10 months ago
I think best bet is to replace the battery. Then if it stll gets the message, I believe you’ll have to plug in a keyboard and hit F2 to continue to continue boot.
For now, if you have a usb keyboard, you should be able to plug it into the PC and then it hit F2 when the message comes up. Turn off the pinball machine first. Plug in keyboard, turn on pin. Hit F2 on keyboard when message is displayed. It should boot into game. But, expect the message to come back each time you turn on the pin until battery is replaced.
#12269 10 months ago
I went to a local store and got CR2032 batteries, changed it, and it sprung to life, no problems other than a switch opto bugging me, again. Thank you very much.
#12270 10 months ago
Just acquired a WOZ standard with 7.5v 1.1 light boards. Half of my lights on the W1 board work(stops at number 2 and everything in the string behind it is dark) ). Would this potentially be a cable problem or board circuitry. Looking for a place to start troubleshooting
Thanks in advance, Chris
#12271 10 months ago
Quoted from Charger68:
Probably the board, a 2.0 light board system was released to correct the issue.
#12272 10 months ago
Quoted from zaphX:
Im on the wait list
#12273 10 months ago
Having some strange symptoms I haven't been able to chase down yet.
During gameplay the RESCUE will pop up randomly ever though I'm not on that upper playfield. It has happened even with the Winkie guard up. Its happened at the exact time I pressed the right flipper, but unsure if thats just a coincidence. It does not stay active but pops up and then dissapears again.
Any guidance on what to check first? My monkey did not release the ball prior to this happening last game, but again I'm not sure if that is related.
What would make it activate?
#12274 10 months ago
Quoted from paulbaptise:
Likely one of the switches on the castle playfield is gapped too close and being triggered by flipper vibration. The game thinks the ball is up there when it isn’t. Put game in switch test mode and bang around that playfield with your fist to see if anything triggers.
#12275 10 months ago
Quoted from Nokoro:
I will do just that. Thank you!
#12276 10 months ago
I have the Castle walls with cauldron for sale. Pm if you are interested. New in box, never installed unfortunatelly.
https://pinside.com/pinball/forum/topic/castle-wall-mod-and-well
0CACD71C-5938-4C0C-B7DB-E51CC42ED965 (resized).jpeg4E46B2EC-AA59-480A-9D7C-BDAF79DEFAB0 (resized).jpeg7257BD03-907B-4BA4-824C-1E5B3E390EE4 (resized).jpeg80A91666-AD33-421E-AEE7-3FB13DF1107C (resized).jpeg8C1367FB-D3CF-4447-8811-89F9F715A266 (resized).jpegB75176FD-09B0-4E28-A186-350873A78FC0 (resized).jpeg
pictures are from the topic
#12277 10 months ago
Quoted from PinPeet:
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Those are really good looking walls! Cauldron is cool, too. If you can’t get Gouveia’s witch, that cauldron would be pretty bad ass. Pretty steep tag though.
#12278 10 months ago
Does anyone know where I can get a replacement led light for the witch’s mod? Seems the wire came loose from the leds and not sure where previous owner got the mod from. Thanks!
#12279 10 months ago
Lermods.com
#12280 10 months ago
If anyone has a Ruby Red edition they are planning to sell in the near future (ideally with the new 2.0 boards), PM me. Willing to pick up when the border opens or shipping is an option as well. Thanks.
#12281 10 months ago
Hi WoZ fans... just want to let you know about our Lit Ramp Sign now open for the 2nd batch group.
https://pinside.com/pinball/forum/topic/woz-lighted-ramp-sign-by-pmc#post-6196186
#12282 10 months ago
If the balls don’t release from the munchkin lock is the prevailing thought that the bar is not lifting enough?
#12283 10 months ago
Quoted from TaylorVA:
Play with the timing in coil settings first.
#12284 10 months ago
Check the coil wire for cold or badly soldered joints first then
See if the mounting screw that secures the bar is tight before any adjustments.
The bar should not be able to be moved side to side.
A loose bar or loose coil makes the lift very inconsistant.
