You are thinking SWOTRB.
Gotcha...thought so. With how hard TNPLH is, there should be a last completed initials spot for that too! HAHA!
anyone else have issues with the trough opto boards? Game wasn't recognizing a drain. Seems like it might be a flaky connector. If so is there a way to make the connectors more stable? Hack glue? oops, meant hot glue.
Last night I completed TOTO save #3 for the first time, 3 shots, hit the 3rd one(crystal ball) just a millesecond before the flippers cut out, in fact the screen animation was already saying too late, then the ball fell in the hole and Toto escaped, what an awesome feeling!!
It's looks a little like mine around the winkie but mine's not as bad. it's more of a chipping than wearing down. You need to dial down the pops a bit and repair any damage like this pronto. Then cover with a protective -I had nothing else but Gorilla tape but it worked.
Mine was built July 2013. I don't know if this is in the timeframe
Of games made by the original supplier which JJP seems to think had an inferior process than what they currently use.
Quoted from TaylorVA:
I would check with JJP to see if it was one of those PF's from the problematic mfg.
Quoted from arcadenerd925:
It was.
Mine was August 2014 and I got the chipping. No chipping over the wood part but the plastic might have adhesion problems. The plastic diamond near the winkie was painted to look like a diamond but is much larger when view from the underside. Also the ball comes to a quick stop with the winkie up and you get some digging in kind of like the Shadow santum . I fixed it and you really can't tell but you ought to be aware of it - shine a light on the area and look for bubbling.
As I have been looking into what my next pin will be, I've been reading quite a bit about WoZ, and I remember reading somewhere that folks were looking for the rules for WoZ. Not sure if someone has already posted it, but they have a rule sheet up at PAPA. http://papa.org/2015/05/18/wizard-of-oz-rulesheet/
Quoted from Blu:
Thanks for posting. What is the contact to give them feedback on things that are incomplete?
Quoted from DCFAN:
Not sure. I'm not affiliated with them, but on their site is a contact us. I'd assume you'd use this link. http://papa.org/about-papa/contact-us/
I wonder if the strategy is actually very simple because of the stackability. That is, maybe the strategy is as straightforward as:
1) Stack everything (Emerald City, Rescue, Fireball, Muchkin, Crystal Ball, Haunted Forest)
2) Don't drain
This may be more of a theoretical exercise than a practical strategy, but I wonder if it really is possible to stack everything listed above.
when a ball gets locked behind the Winkie drop target should the drop target go down in ball search? Just had this happen and it never lowered the target.
ALL stacks are possible outside of the Wicked Witch Battle. Best stack I've had was Emerald City + Flipper Frenzy + Haunted Multiball + Munchkin Multiball. BIG POINTS.
I've said this before, but there are so many strategies. Lately I've been playing solely for bonus. Starting Emerald City with either Lights On or Off, then starting either Munchkin Frenzy or Welcome to Munchkinland can rack up a TON of points. For Munchkinland I'll do nothing but hit the ramp over and over with 2-3 balls cycling at all times. In frenzy I go for the pops. Easily 100,000+ for either of those modes with the crystal ball multiplier. Add in the HOADC multipliers for bonus and everything soars. Best bonus has been around 820,000. Still shooting for 1 million.
I've been meaning to get to a strategy video but time has been short. Someday...
Quoted from TKDalumni:
Wish papa would do a strategy vid of OZ...
Checkout pinballvideos which aggregates the papa videos. Then check out the Papa Live episode for WOZ.
Quoted from Skypilot:
Coming late to the party. I just order a 75th annaversary WOZ from Gary at Abel. I can't wait for its arrival.
Congrats, it's an awesome machine!
Quoted from btw75:
Link?
Regarding the WOZ rulesheet at papa:
Quoted from DCFAN:
I wrote the first draft... you can contact me here or at tiesmasc at yahoo dot com
Definitely need the help!!!
The drop target should go down in ball search. I was doing some glass off checking of the Haunted rules (see other thread https://pinside.com/pinball/forum/topic/wizard-of-oz-rulesheet-2#post-2462369 ) and saw that the drop target does go down when ball search is cycling . There is a small second coil on the drop target mechanism that causes the target to drop.
Quoted from DCFAN:
I was playing a game on WOZ the other night. The ball got stuck behind the drop target. The game went into ball search....the drop target never dropped. I had to shut the game off, remove the PF glass, and remove the ball myself.
I think JJP should do a software update that will make the drop target drop during ball searches.
My machine drops the target during ball search. It clears a ball stuck behind it. Perhaps there is a minor misadjustment on your machine.
Quoted from indypinhead:
Is your software from the last couple versions?
Also, you may want to go into coil test while the Winkie target is up and test the coil to see if it is working to make the target drop.
Quoted from TZBen:
whats your strategy for shooting the behind the flipper shot for horse of a different color?
I usually do not do it on purpose. I don't see it as valuable enough to warrant the risk.
Quoted from DCFAN:
It's EXTREMELY valuable if you did well on a munchkin mode that ball. WELL worth getting.
Quoted from Pimp77:
Are you saying the horse of a different color behind flipper shot factors into the end of ball bonus?
