Turned my WOZ on and the balls kept firing out of the trough and autoplunging themselves. The throne room VUK was firing and the ramp ball lock was going up and down. I can't remember if the winkie drop target which is also on this circuit was firing, likewise the ball divertor.
I opened the coin door to stop them, and noticed they were all on the J106 orange wire circuit. This is associated with fuses 701 and 706 which I checked (pulled them out and tested) and they were fine.
The trough VUK ended up with the black tip falling off.
I have checked for obvious things like whether there is any metal touching the coil lugs and haven't found anything. Just waondering what the next step. I'm a bit rusty on testing transistors but I would be surprised if they are the problem seeing as there are a few different coils on that circuit firing.
Just turned on the machine again after a break and now just the Auto-launch and the ramp ball lock are firing. The throne room VUK and the trough VUK have stopped.
It's a RR75 LE, built late 2014.
