We're back!
After a disaster in our datacenter took down our server, we are now running Pinside on a brand new server. However, things may not work as expected as we are still polishing the playfield and adjusting some switches! We might be switching to maintenance mode a few times. Please see this forum topic for more info.
(Topic ID: 87617)
WOZ Fan Club - members only
By TigerLaw
7 years ago
  • 12,383 posts
  • 622 Pinsiders participating
  • Latest reply 3 hours ago by brickbuilder14
  • Topic is favorited by 284 Pinsiders
9 key posts have been marked in this topic (Show topic index)
There are 12383 posts in this topic. You are on page 245 of 248.
#12201 55 days ago
Hey all, looking for some help. Is anyone else having issues with balls getting stuck in munchkinland? It's random, but becoming more frequent. During play, I often have to open the coin door in order for the lover to release the balls. Sometimes that doesn't even do it and I have to pull the glass and manually lift the lever to release the balls. it used to be a blue moon issue, but is becoming more and more frequent. Any suggestions would be appreciated! Thank you.
#12202 55 days ago
Quoted from RoboBot:
There are multiple posts in this thread about bending the tab to make this work more reliably. Do a search in this thread for "bending" or "tab" and you should be able to find them. Look specifically for posts from LTG.
#12203 55 days ago
What bobukcat said. The arm is too low.
#12204 55 days ago
Thanks to both of you. Knew LTG would know right away. Well, Scott's munchkinland arrived today so it's a good time to get er done! It's a great looking mod.
#12205 54 days ago
Quoted from jake35:
What does everyone set their flipper strength settings to? Trying to use the best strength without breaking things.
While you're at it, if the previous owner hasn't already done so I would reduce the crystal ball VUK some as default setting is way too strong. I also toned down the pop bumpers a bit and the upper sling below the OZ lanes as that rubber is prone to breakage.
#12206 51 days ago
My weekend project. Installing this mod!
#12207 50 days ago
Hi Guys,
Have a small, minor problem maybe someone can help with. I noticed that when plugging in my headphones, I cannot access these two greyed out options in the menu. I would like to make the headphone jack volume louder than it is, without adjusting the machine volume. I am at the max so far.
So far I cant seem to figure out how to do it...
#12208 50 days ago
Quoted from Rager170:
Hi Guys,
So far I cant seem to figure out how to do it...[quoted image]
I don't know the fix but found these threads. Maybe they can help.
https://pinside.com/pinball/forum/topic/woz-low-headphone-volume
https://pinside.com/pinball/forum/topic/headphones-dont-work-on-woz
#12209 50 days ago
Thanks... The first link was a bit useful... Just still not sure why these two options are greyed out when the headphones are plugged in. All I want to do is increase that one option for headphone volume...
#12210 50 days ago
May be a dumb question but .... can you adjust them first and then plug in the headphones?
#12211 50 days ago
Quoted from meSz:
Well, they do work and what I can do is simply open the door to turn the machine volume up, which increases the headphone volume higher.
What I simply wanted to do was increase that one setting so that the headphone volume is much higher, then be able to use the coin door headphone controls to lower it down to where I want. As it is now, the max headphone volume is simply too low.
Like I said, its a minor annoyance issue. I just don't like having to crank up the machine volume to get decent headphone volume because I know I will forget to lower the machine volume and then it will be super loud when I unplug the headphone or turn back on the machine at my next time playing. I have two young daughters and I play at night mostly, so loud noises are to be avoided ha.
#12212 50 days ago
I really wish the crystal ball was more reliable!? The connector pins fell off my computer board. I took the board off the crystal ball and sent it back to JJP . They resoldered it for $25 + shipping. It works again but about 1/2 the time the image is just garbled colors or upside down text.
The ball (or TV inside it) is mounted at such a weird angle that only someone 5 foot tall could easily see the images inside it. Taller people have to duck down and to the right to see the images. Did JJP not do any research or quality control on this basically useless toy?
Does anyone else have these problems with the crystal ball?