Quoted from DCFAN:
Yes. It multiplies your munchkin mode scores (add 0.5 multiplier for every successful HOADC completion).
It has to be on the same ball though.
are you shooting it by holding the right flipper and shooting it with a left cradle and trapping it into the lane? or by some kind of backhand shenanigans. I do it mostly by luck when i'm doing a multiball cradle.
Quoted from TZBen:
I tend to backhand it from the right flipper. If the ball rolls up the flipper just right, I'll shoot it. But it is dangerous to shoot at. More often than not, horses lead to drains for me.
Quoted from Pimp77:
If I'm remembering correctly, there's actually a whole table full of possible multipliers based on your collection of horses. I want to say up to like 6x for 3 different non-rainbow horses, plus a cow. I still don't ever shoot at it on purpose. I'm playing for progression first, points second.
Edit: No, I was wrong, the multiplier I was thinking of was for the HOADC cashout score. Here's the rules for the Munchkin multiplier.
+ Munchkin Multiplier: Now, when successfully completing a HOADC level, you
are awarded a Munchkin Multiplier which affects any and all Munchkin modes
you played that ball. Winning a 4-horse level adds .5x; 5-horse 1x; 6-horse
1.5x; and 7-horse 2x. The maximum is 10x. Remember this is scored at end
of ball bonus now.
Quoted from herg:
Edit: No, I was wrong, the multiplier I was thinking of was for the HOADC cashout score. Here's the rules for the Munchkin multiplier.+ Munchkin Multiplier: Now, when successfully completing a HOADC level, you
of ball bonus now.
I am confused by the horse thing. I thought the bottom left of the screen only went up to 5 horses/cows. How do you get 6 or 7 horses?
Quoted from DCFAN:
After each successful HOADC collect, the next one increases the number of horses you have to collect.
Quoted from chasosaur:
Horse of a Different Color
* Hit four horses then shoot the COLLECT under the right center field flipper which drops the ball back into the plunger.
* Points Breakdown (Taken again from a Buckaroo65 post… Thanks!)
Cow (White): 500 points
Rainbow (RB): 400 points
Red: 350 points
Orange: 300 points
Yellow: 250 points
Green: 200 points
Blue: 150 points
Violet: 100 points
* Add these values up, and then multiply the total based on the following conditions
Success – Each horse is a different color or all horses are the same color
Multiplier: # of horses (4 - 7)
Raises the # of horses to collect the next round. Maximum is 7
Failure – At least two different colors and at least two horses with the same color
Multiplier: 0.5
Decreases the # of horses to collect the next round. Minimum is 4
Rainbow Horse – Acts like a wild card, and is always different from any other horse
Multiplier: 0.5
All One Color – Still counts as Success
Multiplier: 3
All Rainbows – Still counts as Success
Multiplier: 5
*Horse lights are relit and randomized at the top lane (OZ) slingshot
*Scoring Examples
4 RB: 32,000 = (400 + 400 + 400 + 400) * 4 (Success) * 5 (All Rainbows)
Y, G, B, V: 2,800 = (250 + 200 + 150 + 100) * 4 (Success)
Y, G, B, RB: 2,000 = (250 + 200 + 150 + 400) * 4 (Success) * 0.5 (Rainbow)
Y, B, V, V: 300 = (250 + 150 + 100 + 100) * 0.5 (Failure)
V, V, G, RB: 200 = (100 + 100 + 200 + 400) * 0.5 (Failure) * 0.5 (Rainbow)
Quoted from DCFAN:
I don't know what there is to be confused about.
Quoted from herg:
Thanks, that clarifies it for me.
That is what I was confused about. I did not know the collect was how the number of horses increased.
Quoted from btw75:
http://pinballvideos.com/?m=oz
pick papa.tv live
Thanks! Pretty much everything i figured
Quoted from DCFAN:
Sorry if the joke didn't come across. I was being sarcastic since I think the HOADC rules are one of the most complicated set of rules I've come across in pinball.
ok i think im going to join the club, who has them at the best price? I was going to get a standard with shaker, am I correct the rest of the models are just more bling? I wont miss any playing features if I get the standard right?. They look to be $8000 for standard, if you know of anything better, maybe a free shaker etc, please chime in. thanks for any advice. (besides my house and car ive never bought anything so damn expensive in my life, what am i doing, this is sick???
Yes, you are sick. Welcome. You are correct that the only differences are bling: backglass, topper, armor, wire ramps. The game play is identical across all editions aside from the shaker that you mentioned, which is standard in some editions.
I think the main obstacle for Kahanaohana getting a used Woz is an address in Hawaii. How would that even work?
Quoted from nosro:
you can throw anything on the barge, weight doesnt matter. Its about $150 for a pin to be shipped and I get it from dock. we have 6 so far, not too hard.
My WOZ RR 75th Anniversary arrived today (#680)!! What a beauty!! All my wife and I can say is WOW!! What a light show
We went over everything upon setting it up, everything stayed tight through shipping. Played like a champ from the get go!! The topper was cracked, but there's no room for it anyways, so I'll get that exchanged soon. No biggie!
Well, i'm heading back to play some more, have a fun evening folks
