My YBR came set on Hard and I just realized it. Also, zero seconds ball save. I was watching Eric play on You Tube and he had ball saves, but said he was playing factory settings. What is normal Factory Settings? Just curious.
Quoted from Noma2017:My YBR came set on Hard and I just realized it. Also, zero seconds ball save. I was watching Eric play on You Tube and he had ball saves, but said he was playing factory settings. What is normal Factory Settings? Just curious.
I know my factory settings were on zero seconds ball save. In the menu the adjustment title will change from green to red if they are changed from factory. I have a 3 sec ball save time because the wife will walk away pissed if it don't give her the ball back. Every location game I've played had zero ball save time.
Quoted from scottieIA:I know my factory settings were on zero seconds ball save. In the menu the adjustment title will change from green to red if they are changed from factory. I have a 3 sec ball save time because the wife will walk away pissed if it don't give her the ball back. Every location game I've played had zero ball save time.
Wow. Zero is so brutal. My DILE I believe arrived on medium so I was just curious. I will check out the red when I am in front of the machine.
Quoted from jasonbar:I don't recall where that blue stool came from, but we have a few of these & like them quite a bit. Small, fold flat, carry handle, solid, lots of fun colors:
amazon.com link »
Thanks,
-Jason
We have many of these stools as well. Any Marshall’s, TJ Maxx, Home Goods whatever. My wife gets them for $8. So worth it
I have a 10 second ball save which is generous, I know. But there were too many times when the ball came out of the pops on the first plunge to go straight to an outlane that I wanted something.
Quoted from Nokoro:I have a 10 second ball save which is generous, I know. But there were too many times when the ball came out of the pops on the first plunge to go straight to an outlane that I wanted something.
I think mine is set for 8 seconds because I want my wife and casual players to have fun and I'm not trying to earn money off the game. It's still brutal enough because there's still no ball save when you plunge after a ball lock.
Default is set to zero as many have mentioned. I have mine set for 5 seconds. I feel its the perfect timing imo.
I watched a few vids of people installing these side art blades before I started mine .Some took playfield a out ,others fought around playfield .wasnt going that route so I cut 2 2x4s to go from playfield up over railing to the bottom of cabinet on top of the steel control box .The back end of playfield underneath has room .Anyway Sorr didn’t take pics but this took me a whopping 10 minutes to do after wood was cut and in place .Used the painters tape 3 spots too n bottom did half at a time no probs at all!!
5643270B-F9F5-4B41-8678-D2BD94B30DE5 (resized).jpeg6D508107-3266-4B95-83AF-EA754E54C2B8 (resized).jpegQuoted from SLRage:10 seconds for me too. 5 may be enough though. Just wanted to avoid the straight dumps that WOZ is so famous for. Plenty hard enough still for sure!
I looked for that setting last night couldn’t find it .Any help where thats at cause my youngest gets discouraged n doesn’t want to play it I’d appreciate it .
Quoted from Kkoss24:I looked for that setting last night couldn’t find it .Any help where thats at cause my youngest gets discouraged n doesn’t want to play it I’d appreciate it .
Settings - System Settings - Ball Save Time. ( page B-24 in the manual )
Quoted from LTG:Settings - System Settings - Ball Save Time. ( page B-24 in the manual )
Thanks buddy
Quoted from Nokoro:The other thing to note is that the WOZ ball save doesn’t go away if you drain like DI or other games. It lasts for the full time you set it for. Unfortunately, I’ve had it trigger a few times in a row when I’ve been particularly unlucky.
Also, I blasted WOZ for being more difficult than Wonka thinking I had them both set on easy. Now I realize that I had WOZ on hard with no ball save. I decided to keep WOZ on hard as it felt like cheating with the 3 YBR spot, only 7 Munchkin loops, etc. However, I am keeping a 5-10 second ball save. It’s just humane! With that tweak, it is much less discouraging. Now I want to put Wonka back to factory settings as well.
Quoted from SLRage:Do not buy anything from this guy!
I replied to your email the day you sent it, I would suggest checking the spam folder. I also just sent you a PM here, which is another way you could have tried contacting us. Happy to take care of your issues, just like we do for all customers.
... I’m in Canada, I got Mods from him all in perfect condition, fast shipping and everything packed very carefully, simply a great experience, no problems at all, I recommend him 100%
Scott seems like a stand up guy to me- you should give him a chance to make it right.
Quoted from harryhoudini:I replied to your email the day you sent it, I would suggest checking the spam folder. I also just sent you a PM here, which is another way you could have tried contacting us. Happy to take care of your issues, just like we do for all customers.
Looks good, got the same coming.
Quoted from 27dnast:Installed the MOD Couple castle doors and upper playfield lantern. Nice touches to an already spectacular game![quoted image][quoted image][quoted image]
Those doors look pretty sweet! How difficult was the install? Are they simply stick-on?
Quoted from VegasAlleycat:Those doors look pretty sweet! How difficult was the install? Are they simply stick-on?
Easy install for the most part. The monkey door requires the use of a hex key. I ended up using a jeweler’s screw driver.
