Quoted from rubberducks:If only Stern were so committed to code.
Thanks Keith, Ted et al.
If only JJP made more than 3 games a decade...
Quoted from Jakers:Thanks. I'll be sure and make a backup before I install. One more question, what format should the usb stick be? MS-DOS (FAT), ExFAT, Mac OS Extended?
FAT32, not NTSF
Wouldn't stress about stern in time jjp will kill them off . No comparison whatsoever , jjp commitment , quality , and love for the game and fellow uses and their family ,and the respect he has from people in general . This will crush the big stern company it will only take time . Then maybe jjp can make a pinball about it .
Quoted from DeathHimself:Thanks Keith,
Hopefully Lloyd will chime in maybe its just an adjustment, I don't believe they are wired backwards as they did work properly just an hour ago but maybe the new core settings being more sensitive has mine constantly open now. I will start looking into this a bit further now and thanks for supporting such a great game, all the best.
Mike
Can you revert back to the previous code version and see if the problem persists, seems the easiest way to know for sure if the code changed something.
Quoted from DeathHimself:Hopefully Lloyd will chime in maybe its just an adjustment,
Loosen the nuts circled in RED allowing you to move the switches closer to the plate. Reach around the lifted playfield and tap the strike plate while moving the swiches closer. When you have the sensitivity you want, just tighten the nuts back down.
http://www.flickr.com/photos/89824152@N07/sets/72157634995600921/
Quoted from Lermods:Can you revert back to the previous code version and see if the problem persists, seems the easiest way to know for sure if the code changed something.
I don't think you can without doing a full 6.06 install and then delta up to 6.11P
Quoted from Georgeh:Wouldn't stress about stern in time jjp will kill them off . No comparison whatsoever , jjp commitment , quality , and love for the game and fellow uses and their family ,and the respect he has from people in general . This will crush the big stern company it will only take time . Then maybe jjp can make a pinball about it .
Stern isn't going to feel much of a pinch until JJP, or any other manufacturer for that matter, can put out games at a reliable rate. Stern simply crushes everybody in both marketshare and mindshare at this point. But yes, JJP and the others are starting to make dents in the Stern machine.
Quoted from Allibaster:So, when's this thing going to get posted?
You may use the following URL and instructions to download.
http://www.jerseyjackpinball.com/support/
Select 'Downloads'
Select 'Wizard Of Oz'
Select the appropriate 6.50 download
Gord
Quoted from jar155:Stern isn't going to feel much of a pinch until JJP, or any other manufacturer for that matter, can put out games at a reliable rate. Stern simply crushes everybody in both marketshare and mindshare at this point. But yes, JJP and the others are starting to make dents in the Stern machine.
IMHO most of Sterns pinch right now is self inflicted, their quality as of late leaves a lot to be desired and their spotty code support on some titles and not others is what I feel pushing folks away and having them look elsewhere where machines are being made.
However Jack does have some great support on both mechanical and code, and the build quality is there as well. Not saying some things can't fall through the cracks but overall they are on top of things.
Quoted from fuseholder:Confused. Do I download, Delta install ver 6.50 or change-log ver 6.50 *NEW*
Delta, the other is only a text file
Thank you Keith and Lloyd the switches had to be adjusted just as you guys said, you guys rock. Thanks.
The new way of tracking balls remaining rather than ball in play is seriously innovative- obvious- and an amazing way of letting people step up and just play with whose ever at the table and currently playing. I was interested in WOZ before- this actually has me seriously considering this game. I want to play all my games this way. How obvious and brilliant.
I mean obvious in the- WTF why didn't I think of that - kind of way. It's such a trivial change to the game but makes a huge impact.
Whatever you may think of Wizard of Oz, you have to admit that Jersey Jack's commitment to code is unmatched. I think any reasonable person would have expected Woz code to have stopped development two years ago.
Quoted from nosro:Whatever you may think of Wizard of Oz, you have to admit that Jersey Jack's commitment to code is unmatched. I think any reasonable person would have expected Woz code to have stopped development two years ago.
Hopefully, in future, any "reasonable person" will begin to expect the kind of code support that the team at JJP offer. Only that way will others pull their socks up.
the contents of the delta file is different than on the install videos for delta code. what folder do you put on the thumb drive? the delta has the manual in it and a few other files.
Does anyone know if the 'no place like home' lights are still sepia toned in the new code? In the beta they were more white. Thanks.
Quoted from busa32927:the contents of the delta file is different than on the install videos for delta code. what folder do you put on the thumb drive? the delta has the manual in it and a few other files.
after unzipping the file, drag the entire "woz_update" folder to the root of the thumb drive. insert the thumb drive in to the usb extension cable located by the coin box. enter the test menu, down to "utilities" and then to "update software".
that should do it.
