(Topic ID: 87617)
WOZ Fan Club - members only
By TigerLaw
7 years ago
  • 12,823 posts
  • 641 Pinsiders participating
  • Latest reply 7 days ago by bobukcat
  • Topic is favorited by 298 Pinsiders
WOZ Castle PF Removal.pdf (PDF preview)
WOZ_Single_Castle_Door_Assembly.pdf (PDF preview)
11 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 12823 posts in this topic. You are on page 138 of 257.
#6851 2 years ago
Quoted from Gotfrogs:
Have you guys seen the yellow brick road pics online? $11.5k and no flying monkey!
I am looking at it at TPF. No flying monkey. Topper is not as good, either.
#6852 2 years ago
Quoted from HIPPY:
I would think the Ruby Reds with factory 2.0 systems would be in higher demand, specially if they are removing winged monkey.
#6853 2 years ago
Quoted from pinheadpierre:
I picked up an original run WOZ recently and an working through some issues as I discover them. Since I'm new to the game, I'm not always sure what behavior is normal. Is the game supposed to release locked balls at the end of the game? Mine does not release balls from the munchkinland lock at the end of the game. If I end a game with balls locked, start a new game and lock a ball it does not kick a new ball into the shooter lane. It goes into a ball search instead. What is normal/ what is wrong with this picture?
That’s not normal. Check the switches for the locked balls on the Munchkin playfield. I bet one is not registering.
#6854 2 years ago
The balls should drain from the lock at the end of the game. When you lock a ball in a new game and balls still remain in the lock from a previous game, the metal gate should lift just long enough to let one ball down the wireform back to the left flipper.
#6855 2 years ago
I have a minor issue that I don’t think I’ve seen in this thread. I have a RR v2.0 boards, sometimes when I start a game the oz lights go out, then as I hit the YBR shots (first the ramp), the yellow light does not rotate from the ramp to the orbit highlighting the next YBR shot, but the noise sounds. The yellow brick road also does not give me credit for the shot.
Almost every time I restart the game, all works fine for as long as ithe game is on. I have 6.61 software and I’ve tried many times looking for loose connections, all seem tight. This seems like a software bug as 3 sets of lights are acting strange. All lights work perfect in attract mode prior to starting the game.
Has anyone else had this happen?
#6856 2 years ago
Quoted from 2000_Alum:
YES! It is a known software bug with 2.0 and it is being worked on. Next update should rectify this issue. Trust me its not you,...........I mean, that's what she said anyway
#6857 2 years ago
Quoted from capguntrooper:
Awesome! Thanks for the response!
#6858 2 years ago
Quoted from finman2000:
Figured it out. Not sure why but the problem seems to have been caused by the monkey not making it all the way to the top. I fixed that and now the game seems to work normally.
BTW - I was reading through the manual this morning and noticed that whether the game clears out locked balls at the end of a game or not is actually a setting. I just updated my machine to the latest code, so it is set to the default, which is "no". So not having the balls drain out of the locks is normal. I'm curious though whether anyone has an opinion as to whether there is any advantage to "yes" or "no" in this setting?
#6859 2 years ago
No advantage. You still have to lock three balls to start MB regardless of whether they are being held or not from a prior game. You want them released at the end of a game IMO.
#6860 2 years ago
Quoted from Nokoro:
I agree. I was wondering more about it from a performance reliability standpoint.
#6861 2 years ago
Yellow brick road Wizard of Oz really nice yellow trim radcals look wonderful, no flying monkey on the backboard.
Smaller, colorful topper.
20190323_102126 (resized).jpg20190323_103530 (resized).jpg20190323_103520 (resized).jpg20190323_103523 (resized).jpg
#6862 2 years ago
Is the monkey magnet still there on the playfield?
#6863 2 years ago
It's pretty. And a known great game. At a limited number I think they will sell for the high end collector who wants a NIB WOZ. For everyone else, there are plenty that will show up o er time in the marketplace. Surprised they didn't add spotlights or some other lighting as this is a known "dark" game.
#6864 2 years ago
Quoted from pinballinreno:
I like the new backglass.
