(Topic ID: 87617)
WOZ Fan Club - members only
By TigerLaw
5 years ago
  • 8,651 posts
  • 500 Pinsiders participating
  • Latest reply 59 minutes ago by Nokoro
  • Topic is favorited by 228 Pinsiders
There have been 1,154 images uploaded to this topic. (View topic image gallery).
8 key posts have been marked in this topic (Show topic index)
There are 8651 posts in this topic. You are on page 159 of 174.
#7901 60 days ago
Quoted from Nokoro:
Yes, you can diagnose the boards using the method in the manual and figure out which are bad. JJP can sell you the older boards. Or, you can find someone who recently did the 2.0 conversion and buy their old boards off of them assuming they are working. Depending upon how many are out on your game, the latter might be cheaper as buying the individual boards can be expensive.
My 2 cents, just do the conversion. It will take 12 hours plus or minus, but you can spread it out over many days and do it in chunks so it is more manageable. I wouldn’t waste your money on buying replacement 1.0 boards if your are ultimately going to convert.
What's the difficulty rating on doing the 2.0 install? Is it pretty straight forward, just time consuming?
Does the JJP instructions cover everything? And drilling into the pf required?
#7902 60 days ago
Quoted from WizardsCastle:
I’m not terribly mechanically inclined, and I was terrified of it, but it is not that bad. You do have to drill new pilot holes on the underside of the playfield, which is just a scary concept, but again not that bad. The JJP instructions are excellent and take you through it step by step. The early instructions had some places that needed clarity. My understanding is that they’ve revised them, but I’m not sure which set of instructions you have. Regardless, there is an excellent thread that gives tips and clarifies the instructions, and you can pose questions there. It is:
https://pinside.com/pinball/forum/topic/has-anyone-installed-woz-20-yet-im-about-too-
There are a bunch of us who have done it and are happy to help.
#7903 60 days ago
Well guys I was playing my WOZ today and a board definitely went out. I can't remember the process of skipping /bridging a light board to find which one is the culprit. I would LOVE any guidance. thank you!
See below I have highlighted the only working lights.
#7904 60 days ago
Quoted from Soulrider911:
This should help you :
Please check out page C-54 in the manual ( you can download it at jerseyjackpinball.com ) that page shows the data harness path. From W6 to #29, to #1, to #2, to #3, etc. etc.
Please go into Tests - LEDs - All LEDs, this turns any working all white. Lift playfield and lean on backbox. You can see the working ones kind of glow.
They are wired in series, a straight line. Find the last working one, the one after it that is out is the bad one. With the power on, you can by pass the data harnesses on the LED boards, bypass the bad one, and turn off in settings. ( be sure and turn it back on when you replace it ) this will help you identify a bad one.
As an example, say #15 was out. You can run the data harness from red on W2, to green on #16 instead of #15. If the rest light up, you know #15 is the bad one.
With the power on you can move data harnesses. They go red to green from board to board. Don't mess with the power connectors with the power on.
#7905 60 days ago
See below I have highlighted the only working lights.[quoted image][quoted image]
Move the data harness between 4 and 5 to 4 and 6, I think 5 is your dead one.
#7906 60 days ago
Quoted from adol75:
W6 is on, and maybe #29. So #1 is probably bad.
#7907 60 days ago
Quoted from LTG:
Darn it, I was trying to show how Obi-Wan has taught me well, but I’ve failed !
#7908 60 days ago
Quoted from adol75:
You did good. You got him in the right neighborhood.
#7909 60 days ago
Thank you so much folks I will try this shortly
#7910 60 days ago
Ok so the last light lit in the chain appears to be 3. SO, I bypassed 4 directly to 5? now how do I disable it... as nothing has yet happened? Cheers
#7911 60 days ago
In Game Settings - don't do it yet if nothing improved. Disable after you know the number on the bad board(s) you bypassed.
Then to #6, then to #7, then to #8 - etc. etc. You may have more than one bad board.
Grab the long harness from W1 yellow brick road board to TOTO lights, to help you sort this out if data harnesses won't reach.
#7912 60 days ago
ok i think i follow so if 3 is the last good one just keep branching off that to others in the series, i tried to 6 nothing so ill keep going
Its not possible this could be a fuse issue right?
