(Topic ID: 87617)
WOZ Fan Club - members only
By TigerLaw
7 years ago
  • 12,489 posts
  • 625 Pinsiders participating
  • Latest reply 2 days ago by LTG
  • Topic is favorited by 287 Pinsiders
9 key posts have been marked in this topic (Show topic index)
There are 12489 posts in this topic. You are on page 142 of 250.
#7051 2 years ago
Quoted from Oneangrymo:
I was in such a hurry, had to get them in the basement before my wife came home. Sometimes she doesnt know I buy new pins, and I would like to keep it that way.. she gets upset with new pinball purchases. So when she leaves I smuggle them into the basement, she doesn't see them and hardly goes in the basement.
It's like another me is out there somewhere posting on pinside with a different username. I thought I was the only one!
#7052 2 years ago
Quoted from Nokoro:
I posted about this in the 2.0 lighting conversion thread, but I figured I would post here as well for those who don't follow that thread. I just finished the work on the conversion this weekend. Overall, it took me about 14 hours, which I spread out in sessions over 5 days (three weekends). If you are considering doing this but are nervous about whether you have the skills, do it. I have very little in the way of repair skills compared to most on pinside, though I'm learning. This conversion is very doable. Just take it in steps, follow the instructions, and ask questions if you need help. Don't let nerves stop you. Honestly, the most difficult part is removing the castle and munchkin playfields, which isn't really all that hard and which you will most likely have to do at some point. Anyway, I just wanted to offer some words of encouragement to those who may be on the fence.
Cool thanks for posting. I’m taking delivery of a very early run of WOZ (No 27/1000) which I will inevitably have to replace the boards at some point. Was it easy to purchase the boards from JJP. And what is the total cost including shipping if you don’t mind me asking, although I’m uk based so will cost more
#7053 2 years ago
Quoted from Sciddleybop1980:
It is up on their online store now so you can order directly from that. Mine shipped the day after ordering. It is $800, which is the discounted rate. At some point, they have threatened to raise the price significantly since they are selling at cost, but that hasn’t happened yet. Shipping wasn’t too bad, but you are right that it will cost more for you. It comes in a fairly large box.
#7054 2 years ago
Installed my drop target from indypinhead
Love the look and how solid this feels in hand, going to be able to take a beating!
#7055 2 years ago
Quoted from f3honda4me:
Love the look and how solid this feels in hand, going to be able to take a beating![quoted image]
I have over 1000 plays on mine, still solid.
The LED bulb broke (easy to just replace bulb) but the target is still good!
#7056 2 years ago
Do I have to take out the mini playfield to change this rubber? ... How do I take out the mini playfield/loosen up to be able to change it?
Thanks Guys!
#7057 2 years ago
Quoted from RPZ:
Mine broke also.Only loosened the mini playfield to change mine.Two or three hex bolts to be undone enough to lift the playfield a little and get new sling rubber over that third sling post .
#7058 2 years ago
LTG has a guide he can send you about changing that rubber.
#7059 2 years ago
Quoted from Pinballomatic:
Thank You! I just found it, and unfortunately I sent him like 10 PM’s by mistake somehow to get this guide.. oops!
#7060 2 years ago
Is there a link to the guide?
#7061 2 years ago
#7062 2 years ago
Didn’t get the guide, but it’s super easy.
- unscrew and lift ramp
- loose 3 screws. 2 around the house, you have to rotate it until they come up, then a 3rd which you may or may not need to loosen towards the front of Mini playfield.
-Lift up mini playfield enough to fit new rubber through and you are done.
- tight all back up!
#7063 2 years ago
Thanks! Key post made! This thread needs more of them.
#7064 2 years ago
There is Butch's video :
And if you want the guide, I need your email address to send it to.
#7065 2 years ago
Quoted from LTG:
Thanks! Mine just broke today. Pretty easy fix!
#7066 2 years ago
Quoted from lurch:
I changed that one a couple months ago, I was totally freaking out about taking of the mini playfield, but this tutorial video saved my life.
One advice though, the nut above the top left playfield (plastic part 14) is really tough to reach. After 30 minutes of struggle, I went to the hardware shop and got a flexible flat wrench like this one and did the job in 1 mn.
#7067 2 years ago
Also you can gently flex that clear plastic out of the way without pulling out the mounting posts as they are flexible. I’ve always been able to do it with an 11/32 nutdriver.