#6865 2 years ago
Quoted from avspin:
It appears that the magnet is still there:
https://pinside.com/pinball/forum/topic/jersey-jack-s-pinball-machine-release-tx2019?gallery#g
#6866 2 years ago
Having trouble with my lighting harness and wondering if anyone here has insights that might be helpful:
https://pinside.com/pinball/forum/topic/woz-light-harness-problem#post-4898863
#6867 2 years ago
I agree! The backglass on the 75th RR is the only portion of that edition that I am not crazy about.
#6868 2 years ago
Quoted from avspin:
Yes
#6869 2 years ago
The yellow flippers and rubbers is a little too much IMO.
#6870 2 years ago
Quoted from bobukcat:
The yellow rubber is pretty dirty after 1 day...
#6871 2 years ago
The yellow overall is way too much for me.
I would however happily drop the playfield into my ECLE. I have asked in two places to see if A: the playfield is identical to the EC and RR editions and B: if the YBR glitter PF can be purchased separately.
#6872 2 years ago
I think the main reason I dislike the yellow isn't because of the cabinet armor, but the ramps... The green and red ramps in ecwoz and rr blend in with the playfield and kinda disappear these yellow once stand out too much and take away from an otherwise beautiful machine. I would like to see the playfield in person though, it sounds like it would look pretty nice.
#6873 2 years ago
Quoted from dnaman:
I’d say no on B.
#6874 2 years ago
Just a quick question about YBR WOZ. If there is no winged monkey, does it mean no more physical lock for Rescuer Multiball? The right door of mini castle playfield is doing nothing?
#6875 2 years ago
Virtual lock
Single door does not open
#6876 2 years ago
I would definitely buy the apron for my RR.
#6877 2 years ago
WOW No Monkey?? And it's more $... interesting
#6878 2 years ago
I'm looking for some advice on improving the overall GI illumination of WOZ. I know this has been discussed as nausea but the threads I found are scattered all over the place.
I'm looking to collect the opinions of folks who have already traveled this road. I started a thread with a poll here:
https://pinside.com/pinball/forum/topic/what-s-your-favorite-gi-mod-for-woz#post-4903367
Thanks in advance for your input!
#6879 2 years ago
Adding a few 12v spot lights is really all that is needed. Easy to tie into the GI.
I added 6 and could probably add 2 more.
There is an illumination kit from lermods I think.
It has 6 spots and trough lights.
Pinstadiums are really bright, you can make them ptetty cheap or buy them. They put out a lot of light.
#6880 2 years ago
Quoted from Pinbear:
Yep, no monkey. The door is not used.
Too bad they removed it.
They should have reworked the castle doors instead of removing the monkey mech.
Castle doors are the most trouble and needed a design change.
#6881 2 years ago
They did change them slightly - no more microswitches up there now optos on top on castle playfield.
#6882 2 years ago
Quoted from Pinballomatic:
That's a great improvement for sure! I just replaced both switches in mine. It's a big job.
But the short life span of the motors is still an issue.
The other weak part is the rubber door stop pad. It should be black nylon or duron. When the pad wears it creates an angled shape that allows the doors to slip past.
I glued my new stop pad in with epoxy, the old glue on the replacement pad was dried out.
I also replaced the door stops. They were worn and tended to slip under the lock. They were only slightly bent back.
10,000 plays, 70,000 balls in play = 6 motors and 3 door stop pads.
1 million flips on each flipper = 6 bats, 4 flipper bushings and several flipper rubbers.
I like the perfect play translucent red rubbers the best on this game.
#6883 2 years ago
This is a downgrade ... I have an issue with Castle doors but it was an easy fix. I never have an issue with monkey. The major problem is witch bash target. The design is bad and hard to adjust to the perfect position. I have an NIB WOZRR with 2.0 boards. I remembered in the first few months, it the ball hits pop bumpers which triggers witch hits. It took me a lot of time to adjust the bash. I thought they will upgrade the witch bash mech.
Now I am glade I got the RR WOZ. The YBR version, yellow is not the yellow brick's yellow. It looks like a taxi yellow. AND the price is $11500 .... which is 2k more ...
I hope the JJP's new prices are NOT ... Standard 10k, LE 11.5k and CE 12.5k.