In fact, while looking at the mechanism with the Huts plastic off, check all of its fasteners including the big single screw that holds the coil. All should be snug.
When making timing adjustments, only change the numbers by 3 or 5 at a time to dial it in.
Small adjustments to the timing work best, write down the original numbers. Otherwise it can be maddening to get it right,
#12285 10 months ago
sadly one of my my original red shoe flipper bat broke today... i was disappointed to see that the part is not available on JJP store anymore, is there any other way i can find a replacement?
#12286 10 months ago
Quoted from hisokajp:
The last time one of mine broke, it said it was unavailable. But I contacted them via email and they have them. You just need to reach out.
#12287 10 months ago
Quoted from harryhoudini:
That is pretty nice, Im in
#12288 10 months ago
Quoted from pinballjah:
I wouldnt be surprised if border closed for a long long long time still. Whats up with that?
#12289 10 months ago
Save the pieces and glue it with CA gel glue to a new sparkly flipper:
https://shop.thepinwitch.com/Flipper-Parts/Flipper-Bat-and-Shaft-Assys/Flipperbat-Transparent-red---with-Glitter-and-Jersey-Jack-Logo.html?language=en
JJP might have some but not in red glitter.
Rick was the last guy who had them and I think he's sold out.
#12290 10 months ago
Quoted from pinballinreno:
Here ya go!
https://shop.mrpinball.com.au/product/flipper-bat-set-l-r-w-ruby-slipper-wizard-of-oz/
#12291 10 months ago
#12293 10 months ago
very cool, thanks guys!
#12294 10 months ago
Let me look, I might have a spare.
#12295 10 months ago
Hey guys, after finally updating my emerald yesterday to the most recent code I feel like the image on the screen is not as clear and crisp as it was with the 6 update. Am I imagining this or does the monitor need to be adjusted now ?
#12296 10 months ago
I have a handful of those red glitter bats if you need one or two locally.
#12297 10 months ago
Taylor to the rescue!
#12298 9 months ago
My WOZrr started some strange behavior last night that I can't seem to wrap my head around. The game had been working fine up until last night and I have not lifted the hood in a while, so nothing recently changed as a part of anything I had done.
So initially, the game would play fine until the ball hit the upper left pop. Once it hit that pop, the flipper power would die and some random coils might fire (castle VUK or crystal ball VUK) until the ball would drain. Once the ball would drain, the house would spin for a second and then the flipper power would return and a new ball would get fed to the trough. Game would be fine until that upper left pop got hit again and then the same thing would happen.
I rebooted the game and same problem existed. Raised the hood thinking something on that pop might be shorting out on the side rail, but nothing I could see looked wrong. Put it back together and went to coil tests. Initially when testing that upper left pop, it would also briefly cause the house to spin once or twice, then that stopped. I went through the other coils and when I would test the castle VUK and then go to the crystal ball VUK, it would switch, but then fire the castle VUK one more time about 5-10 seconds into the CB VUK test. Also did through same the other way, firing the CB VUK during the castle VUK test.
Anyway, tried playing again and the game suddenly began to play fine with the upper left pop not killing the flippers. All was good until it hit the crystal ball VUK, and then that coil killed the flippers until the drain, the house spun for a second, before all was restored again.
Another strange thing was at one point back when the upper left pop killed the flippers, the game was awarding jackpots and super jackpots with callous as the ball was coming down the field to drain. I think this was happening while other coils were mysteriously firing.
Anyway, I have never seen behavior like this and don't even know where to begin diagnosing this problem. Anyone seen anything like this before and have any suggestions?
Thanks in advance...
#12299 9 months ago
Quoted from Calfdemon:
Just a hunch, but the bracket and switch for the skill shot is really close to the rail and can cause a short to ground especially with the left pop firing right next to it. Try wrapping the bracket and switch in electrical tape — not a bad precaution in any case; see some of my earlier posts where I had a major issue with it — and see if that helps anything.
#12300 9 months ago
Quoted from Nokoro:
I'll give it a shot, can't hurt. In the meantime, open to any other ideas or experiences... I'll report back later and see if this made any type of difference, thank you.