#7068 2 years ago
I need help. In the middle of a game, one of the coils started acting up and seemed to fire on its own. The game screen then went dark. I shut down the game and restarted it. When it started up, the game seemed ok but very quickly into my first plunge, multiple coils started firing. I heard a pop and smelled burning. I turned off the game again quickly. I looked inside the box, and the only thing I saw out of the ordinary was this burnt looking chip on the I/O board (see picture below).
Note that I recently converted the game to the 2.0 lighting system. However, I played multiple games since doing that and everything played well. More recently, I waxed the game, and this was my first game after waxing. Not that waxing would do anything, but I did pull out the playfield a bit to get everywhere.
Any ideas? Is this just bad luck, and my I/O board went? Do I have some other issue that caused the I/O board to go? I'm really bummed out as I just spent all that time on the 2.0 upgrade only to have this happen a week later. Thanks in advance for the help.
#7069 2 years ago
Are these fuse LEDs supposed to be out?
Also, how did my witch get unmoored from the threaded rod? Perhaps because the motor just kept turning?
When I turn on the machine now, the ball lock door on the castle playfield just keeps clicking open and shut, even when the coin door is open.
#7070 2 years ago
Quoted from Nokoro:
Look st the coils, see if any look overheated.
Check for burnt connectors or maybe inserted wrong, smashed or bent onto the siderail or ground.
Looks like a high voltage short to cause that chip to burn.
Check the schematic and see what that chip controls
Could be wire cut, pinched or damaged and going to ground.
Could be a stay wire in a connector.
Screw or washer fell onto a board?
The game will not function properly until your i/o board is repaired or replaced.
Sorry to see this happening after all the work getting 2.0 up and running.
#7071 2 years ago
Quoted from pinballinreno:
Thanks. This is very disappointing. I’ll have to check everything over, likely next weekend. I feel like I’m going to be looking for a needle in a hay stack.
What would an overheated coil look like?
#7072 2 years ago
Quoted from Nokoro:
Shrunken, singed wrapper. Smells bad etc.
#7073 2 years ago
Witch came up because you lost the 5v dc to that opto control board. Motor keeps running until it sees that up opto and it never did.
#7074 2 years ago
Really sorry to hear this Nokoro. Was following your 2.0 lights with great interest. Don’t know if one had something to do with the other, but I also had an i/o board short out. Never found the cause but had it replaced and it’s been good for years. Darn pinball machines.
#7075 2 years ago
Proud New Owner Today! ECLE #139, June 2013 build date. Appears to have many upgrades including light boards, not the 2.0 but earlier I was told.
My Monkey is not happy.
During game play it will come down track and grab ball....then stops and freeze's. Game search will happen but never corrects monkey, he's frozen to playfield. Had a few good games till bug occured. Its a game over situation, it never moves.
Ive checked the track and lubrication, the 2 ball switches top and bottom. Im able to get ball off with glass off and get the monkey to work in tests. It seems all good, but next game the second it comes down to grab Dorothy it just does it again.
Any suggestions would be appreciated.
Thanks in advance, I'm sure Ill have many more in years to come.
#7076 2 years ago
#7077 2 years ago
Does he go back up the hill in test mode? If he does, the problem is he is “plugging” on top of the pinball because he is traveling too far down just a bit - a thread or two - on his threaded rod. Imagine you took off the monkey decoration and could see the small magnet coil - you want him to stop so that the farthest edge of the small coil (not the plastic) bisects the playfield magnet core exactly. Adjust up the bottom microswitch arm JUST a bit so that he stops just higher on the hill than you would think he should. Just a tad sooner than now and his magnet will pull the ball over ever so slightly before lifting it up. Too far down he stops exactly as you describe.
#7078 2 years ago
And congrats - WOZ is great when you get it dialed in just right.
#7079 2 years ago
Thank you so much. This woz is several years in the making. I recently sold some machines to help pay for this.
What your saying about micro switch sounds dead on, i will try this in a bit. Glass off again. Previous owner recently installed Gouvia New Monkey, maybe that switch or putting new monkey messed with that alignment. Came with red smoke witch mod to. Got really lucky on this WOZ.
Im very good friend from league was willing to sell it. He's taken great care of it.
#7080 2 years ago
Quoted from Vyzer2:
Thanks Vyzer. What made you finally decide to stop looking for the short and just replace the board? I’m paranoid about replacing it as I don’t want to spend all that money just to short another board, but I’m really not sure what caused this.
pinballinreno all coil sleeves look ok.