The rest is sticking them on.
The light, which I forgot time photo, requires cutting and removing the stock spotlight.
Nice monkey.
Hey folks, just announced a topper companion to our Throne Room mod.
https://pinside.com/pinball/forum/topic/woz-enhanced-interactive-throne-room-by-pmc
Quoted from harryhoudini:Hey folks, just announced a topper companion to our Throne Room mod.
That looks pretty awesome!
Kinda a newbie using this forum. I am trying to find any posts on installing Pin Stadium lights on my RRWOZ. When I do a search nothing pertaining to this topic shows up. Anyone with a tip for me?
Quoted from Chopper36:Kinda a newbie using this forum. I am trying to find any posts on installing Pin Stadium lights on my RRWOZ. When I do a search nothing pertaining to this topic shows up. Anyone with a tip for me?
Welcome! Go to the Pinstadium thread and do a search for "WOZ" in that thread and you should find all you need. It will be important to know if you have the 2.0 lights or not as the hookups are a little different with those. https://pinside.com/pinball/forum/topic/new-pin-stadium-lights-official-announcement?tq=woz&tu=
If you still have questions just post in that thread and Scott from Pin Stadium will be all over it, he can be over-the-top but his customer service is second to none.
Quoted from Kkoss24:playfield
Plenty of soapy water on the decal and the inner cab, obviously with the power off. No need to take the playfield out.
Here is a video i did for pinstadium on woz 2.0 ruby red
Quoted from monte_:Here is a video i did for pinstadium on woz 2.0 ruby red
Thanks a lot good video!
If you still have questions just post in that thread and Scott from Pin Stadium will be all over it, he can be over-the-top but his customer service is second to none.</blockquo
Thanks for the info much appreciated.
I'm pretty sure there is a post on how to slow the balls down coming through the ball lock behind the spinning house, but I can't find it. Anyway, the ball frequently flies off the wireform into the state fair when it comes around to fast. Best method to get it to slow down? TIA
Quoted from angus:I'm pretty sure there is a post on how to slow the balls down coming through the ball lock behind the spinning house, but I can't find it. Anyway, the ball frequently flies off the wireform into the state fair when it comes around to fast. Best method to get it to slow down? TIA
I've had that for a while, then I had to take off the wire form and put it back and never had the problem after. I guess it wasn't properly aligned or not tight enough.
Lower the flipper power.
I'll be selling my Gouveia witch mod 1.0 for $185 shipped to CONUS once Witch 2.0 arrives at my home. It's a great replacement for the witch in a tube. Mint.
I think I might have a buyer, so he gets right of first refusal. But, if you're interested, PM me and I'll let you know if he decides not to buy.
Added over 4 years ago:No longer available!
I'm about to purchase a WoZ standard edition early run. The owner said he believes light mod done. How can I tell if it's 1.1 or 2.0. Thanks for the help.
Quoted from Navystan:How can I tell if it's 1.1 or 2.0. Thanks for the help.
Look at page C-54 and page E-24 in the manual to compare. 2.0 has a bunch of ethernet cables running around, the earlier light boards don't. Picture of 2.0 below.
You can download the manual from jerseyjackpinball.com under support under downloads under WOZ.
wozcables (resized).JPGLooking for the experts. About to buy this WoZ. Owner thought previous owner installed light mod. One expert (LTG) said definitely not 2.0. Can anyone tell if 1.1? The actual boards say 1.0. If not, I'm up for the challenge of upgrading to 2.0. JJP site says not in stock for 2.0 light mod. Do they still sell?
Thanks.
Quoted from Navystan:Looking for the experts. About to buy this WoZ. Owner thought previous owner installed light mod. One expert (LTG) said definitely not 2.0. Can anyone tell if 1.1? The actual boards say 1.0. If not, I'm up for the challenge of upgrading to 2.0. JJP site says not in stock for 2.0 light mod. Do they still sell?
Thanks.
Looks like regular 7.5v system to me. The downloadable manual shows the differences.
Mine has been rock solid for years now. If it works, dont fix it.
Im not a fan of the 2.0 system until they sort out the dim GI lights on it with a code update, then maybe.
It is absolutely not 2.0 but the picture is too blurry to see any detail of what's on the boards to see if it's 7.5 buffered or not.
Thanks.
I back what he said no need to change ,actually there’s a set for sale now on pinside I think it’s $300 snatch it up if you have 7.5.I grabbed a set piece of mind .
Quoted from pinballinreno:Looks like regular 7.5v system to me. The downloadable manual shows the differences.
I don’t think that code update is ever coming.
Quoted from Kkoss24:I back what he said no need to change ,actually there’s a set for sale now on pinside I think it’s $300 snatch it up if you have 7.5.I grabbed a set piece of mind .
Ahsolutely!
I have a couple sets lol.
So im good for a very long time...
I get that but i wouldnt be a fan of my lights not working in the future..
This page was printed from https://pinside.com/pinball/forum/topic/woz-fan-club-members-only/page/220 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
