Over the Labor Day weekend I installed the 2.0 light kit upgrade to my RRWOZ.
My machine came with the 7.5v light system originally.
This is a great kit.
3 cheers for Butch Peel making this a reality.
I followed the instructions and it worked. No trouble shooting. It just worked. Amazing
It took me around 20 hours to finish this project over three days. I also took this opportunity to rewire and rerun all the mods that I have on this machine so it tool more time than it would have if I hadn't taken on this extra work. But now it all looks cleaner when I raise the playfield.
If you are considering this I say do it. It wasn't hard just time consuming.
Some suggestions based on my experience:
As mentioned by DANGERTERROR (https://pinside.com/pinball/forum/topic/woz-fan-club-members-only/page/113#post-4425303),
have the wiring diagrams (pages E-20 - E-25) from the WOZ manual ver 3.5 handy and the bigger the better. I displayed the manual on a 60" tv and it was extremely helpful. Especially the orientation of the single LEDs
Read all of the instructions relating to a step before embarking on a step. There are several steps with subsequent information that you will be glad you knew of before proceeding. (Ex. one step is to remove all the large boards, which I did, then I read after that each board should be replaced as removed and that removing them all without replacing them would make it more difficult to put the new boards in place. Fortunately, the pictures in the manual made it easy to put the new boards in place but I think you get my meaning. Read the whole step.)
You will need some 1/4" 8-32 SMS and brackets for mounting the new power supply to the rear of the lower cabinet. I used some plastic Plumber's Tape to strap it in place.
In the manual, on page E-23 Cable 8's part number is 19-3096-08. In the kit this cable is now 19-3096-09, there are 4 of them. Not a big deal but I relied heavily on the manual and this was the only disconnect between the manual and the kit that I found.
The kit comes with some #4 x 3/8" SMS but I didn't see any instructions on where to use them. Instead there are many callouts for the #4 x 1/2" SMS. I went and bought a bunch of #4 x 1/2" SMS but I think I should have been using the 3/8" SMS for the single LEDs (the ones with two mounting holes 15-0025-01) that get mounted directly to the playfield without standoffs. Again not a big thing but I would do it differently next time.
Also the kit included new plastic pop rivets. As it turns out I used the original ones, but after crawling across my garage looking for the original sleeve that fell and me wondering how I was going to proceed I found the bag with the new pop rivets and I almost cried. JJP had my back - I wish all companies were this thorough.
