(Topic ID: 87617)
WOZ Fan Club - members only
By TigerLaw
6 years ago
  • 12,220 posts
  • 611 Pinsiders participating
  • Latest reply 17 hours ago by Oneangrymo
  • Topic is favorited by 284 Pinsiders
There have been 1,697 images uploaded to this topic. (View topic image gallery).
9 key posts have been marked in this topic (Show topic index)
There are 12220 posts in this topic. You are on page 192 of 245.
#9551 1 year ago
Thanks Dash...
I think it’s a code problem - balls seems fine, I just think the disabling the magnet During multi ball would eliminate this.
I have had the capture arrow lit and left orbit did not activate monkey on a couple of occasions - I’ll hit right orbit in next shot and magnet comes on and monkey captures ball. (I’ll retest the top left switch again)
I tried this - it’s so tight, the ball guide actually cuts the new rubber in half - I just moved the post to the back and play better.
#9552 1 year ago
I have an issue once in a while where my ball gets stuck under the munchkin playfield. I cant see what it gets hung up on. A little rocking of the machine back and forth sets it free... Anyone have any ideas?
#9553 1 year ago
Quoted from Rager170:
Same here. I just nudge it out. It frustrates my 5 year old though as he’s not strong enough to nudge it out. Happens fairly frequently.
#9554 1 year ago
Might have some debri or bad rubber under the PF? I have the rare occurance of this as well but a slight nudge gets it going again. Maybe it's time to remove the Munchkin PF and take look.
#9555 1 year ago
Quoted from Sciddleybop1980:
Quoted from drained:
Yup, a quick nudge does it. I wasnt sure if anyone knew what exactly is making it get stuck.
I will probably take off the playfield at some point to take a look. I have a cliffy to install so timing is good.. whenever i have actual time to do it ha.
#9556 1 year ago
Probably getting stuck where the ball is returned after going through the OZ lanes. The area below the OZ lanes doesn't have mylar but where it rejoins the orbit there is mylar. This results is a 'ball trap' when a ball plunged lightly enough doesn't have enough momentum to overcome the mylar ridge. I have this happen all the time and it is an annoyance for sure. I reach up and shake the machine up near where the ball is stuck to clear it. If you can get to the side of your machine near the back box and look it is fairly easy to see the ball just sitting there waiting for your nudge to get it rolling again.
I have seen a fix for this (probably in this thread) where mylar was applied below the OZ lanes area, effectively eliminating the lip. It looks like it would be difficult to do a nice job of this without one of those craft cutters. BTW if someone is willing to do make some mylar that fits this area, count me as your first customer.
#9558 1 year ago
Quoted from fnosm:
Yup, thats exactly the area... annoying ha.
#9559 1 year ago
Quoted from mjs2:
Thanks Dash...
There’s an opto under the castle on the left orbit. Did you test if it registers well ?
#9560 1 year ago
Quoted from adol75:
Good call, the optos pop out sometimes and is a super easy fix to pop them back in.
#9561 1 year ago
Then roll a ball through slowly, or stop at various points to see where it actually stops. You may have to adjust lane guides or something.
Disclaimer : Adjust is a code word for bend the darn thing.
#9562 1 year ago
Quoted from LTG:
lol thanks LTG!
#9563 1 year ago
Quoted from adol75:
I’ll try that this weekend. Thx!
#9564 1 year ago
Under munchkin playfield ball hang:
There is a rubber under it near the top edge.
If it slips up and out of its post notch it causes the ball hang.
You can reach it without tools.
It's just below the upper sling.
Just roll it back down.
You will see that it up hugging the top. It should be lower onto its notch
#9565 1 year ago
Quoted from pinballinreno:
There is a rubber under it near the top.
Thanks! I will take a look for this as well.
#9566 1 year ago
Quoted from mjs2:
In the last 20 games I have had 2 balls get stuck on the magnet directly below the munchkin Playfiled drop hole during multi ball. M
This was happening to me as well. The cause was kind of rare. There is a small piece of mylar underneath the munchkin hole - in my case a corner of it was lifting and sticking straight up some and would block balls at times. Repaired it and no problem since.
#9567 1 year ago
Quoted from fnosm:
I thought it was the mylar edge, but mine is perfect.
Its true that a failed mylar would do this.
But in most cases it's a slipped rubber.
It's the rubber to the left of the mylar, and up a little to the left.
It's a little hidden, and hard to notice unless you know what you are looking at.
It slips up off its notch.
This makes a little corner that the ball can rest in.
Action from the sling does it.
I have had to slip it back down a couple times now.
#9568 1 year ago
I will check this tonight. Thanks for the tip.
#9569 1 year ago
Quoted from pinheadpierre:
I’d like to make a switch controlled illuminated winkie target. I’ve got all the parts I think I need but, being more of a visual artist than an electronics tech, need some wiring advice. I’m thinking I make a molex splitter to tap into the 12v from the castle spotlight. After that, I’m thinking that the neutral wire goes to one leg of the new bulb socket while the positive wire goes through the micro switch and then to the other leg of the new lamp socket. Could someone please confirm or correct my wiring logic? Also, is there any need for a diode on the switch wiring? I’m thinking not but am unsure.
Never mind. I decided to trust my own thinking. What I described works.
#9570 1 year ago
That wiring will work if you are adding a new switch somewhere and you are using a 12V LED or bulb, where/how do you plan to install the new switch?
#9571 1 year ago
Quoted from bobukcat:
Thanks, already done. I got longer #2 screws and mounted a secondary micro switch to the same mount as the factory drop target switch.
This was the last step in my post-2.0 conversion to get my lighting all modded. I went full diy on trough lighting, stadium lighting, balloon pop and winky target. I pulled off the spotlights and other stuff I experimented with. I just really didn’t like the uneven hot spots and visual obstruction of the spots and such.