#7913 60 days ago
Ok i tried 5, 6,7,8... when I connected to 5 got a quick little blink and out... the rest nothing... then I noticed this... crazy frayed ends on the W2 Connector, this can not be good ... I mean all the leads are touching, but it actually looks like a few of the longer connectors are just like this one? ltg
#7914 60 days ago
Ok I tried going from 2 to 5 and skipping 4, which actually was a working light, and we got more lights on... but still tons out in the lower playfield area
#7915 60 days ago
Best, easiest way to replace winky target?
Just unscrew the whole popper from playfield.
Winky broken....
#7916 60 days ago
You might have more than a few boards out. Check them one at a time.
#7917 60 days ago
ok think i found them ... 3,4 and 12 appear to all be bad so going to order replacements, where do I order them? thank you so much for the help ltg
and im having a hard time finding the part number? Is it 15-0008-03, 15-0008-04, 15-0008-12....?
#7919 60 days ago
Thank you ordered 4 got a spare it seems the little GI ones are the most common to go out?
#7920 60 days ago
Joined the club today! Picked up a 75th Anniversary Ruby Red WOZ. This one was on location and had a LOT of plays, but overall works very well... needs a good deep cleaning tho! Looking forward to giving it a polish and rebuilding a few of the flippers and mechs.
#7921 60 days ago
Yup
#7922 59 days ago
Quoted from Ericpinballfan:
Winky broken....
Yes, disconnect one of the wires to get access
4 screws, one of them you need a magnetized screwdriver. A nut driver wont fit.
#7923 58 days ago
Just out of interest, since i don't own the game (yet).
Seems to be four wires?
Is it so that same clusters can do different colored Light, but all do the same color in that cluster?
Are Theese boards only routing Light-wires?
12 or 5 volts?
#7924 58 days ago
Quoted from Dr-pin:
12 or 5 volts?
The pre 2.0 light systems (doesn't matter which one) are all serial communications which means the data flows from one board to the next to the next and so on. There are no "clustering" of light colors, each board is full RGB and completely independent of the other boards as far as what color is being produced but the serial nature is what causes the bigger problems. One board can cause a whole bunch of others to do bad things like be completely dark or flicker rapidly. The very first ones were 5V and were pretty quickly switched over to 7.5V boards until the 2.0 light system was released, I'm not sure what the voltage is on those.
#7925 58 days ago
Quoted from pinballinreno:
Thank you. Been looking around. Need to order another lit winky. Anyone know a good place to get the lite clear winky?
#7926 58 days ago
Indipinhead makes the best one.
#7927 58 days ago
I'm thinking of buying an ECLE version of WOZ pinball, but the seller told me that the machine is running the 7,5V light boards. The seller said that he didn't had any issue with the lighting.
Should I be worried if I finally get it?
#7928 58 days ago
Quoted from bobukcat:
Thanks for the reply. Much appriciated.
So are all the lights on the same board, presenting the same color all the time?
(i realize they can change color, but can they change color induvidually, or only within the same group?)
#7929 58 days ago
My ECLE has the 7.5 volt boards and I’ve never had a problem either. In the unlikely event that a problem did arise, I can just order the 2.0 version.
#7930 58 days ago
Pm sent to indy!
Quoted from sonambulo:
Quoted from hlaj78:
I have the 7.5 buffered boards. Game works great no issues with lighting.
#7931 58 days ago
I wouldn't, have the same boards and except for a questionable GI board I've been good. Buy it and you'll love it!
#7932 58 days ago
Quoted from Dr-pin:
No, every single LED is fully RGB addressable, even on boards with multiple LEDs and the resulting light show is pretty fricking awesome!
#7933 58 days ago
I bought a used ECLE thinking I would be ok. I was wrong. I ended up buying the 2.0 board set.
#7934 58 days ago
Some of the problems with the old boards have to do with interference from nearby EMI sources that cross onto the communication wires between the boards and aren't failures of the boards themselves. Moving the wires around can actually resolve lighting issues in these cases. One way to tell if interference may be your issue and not a bad board/wire is if power cycling the game restores full lighting functionality until you play it and flip some, and then after some gameplay half your lighting dies out, and may or may not come back by itself...until you power cycle again.
Source: Resolving my ECLE issues with some help from folks around here when JJP support stopped replying to me.
#7935 58 days ago
Quoted from mavantix:
A lot of the moving wires around to fix lighting issues has been from loose wires in the wall nuts.
