(Topic ID: 87617)
WOZ Fan Club - members only
By TigerLaw
6 years ago
  • 10,859 posts
  • 564 Pinsiders participating
  • Latest reply 3 hours ago by Kkoss24
  • Topic is favorited by 256 Pinsiders
There have been 1,486 images uploaded to this topic. (View topic image gallery).
8 key posts have been marked in this topic (Show topic index)
There are 10859 posts in this topic. You are on page 217 of 218.
#10801 12 days ago
Whoops thanks Lloyd. Must have forgotten them during the build somehow. I'll contact support and see how I go.
#10802 12 days ago
Quoted from Kkoss24:
I’m going to try the glue fix .I was pushing in it and started changing colors ...then if fails I’ll have to decide .I have heard the 2.0 subpar to the 7.5 any thoughts on this .I appreciate u guys thanks !
The GIs on 2.0 are less bright, I would actually say obscure compared to the 7,5v. It's clearly a drawback. JJP said they will come up with a software fix but we haven't seen it yet.
But the added reliability is a no brainer to me, I switched to 2.0 when I was either buying the Tin man board for 300$ or getting the 2.0 full kit for 800. I also was tired of praying for the pinball to lit up everytime I was turning it on or lifting the playfield to diagnose a dead light and replace it.
So the benefit of the 2.0 is quite unmatchable IMO.
#10803 12 days ago
Has anyone tried repairing non-2.0 boards when they go bad?
#10804 12 days ago
Quoted from hlaj78:
I re-soldered / re-flowed several but it was always just a temporary reprieve. I thought about replacing the actual LED but I don't think that's what fails and the driver chip is apparently obsolete / unavailable so I never even tried to find one to attempt a replacement.
#10805 12 days ago
Quoted from adol75:
Thanks ,since it still works as should (just NB stay red) I’m going to keep looking if anyone is selling they’re 7.5 sets that upgraded to 2.0 .lmk I’m interested in purchasing the rainbow only will decide later which way to go depending on the previously stated software fix with the 2.0
#10806 10 days ago
I’m having a weird new problem with our EC. I installed the Pinball Mods witch and now the witch melted optical switch 23 and oddly Throne room VUK optical switch aren’t working.
I plugged them into different locations on their respective board and they worked. So it seems like there is a problem at the board. It seems odd because they are different optical boards and not related to the witch at all.
So, could two separate optical boards just go bad all of a sudden at the exact same time?
Could the mod be messing up something? Although I can’t figure out what.
Or could it be a power issue? I read that some people suggest using an external dedicated paper supply in JJP games cause the power supply is finicky if you start adding mods. Have other people had issues adding mods? I have quite a few mods and have daisy chained a bunch of power leads into the factory harness.
Any thoughts?
#10807 10 days ago
Quoted from Nugilo92:
Any thoughts?
The question would be did you have these issues before adding these pinball witch mods? If not, can you go Back to the way the game was to see if the issue is resolved. Would definitely answer the question, is it the last thing I did.
#10808 10 days ago
Any thoughts?
Both are on the same row and have white/blue wire in common, trace that wire everywhere it goes and make sure it's not broken, my bet is that it is.
#10809 10 days ago
I have the certificate in there slot on the apron but it’s black on the right side of the apron. Has anyone made any custom cars
#10810 8 days ago
I just joined the club and have the Emerald City edition. The issue I’m havingis when the monkey flies down to grab the ball he hangs on to it. I b assume once he gets up top he drops it right way in the castle. My monkey will hold it until it goes into ball search then he releases it. Any ideas?
#10811 8 days ago
Quoted from Yesh23:
Balls magnetized?
#10812 8 days ago
Quoted from Yesh23:
I have that sometimes. My monkey releases the ball when I hit the flipper buttons
#10813 8 days ago
Quoted from Yesh23:
Yup. Put a piece of black electricians tape on the traveling monkey magnet pole. It's become magnetized. This is an easy fix.
#10814 8 days ago
Quoted from adol75:
Mine is the same way. Why would hitting the flipper button make the monkey drop the ball? Doesn't seem like nearly enough vibration.
Also, as long as we're talking magnets, my Glinda and Dorothy magnet under the house exit sometimes doesn't activate properly. For example, sometimes after saving the ball via completing TNPLH, the ball will just keep rolling after dropping through the spinning house exit hole. Not always, just sometimes. Any idea why?
#10815 8 days ago
Quoted from pinheadpierre:
The traveling monkey magnet pole is magnetized. Hitting a flipper button is enough to make him drop the ball.
#10816 8 days ago
Quoted from LTG:
I don't understand where you put the tape. Do you roll it around the whole pole and leave it there ?
#10817 8 days ago
i think between ball and magnet!
#10818 8 days ago
Watch the ball as it exits. Does it drop in the same place each time, or does it sometimes get dropped a bit to the left? If the latter, this is an issue with how that upper playfield is leveled. You can tighten the nut on the right hand side that holds the playfield to the support posts, or loosen the nuts on the left just a bit. This will tilt the playfield slightly more to the right, making the ball more consistently land where it is supposed to and be caught by the magnet.
#10819 8 days ago
The electrical tape worked awesome.
#10820 8 days ago
Does anyone know what volt the 2 spotlight bulbs are? I’m thinking 13 volt because I put a 6.3 volt bulb in there and it started smoking. If it’s a 13 volt I should be able to but an 8 way Comet flashes in there to brighten up the playfield
#10821 8 days ago
Quoted from Yesh23:
They are 12v leds
#10822 8 days ago
So a Comet 12 volt flasher should work?