#12213 50 days ago
Quoted from d0n:
I have the same issues with my CB, I don’t know how to fix it and just assume I’m shit out of luck.
#12214 50 days ago
Quoted from d0n:
Quoted from TaylorVA:
I installed the crystal ball mod upgrade. It’s fully adjustable for image size and position.
#12215 50 days ago
Quoted from MrMikeman:
Didn’t even know this was a thing. Is through JJP?
#12217 49 days ago
Quoted from d0n:
I replaced it with a new LED screen, rock solid now.
#12218 49 days ago
Same here...installed PinballMods crystal ball upgrade and new OLED screen from JJP. Not cheap, but no more issues and crystal ball is adjusted where I can see it from my playing position. I’m 6’2 so the factory crystal ball position wasn’t ideal for me.
#12219 49 days ago
The Gouveia Crystal Ball mod is the crown jewel... handmade. Seriously, it's a work of art. No 3D printing. Meticulously detailed.
It re-orients the ball image so it's easy to see. I'm 6'2"
If you can find one, highly recommend.
38544477-AFB3-4DA1-A35A-DE71AE0B47E2 (resized).jpeg5E5BE025-2CF4-402D-B5B0-AFEA80EBE31B (resized).jpegBB423B5D-0632-4B3A-8F3F-0E9406F26FFF (resized).jpeg
#12220 49 days ago
Quoted from 27dnast:
Man I always miss out on these mods
#12221 48 days ago
Can you send some pics taken from your machine? Ive been curious about this mod since you can adjust the angles but havent seen any pictures from players...
#12222 48 days ago
Looking for WOZ std #530. I’m the original owner and been on search to see if I could locate it and maybe buy it back. Long shot but thought I try posting in the club thread.
#12223 48 days ago
Quoted from pin15:
Good luck with your search.
If you get the story of it let us know.
#12224 48 days ago
Quoted from fnosm:
Wondering if OP just remembered hiding something valuable in it lol.
#12225 48 days ago
Players perspective. In my case I had to insert a small spacer underneath (blue key fob visible). Otherwise the ball was contacting the crystal ball on the u-turn ramp and getting bumped off the wireform. All machines are slightly different and my wireform is sitting about 1/8" too high.
987DF46A-ED0D-49B7-92FC-979F36E555B9 (resized).jpeg6D6AF3CF-CC41-439E-8BB2-E4B4D1F6956A (resized).jpeg612081D0-C1C2-464F-8CF4-364DCDE5A273 (resized).jpeg7BE02D71-3A27-4CE0-8E3A-6C2A9B5B47A2 (resized).jpeg
#12226 47 days ago
Thanks. The mod looks good.
Curious, you had to put the spacer in the front to prop it up. I would think that would make it sit further back towards the wireform, where the ball could hit it more?
How does that mod install? Is it using that bolt/nut that holds the wireform as the stock did?
#12227 47 days ago
The spacer goes all the way back. The whole base is lifted about 1/8".
The install/adjustment is a PITA. But once it's in it's awesome. You can't make adjustments when it's installed. Has to be removed, adjusted, installed again.
I just had most adjustment screws/bolts tight enough for some friction but still moveable. Once I was happy I carefully uninstalled and tightened everything, then re-installed. Once I started playing that's when I noticed the pinball would fall off the wireform. Tried a lot of things but in the end just lifting the base a little provided the clearance I needed.
#12228 47 days ago
Thanks but it's $115 and it's out of stock. Probably not worth the money just to be able to see into the ball a bit better. I'm sure there's a cheaper and easier way. Spacers, washers etc etc etc.
#12229 47 days ago
Quoted from d0n:
CB mod from where? thanks
This has to be the PMC crystal ball mod because the Gouveia crystal ball mod is unobtanium.
https://pinside.com/pinball/forum/topic/pmc-woz-crystal-ball-upgrade-announcement-
#12230 46 days ago
Quoted from fnosm:
Yea thats a bit of a pain. I was under the impression that you could just adjust it on the fly if needed.