#6884 2 years ago
Is it me or do standards look better than YBR editions? I mean, ya get winged monkey and pay 3k less. If you're a taxi cab driver though this is a must have, I'm betting that ECLE and RR will fetch more in the distant future. Now if the next code update produces a special YBR edition multi ball specific to game, then I might change my mind and be a little jelly, but as it sits now, MEH.
#6885 2 years ago
Rare picture of a specie on the edge of extinction !
#6886 2 years ago
Quoted from adol75:
*Chuckle*
I agree with Pinbear should have come up with a better solution for the witch bash. After the lights this has been the main source of frustration for me.
But I think the YBR is gorgeous. If I wasn't keeping my powder dry for JJP 5 & 6 I would be placing an order today and keeping both the YBR and RR side by side. I am thinking that if the YBR playfield is available a swap may be in order.
#6887 2 years ago
Odd question - anyone know the BOX dimensions of the WOZ RR machines? I'm referring to the shipping box they come in.
#6888 2 years ago
Quoted from f3honda4me:
31 inches by 31 inches by 57 inches.
#6889 2 years ago
The box is fairly usual, what is very surprising and unexpected when you get it delivered is how damn heavy it is. I remember calling two friends once I tried lifting the box with the delivery guy, and 4 of us was still a painful time !
#6890 2 years ago
Quoted from LTG:
Thank you thank you kind sir.
#6891 2 years ago
Quoted from adol75:
I just need to get it in and out of the vehicle, easy enough to do with the sliding method. After that, it's all escalera!
#6892 2 years ago
I'm thinking I'd like to add some Cliffys to my newly acquired WOZ. I know I read recommendations about this somewhere but can't seem to find it. I remember people saying the munchkinland playfield edge needs a protector. Seems like the scoops could use protection, too. That means a minimum order of the VUK/scoop set and munchkin edge. What is the general opinion on protection for the rollover buttons, magnets and castle playfield edge?
#6893 2 years ago
pinheadpierre I did vuks, munchkin, shooter lane and opted not to do rollovers as they tend to diverge the ball path more than normal. Munchkin is a must the ball hit that edge in front of the ramps a lot
#6894 2 years ago
Sounds like Cliffys is 2 months behind right now. so gonna be a while
#6895 2 years ago
Quoted from Soulrider911:
Thanks for the input. I think that's the route I'll take, too unless enough people chime in otherwise. I'm having a hard time seeing how the rollover button areas would need a cliffy given that there is an approximately 1/8" ring of clear plastic flush with the plywood edge between the button and the playfield. Plus I don't want three metal rings in the middle of that beautiful playfield. The magnets I worry about a little bit not as much as the saucers. I also have a hard time imagining the castle playfield taking a bad hit to the edge. Is this an actual problem area or just a protection option for the abundantly cautious?
That's okay. He's a one man shop making stuff in his garage. Sometimes you'll get lucky and he'll have stock on hand for what you need. Otherwise, I'm fine to wait. He's a great guy with a quality product.
#6896 2 years ago
Thanks for the input. I think that's the route I'll take, too unless enough people chime in otherwise. I'm having a hard time seeing how the rollover button areas would need a cliffy given that the is an approximately 1/8" ring of clear plastic flush with the plywood edge between the button and the playfield. Plus I don't want three metal rings in the middle of that beautiful playfield. The magnets I worry about a little bit not as much as the saucers. I also have a hard time imagining the castle playfield taking a bad hit to the edge. Is this an actual problem area or just a protection option for the abundantly cautious?
Agreed!
#6897 2 years ago
The Munchkin mini playfield is the one you MUST have some kind of edge protection for, trust me the ball WILL hit it and it will chip the edge! If you don't want to put the cliffy on at least get some mylar strips and apply them over the top edge of that playfield or you will be sorry you didn't.
#6898 2 years ago
I am having some problems with my castle doors. I have a ticket open with JJP but have a party at the hose this saturday and really want to have my machine up and running. If you could take a look at my posts in this thread I would greatly appreciate it! https://pinside.com/pinball/forum/topic/woz-castle-doors-not-closing-fully
#6899 2 years ago
I responded to this in that thread.
#6900 2 years ago
Anyone know how long it usually takes cliffy to respond to emails for placing an order?