#10823 8 days ago
Quoted from adol75:
Right across the top of the pole in the magnet.
#10824 8 days ago
Quoted from Yesh23:
It should.
#10825 6 days ago
Hey gang,
Looking for a WOZ Standard or an Emerald City with the 7.5 boards, if anyone was thinking about selling theirs.
Thanks,
Ted
#10826 6 days ago
Quoted from teddyb73:
Hey gang,
Thanks,
Ted
Not sure which light boards but worth inquiring:
HUO - Documented (Home Used Only) “• Wizard of Oz Emerald City STANDARD Edition #158 of 1000 with Invisiglass - 3/12/14 Build. Original owner. low plays - looks like it was taken out of the box yesterday. Not a s...”
16 days ago
Saint James, NY
7,700
#10827 6 days ago
Also
HUO - Undocumented (Home Used Only) “Woz emerald City le Everything works as it should. Pm me with any questions.”
28 days ago
Escondido, CA
7,500
#10828 6 days ago
This guy wants $7000 and you have to move it out of his basement on Long Island NY and he has a spiral staircase.
and he also stated once you break it down and start moving it you're liable for anything that happens going up the spiral staircase. What a joke.
#10829 6 days ago
I wish the guy in New York wasn't a butthead with me moving it out of his basement with a spiral staircase. Unfortunately California is too far. But thanks.
#10830 6 days ago
Wait a sec...I have a spiral staircase to my basement but I also have a Bilco entrance. This guy doesn't have any Bilco entrance to his basement? That's a really dickish design for a house. How can you get anything up and down?
Here's an idea for you: Offer him $7200 and tell him he has to move it up the stairs and he's liable for any damage, and it's a deal. If nobody else feels like schlepping the machine up the stairs with his stupid proviso, I bet he circles back to you and takes the deal.
#10831 6 days ago
If the seller will pallet, STI has been pretty good for me so far. My WOZ came from TN->TX via STI.
#10832 6 days ago
$7200 is to much for a standard. $6500-$6800
#10833 6 days ago
Man I’m having a hard time removing back glass to access the back box , don’t u just turn the key and lift the translite up ? It doesn’t even budge any help ?
#10834 6 days ago
Quoted from Oneangrymo:
Probably just stuck to the paint. As my father used to say, jiggle it a little.
Oh and my key is horizontal when it is unlocked.
Or you could get a hammer!
#10835 6 days ago
To where?
#10836 5 days ago
Mine is Also very tight.
The slot on early runs was a little narrow, so they forced the glass in with a block of wood and a mallet.
Repeatedly smacking the glass very firmly with palms, in an upward motion got it out.
Hammering with a block of wood and a plastic hammer on the trim channel got it back down.
I probably should have relieved the rear edge of the slot a bit with a file, but i didn't do it yet.
#10837 5 days ago
Quoted from pinballinreno:
Ugh, I wont mess with it , I was hoping to put some led around the trim to make backglass pop more, but I have a feeling all im going to do is break the glass.
#10838 5 days ago
The glass is pretty strong.
But yeah, it thakes a but of beating it up to get it out.
#10839 3 days ago
Having a small issue with the Bilbo ramp entrance. Upon turning the machine on getting switch closed error. Long story short if I move the wiring close to the OPTO IQ Board the switch opens and closes. So issues appears to be close to the connector and not the optos. Anyone have this issue before?
#10840 3 days ago
Quoted from meSz:
I haven't had any issues with the bilbo ramp in my woz.
#10841 3 days ago
Quoted from meSz:
I just finished changing 2 optos,under the spinning house. I had a check switch 12 and 13, house cannot find home. Bad part, had to pull the munchkin playfield. Good, is it fixed it. If you have switch errors on an opto, check it out. You can order them from JJP. Yours sounds like something is loose, though.
#10842 3 days ago
Quoted from jorant:
Only certain WOZs built after December 2017 came with the bilbo ramp. It was the special Smaug Emerald edition.
#10843 3 days ago
Quoted from HIPPY:
Yeah I reseated the connector to no avail.
And apologies as I posted in wrong thread.
#10844 3 days ago
Quoted from meSz:
We know. We’re just giving you a hard time in a friendly way.
#10845 3 days ago
Quoted from Nokoro:
I GOT FEELINGS DAMN IT
#10846 3 days ago
Highly recommend pingraffiz blades for woz got one done already looks
Amazing
#10847 1 day ago
So, I posted a while back about several problems I had with our ruby red we got last october. Round 2of the WOZ demon, went to turn on the pin this eve, hums, and no boot. Took off back glass, red lights on board, no fuses blown, now what...... Checked fuse on power supply, all good. even change outlets on the wall, nothing. Any thoughts on what to look for? Just want this thing to work 100% for once........
Mike
#10849 1 day ago
I've had this happen on a couple of pins. Either it is getting stuck to the paint, the trim doesn't fit well, the lock isn't turning properly, or there is some type of debris blocking it.
Make sure the key fully turns. You can use graphite if it isn't.
Try gently sliding one side of the BG upwards, and then try the other side.
You can also try sliding the BG left or right...very gently, of course.
If it is debris, you can take a hand-vac and go around the edges to suck up any wood, glass, etc.
#10850 1 day ago
Thank you for the video!! I will try this tomorrow. Not going to lie, little nervous about shoving a paper clip in a powered board!!! Ill let you know if this fixes the problem.
Mike
$ 16.95
7,500
Escondido, CA