I put the stadium lights on three separate controllers (1 for the rear, 1 for the sides and 1 for the trough) to control color and brightness independently. I also stopped the right side stadium lights short of the huts to avoid over lighting that area, especially the hut roofs. I’m happy with the results. (The rear of the game actually doesn’t look that blue/purple in person. That’s an odd artifact of the photo.)
I can now play in a dark room!
#9572 1 year ago
Mine does this when the balls get a little magnetized. Replacing the balls seems to help.
#9573 1 year ago
When the ball gets hung up under the munchkin playfield, it could mean that the upper slingshot rubber is broken.
#9574 1 year ago
I am a newer woz owner, got a ECLE edition in a trade deal about a month ago..
Anyone have the issue with the monkey not dropping the ball in the castle? With the original set of balls only 1 of the 5 balls would fall without me having to double flip the flippers for the mag to drop the ball. After checking all the switches I replaced the balls, 4 of the 5 balls would drop properly. I am using carbon core balls and now its happening more frequently.. didn't take long. Guess my monkey mag core is a little to strong/polarized..?
I ran across a thread mentioning placing electrical tape on the mag?
#9575 1 year ago
FYI - Just put an order in for 2 sets of carbon balls from ball Barron. They seem to have them back in stock now if anyone interested.
M
#9576 1 year ago
You can de-magnetize balls by heating in an oven at 350-400 degrees for 45 mins.
Let them cool naturally.
#9577 1 year ago
You can magnetize balls by heating in an oven at 350-400 degrees for 45 mins.
What a great trick! I’ll have to give this a try next time I get sticky balls...pinballs, that is.
#9578 1 year ago
That’s what I did. Worked faultlessly now for months
#9579 1 year ago
Wow! Never knew that.
#9580 1 year ago
Wow really? Thats pretty awesome to know then...
#9581 1 year ago
The "curie temperature" to lose all magnetism is around 1060 degrees (cook on bbq for 25 mins over direct coals).
But magnetism drops off sharply at 212 degrees (boiling water for 15mins).
350-400 degrees yields good results for pinball.
Practically all magnetism is gone.
#9582 1 year ago
Great info! You have just made many people's day!
#9583 1 year ago
Im having a problem with my Winkie Target going down when it is supposed to. I can hear it clicking as the coil is firing but it doesnt drop. I feel like it happens on and off.
Any help is appreciated.
#9584 1 year ago
Can you confirm the coil is actually firing? Perhaps try in coil test mode with the playfield up so you can see.
If so, then it is likely something mechanical. Check it over and see if anything is catching. Is the spring intact? Etc.
#9585 1 year ago
Quoted from Nokoro:
Yea its firing. I can hear it clicking when its trying to lower the target during game play. During test, I can hear it firing as well.
The spring is attached because it goes down just fine when playing and the ball hits it. Its only when the game tries to lower it with a coil that it doesnt go down as it should.
To be honest, im not sure when the target is supposed to go down on its own haha. Its not even a big issue.. I dont think.
#9586 1 year ago
Ok. Next make sure it raises and goes down on its own in coil test mode. If it doesn’t go down in coil test mode, but the coil is definitely firing, then there is something wrong with the mechanical connection. I believe the coil triggers a little arm that pushes the drop target back causing it to fall, but I can’t look right now to make sure. You should be able to see the mechanism.
#9587 1 year ago
Quoted from Nokoro:
Yup, thats what happens. I havent had a chance to really look at it. Wasnt sure if anyone had this issue in the past.
Thanks for the help...
#9588 1 year ago
Check the switch alignment.
Check the screws on the switch.
Check the spring.
#9589 1 year ago
I made a trial today.
Had 4 balls severely magnetized.
20 min in an aluminium sheet in the embers in the stove.
Balls are completely normal now except one thing..
#9590 1 year ago
Quoted from BENETNATH:
Balls are completely normal now except one thing..[quoted image]
That is cool! Are you gonna start making these ? I'll take a set.
#9591 1 year ago
That ain’t right lol
#9592 1 year ago
Quoted from fnosm:
As long as it's winter, production can go smoothly ^^
#9593 1 year ago
Clean/dewax them before cooking, or the wax and grease will get dark.
Degrease them and Run them in a tumbler
They will shine up. They're steel.
A little experimentation with time and temperature.
I just bake them at 350f for 30 mins after cleaning with brake cleaner and lacquer thinner to dewax them.
Then run them thru my vibratory tumbler for 3 days.
They come out fine.
#9594 1 year ago
#9595 1 year ago
I did the ball cooking last night, grabbed my rather large collection of magnitized balls out of the closet, worked great. Very happy with this solution, saving $$, the balls were in great condition physically. Mine came out looking like how they went in.. but I tend to rarely use wax.
#9596 1 year ago
Direct flame was surely not the best idea
#9597 1 year ago
My Rainbow targets have decided to go dark. I've checked the connections and they seem good. Theres a grin light under the plastic that is on, but the LED's are not functioning. Any thoughts? Thanks all.
#9598 1 year ago
Quoted from billycrna:
Any thoughts?
W10 LED board failed. ( if you don't have the 2.0 LED boards. )
#9599 1 year ago
Quoted from LTG:
Before I order a new one, Could this be a fuse? Also, I just received and replaced the single LED under the cowardly Lion rollover and the new LED is not the same color as the rest of the play field. Is that just the way it is, or is there something that I need to do? thank you!
#9600 1 year ago
No.
W10 is the end of the data chain. If the LED board before it works. Then W10 is bad.
Could be an issue with the data harness or loose connector on the LED board. Or bad new board ?