Im not really a fan of either of the Crystal Ball mods. The other one by Gouveia, I do not like that you have to break your original mod to install the new one, and personally, i have a hard time with that pan handle base. Just dont find that attractive at all and sticks out like a sore thumb.. To each their own of course.
All in all, the stock crystal ball doesn't bother me really at all. I just wanted to be able to adjust it.
#12231 46 days ago
I don't understand what you mean by having to break something. The PMC mod requires you to re-use the screen (of course otherwise the price would be insane). You don't break anything. Just remove the screen and re-attach it to the improved crystal ball. One thing I have to mention and isn't really visible in pictures is how bright the image is in the new ball. The contrast is amazing. The JJP ball is plastic. The mod is real glass. Makes a big difference.
#12232 46 days ago
He was talking about the Gouveia mod. In that one, you reuse your original crystal ball, so you have to break it from the stock mount, which results in the stock mount being destroyed most of the time. The PMC mod supplies you with a new crystal ball, so your original one stays intact.
#12233 46 days ago
I guess you didnt understand where I referred to the other crystal ball mod where you have to break the stock part?
#12234 46 days ago
Quoted from Calfdemon:
Correct.
#12235 46 days ago
Didn't break my stock mount...
#12236 46 days ago
I know you referred to his mod but I didn't know that about Steve's mod. Kinda surprised really. Getting a real glass ball makes a very noticeable difference I would have thought his mod would have that given the quality of his stuff.. Time for a cyrstal ball v2.0!!!
#12237 46 days ago
I was surprised that it didnt come with another glass ball also, especially for the cost. 2.0 hahaha
Myself, I never like getting rid of stock parts because you never know when you will need it..
#12238 46 days ago
There was no saving my mount. JJP overdid it with the glue (cement) and I actually had to file off a bunch of the leftover mount that was still stuck to the ball when I finally got it free. All good though, Steve's mod is a thing of beauty once it was all put together and installed.
#12239 46 days ago
They must’ve learned a lesson from the first run. The ball on my original standard WOZ appears to be held on by little more than a repositionsble glue dot. I have to remember to take it off the base before lifting the playfield or it’ll fall right off!
#12240 46 days ago
I installed my munchkin hut mod today. Overall, I think it is a nice addition that improves the look of the game. Here is a before and after photo.
196DADD1-3CA8-4E4F-A33F-9E19F40B41EE (resized).jpegBB0570A4-C310-478C-96F7-FF9CA82A6EEA (resized).jpeg
#12241 46 days ago
Wow, that hut mod is a true beauty in its own, and a huge improvement over the rather ugly stock one.
#12242 46 days ago
Quoted from Gotfrogs:
Your blades look great and congrats on your new mod. Thanks for posting.
#12243 44 days ago
That mod looks great, nice job! I’d jump on it myself, but that doesn’t look like it will work well with Pinstadiums, so it’s a pass for me. I have the PMC crystal ball and flaming witch mods and they are amazing
#12244 44 days ago
Quoted from darkryder:
You dont think there is enough room with the stadiums?
Nevermind, I didnt see that top piece at first.
#12245 44 days ago
Quoted from fnosm:
I agree, those blades are great. Wish they still made those ones.
#12246 44 days ago
Curious, are the lights on the huts interactive?
#12247 44 days ago
I think there's a V2 coming that can be retrofit on V1 that will have interactive lights.
#12248 44 days ago
Quoted from adol75:
Oh very interesting...
#12249 44 days ago
On the crystal ball mod, I just installed Steve’s which also makes a big difference in the effect (i think the original mount just held it at a bad angle). On mine the base had a very reasonable glue dot that allowed me to remove it with very little damage to the original base. If ever needed I could absolutely reuse it (not that I would).
A glass ball also sounds awesome though.
Also, this week I got the Witch 2.0 so I have my 1.0 Witch mod going up for sale. Putting up a classified ad after work.
#12250 43 days ago
Hey guys, my Second ball lock onto on the 3 ball lock mechanism has an Intermittent connection at the opto, How do you remove the stainless steel guards that are behind the Optos so I can reflow the solder connections?