Wall nuts were never recommended for stranded wire.
It compresses and loses contact.
Wall nuts are typically used for solid core wire.
#7936 58 days ago
Umm, there are no wall nuts on the inter-board communication wires I'm talking about moving away from EMI sources.
#7937 58 days ago
Right, but when the wall nut connections go bad the slightest movement can have an effect. I experienced this myself, jiggling various wires under the playfield (not the main harness branches). Give each wire on the wall nuts a solid tug just to be sure. I ended up having so many wires pull out that I replaced most of the wall nuts with old fashioned twist nuts.
#7938 57 days ago
Yes. But just raising the playfield can fix lighting issues or cause them, if you have loose wall nuts.
My game has done this from the beginning.
Its fairly stable if you dont mess with it too much.
#7939 57 days ago
My family hosted a gathering at our house while I was away last weekend. Went out to the game room and discovered that WOZ no longer boots. I started a separate thread here:
https://pinside.com/pinball/forum/topic/woz-won-t-boot-1#post-5062240
Any help would be greatly appreciated!
#7940 57 days ago
Greetings! Recent new(and happy) owner here! Can anyone tell me where I get get mirror blades? Best, Charlie
#7941 57 days ago
Please elaborate on wall nuts fixing some light board issues that manifest inconsistently after some gameplay but then resolve after cycling the power.
I had to search on "wall nut". I learned something today. Hadn't heard that term.
Which/where wall nuts are possible culprits?
And which wires are recommended to fuss with?
Thank you,
-Jason
#7942 57 days ago
Quoted from FLpinball:
Regular, black and gold
https://www.pinballdecals.com/MirrorBladesPage.html
#7943 57 days ago
^ Thanks bro!
#7944 57 days ago
Quoted from jasonbar:
The issue and workaround I described has nothing to do with wall nuts and everything to do with EMI in a pinball and it’s negative effects on serial lines controlling the addressable LEDs. EMI (say from a coil firing) causes communication to be disrupted (noise on the line) and the software/boards don’t recover gracefully. That’s why power cycling the game temporarily resolves it. If it doesn’t, it’s not the same issue. Interestingly in my case, early versions of code (1.x) presented the issue as a white flash across all the LEDs, but later versions (6.x/7.x) exhibits total temporary failure in effected lighting and downstream lights, and only recovered with a few scenarios, power cycle being 100% reliable. I suspect they changed some of the USB interface code between those versions causing the difference in visible behavior.
I assume JJP attempted to fix this EMI issue with “buffered” boards, but that just treated the symptoms and not the cause, so they abandoned the old hardware design for a new one using Ethernet cabling which is twisted to specifically avoid EMI/cross talk.
Would be ecstatic to be enlightened otherwise with details on what I got wrong, but it seems JJP is mum on this issue. Perhaps because an argument could be made that it’s a design flaw and not a component failure.
#7945 57 days ago
Thank you,
-Jason
Follow the wiring harness for the lights to the back of the playfield. You will find that the wires all come together in a group of wall nuts. One color is positive, the other is ground. Tug each wire in each wall nut. If a wire comes out of a nut or wiggles excessively, replace the wall nut with a twist connector or other suitable, strong connection. Make sure the wires are well connected and secured together as a group. Don't use another wall nut. They're not good with stranded wire.
#7946 56 days ago
Hi guys, still thinking in joining the club buying an ECLE version. All I know it has 7,5 boards (don't know if buffered or unbuffered).
It's a 2/2014 build, any known issues on machines born this date?
#7947 56 days ago
Anything not 2.0 is likely to have issues sometime. Those sound fairly stable for all the v1 options. As long as you are ok with doing the 2.0 update at some point.
#7948 56 days ago
Quoted from pinheadpierre:
Did they change that at some point because I don't remember encountering any wall nuts (which I fricking hate!) when I pulled the old wiring harness out while doing the 2.0 upgrade?
#7949 56 days ago
Walnuts? In a salad yes those are tasty, I’m totally lost on this wal nuts talk
#7950 56 days ago
Mine has a huge bundle of them hanging down from the bottom of the playfield.
Once in awhile after doing maintenance I have to pull on them or wiggle them to get the lighting back up.
It's not frequent, maybe 5 times in 5 years lol.
$ 189.00
$ 11,500.00
$ 40.00