I really need to go over everything more closely. I’m going to email JJP and see what that chip connects to to try to narrow this down. I’m not sure if the 2.0 conversion had anything to do with this. As I said, everything worked fine for about a week after I finished, and then this happened.
#7081 2 years ago
I couldn’t nail it down, so called Jjp and actually had Eric M call me back. This was when Eric was not working on designs, etc. He had me checking everything with a multi meter (spent a good amount of time on the phone, couldn’t thank him enough). In the end there was nothing specific that could determine the cause. Just wound up ordering a new board. Keep in mind, my game was a very early production game (May 2013). Because I live in NJ I took the board to Jjp where they work on all sorts of boards to repair. Got a different I/0 board (used) which they felt was more robust for lack of a better word. It has been fine since. Btw, replacing it for you will be a snap after the work you did on the light boards. Do keep us up to date.
#7082 2 years ago
Quoted from Vyzer2:
Thanks. I have a friend who is a bit more experienced than me with these things, and he said he would help go through all the connections with me with a multimeter. I still want to call JJP to see if I can narrow it down based on the chip.
#7083 2 years ago
Quoted from Nokoro:
Take a look at the schematic.
#7084 2 years ago
I'm not great with schematics, but if I am reading it correctly, it looks like it is a transistor thingy for the switch matrix columns. If I'm right, maybe that rules out the coils . . . .
#7085 2 years ago
Quoted from Nokoro:
Or a coil or diode failure killed the transistor.
#7086 2 years ago
To answer that first question, yes it goes up hill and down in tests just fine.
Bent the lower switch up a little, it helped some, but not 100%, still did it again today, much better, i will try to tweak it up a little more.
Thank you again.
#7087 2 years ago
Quoted from Ericpinballfan:
Thank you again.
Put a little silicone or white lithium grease all along the threaded rod.
Same with the witch threaded rod.
One you get the monkey dialled in, its pretty stable.
I haven't had to adjust mine since the first week I owned it years ago.
#7088 2 years ago
Thanks bud. Im thinking just moving it cross town wiggled it or something. It was working.
Lithium applied to both rods yesterday. Made the noise it makes a little better.
That damn little coupler....at first i thought it was loose, how the hell you tighten that? Micro allen and micro wrench?
#7089 2 years ago
I have been thinking about selling off my Met pro and a few of my arcade machines to buy a Woz standard. Looks like all that is available is the YBR edition most places. Is JJP done making standards?
#7090 2 years ago
Yeah, it just has to grab.
Dont tighten it very much unless its slipping.
Moderate to light back pressure on it with a finger and it shouldn't slip.
I was concerned that the additional weight of the mod might cause it to slip, but that had not been reported.
I bet yours is just out if adjustment. It takes a little monkeying around with it.
#7091 2 years ago
There isnt much weight to the Monkey Mod. Nothing the motor cant handle. Maybe 2 oz.
#7092 2 years ago
All right, owner for 2 days.
Some dumb questions.
Where can I buy green leg bolts to match this beauty?
What connector do i need to power a sub using this outlet on back of cabinet?
At what point do the witch's legs come out of house?
#7093 2 years ago
Wondering why a lot of guys don’t like the YBR ? I think the yellow looks great ?
#7094 2 years ago
Spell RAINBOW and then launch a ball up the ramp and hit it around the house with the upper right flipper like 10 times.
#7095 2 years ago
Go through the house calibration in device tests menu.
The legs drop when the house stops spinning.
Calibration can be tricky but yields good results.
Sometimes just manually turn th he house a tiny bit if its close to perfect.
There are a few vids posted about this as well as instructions here on pinside.
#7096 2 years ago
All right, owner for 2 days... ....Where can I buy green leg bolts to match this beauty?
I LOVE IT!
2 days in and you are looking to colour match the bolts, you sir are 'hooked on pinball!'
#7097 2 years ago
Quoted from whitey:
It's got no monkey! (and cost $12.5K)
#7098 2 years ago
Quoted from bobukcat:
Yeah, but the sparkles and yellow wire forms and smaller topper is definitely worth the extra 2K.............said no one........like.......EVER!
#7099 2 years ago
I'm looking at getting my first pinball. WOZ looks badass, I like the crystal ball toy with the OLED display inside. Can these units still be bought in brand new condition? If not, I might have to do the Wonka machine, as I like its color pallette, but the toys on WOZ look much more fun vs. Wonka.
#7100 2 years ago
Quoted from Flipper_McGavin:
Check with Chris at Kingpin games - 608-393-2299 . See what he has in stock. Tell him LTG sent you.