Quoted from thewool:Does anyone know if the 'no place like home' lights are still sepia toned in the new code? In the beta they were more white. Thanks.
Don't remember, but they seemed more white last night...
Installed 6.5 WOZ and 2.0 Hobbit and got on my high score lists for both games!
Does anyone know what "Courtesy Kicks" are? It's listed in the changelog.
I went from 6.06 to 6.50 because the witch issues concerned me in 6.11, but in 6.50 the witch is registering better than ever! Looks like they got her....Dialed In
I did the update and have to give a MAJOR thanks to Keith. It is excellent! Thanks for the hard work and dedication to the code.
I gotta say, the new JJP website design is a LOT easier to navigate and find updates than the last time I was there. From download to delta update, it took me less than 10 minutes total!
Well done JJP and team!
Quoted from LTG:Loosen the nuts circled in RED allowing you to move the switches closer to the plate. Reach around the lifted playfield and tap the strike plate while moving the swiches closer. When you have the sensitivity you want, just tighten the nuts back down.
It seems that my switches were already factory-set as close to the strike plate as they could be. Moving them in the OTHER direction makes the problem worse. Most of the time, the matrix still shows Left & Right as green, but sometimes a good hit will turn them dark blue again...until, of course, the next time I hit it. Those switches are craaazy sensitive.....sometimes, just lifting/lowering the playfield will cause them to be triggered.
Any other suggestions? :/
Quoted from tp:So I download unebooten, and new 650 code, combine them and all this stuff is now on USB stick.....is this correct?
No. Just unzip the file you downloaded onto a usb stick and update from the menu if you are already about 6.0 firmware
Quoted from FalconPunch:No. Just unzip the file you downloaded onto a usb stick and update from the menu if you are already about 6.0 firmware
I'm doing everything I did to get 606 but everytime I try to combine unebooten and new code all these other files appear on usb. I clear usb stick of all data, download new code, download unebooten. They are the only 2 files on stick but when I combine them all the other files appear on the stick. As far as I can tell I'm following directions exactly.
Quoted from tp:I'm doing everything I did to get 606 but everytime I try to combine unebooten and new code all these other files appear on usb. I clear usb stick of all data, download new code, download unebooten. They are the only 2 files on stick but when I combine them all the other files appear on the stick. As far as I can tell I'm following directions exactly.
This is a delta update, not a full install. Follow the delta update instructions:
http://docs.jerseyjackpinball.com/general/Delta-Update-Install.pdf
Quoted from brucipher:This is a delta update, not a full install. Follow the delta update instructions:
Success!!.....thank you all.
Quoted from moonduckie78:It seems that my switches were already factory-set as close to the strike plate as they could be. Moving them in the OTHER direction makes the problem worse. Most of the time, the matrix still shows Left & Right as green, but sometimes a good hit will turn them dark blue again...until, of course, the next time I hit it. Those switches are craaazy sensitive.....sometimes, just lifting/lowering the playfield will cause them to be triggered.
you can do a slight bend in the switch arm so it make better contact and responsive enough.
Updated mine (from 6.0.6) and played a few games and it really seems to have fixed several issues plus I like some of the new features. The clipping audio appears to be eliminated completely, the castle doors now seem to detect when they have been pushed open better (and close more reliably) and really like the balls remaining display. I haven't played any multi-player games yet or tried adding players during the game but that will be next. The jury is still out on having the magnet by the flipper catch the ball on orbit shots when Capture Dorothy isn't lit but the Witch is, surprised the hell out of me the first time it happened! It really is awesome to keep getting support like this, thanks Keith and crew for all the work!
Quoted from RobertWinter:I gotta say, the new JJP website design is a LOT easier to navigate and find updates than the last time I was there. From download to delta update, it took me less than 10 minutes total!
Their site had a bunch of graphics clipping and stepping over each other in my browser (Safari). Everything on my end was updated to the latest.
Fortunately, I was able to get what I needed, but the site was kind of messed up.
Does the new code have a load countdown now like mine does? Its on the screen wear your code version is annotated at the top left of screen.
Quoted from Allibaster:Their site had a bunch of graphics clipping and stepping over each other in my browser (Safari). Everything on my end was updated to the latest.
No problems like that with Chrome on Win 10 for me.
One of my buddies on the other coast his witch doesnt work at all now and hes having intermittent light board issues after update, anyone else experiencing problems? Im at 6.11 and afraid to delta up. My witch works pretty good after adjusting switch arms.
I love the update with two insignificant exceptions. The display sequence after completing TNPLH is different. I prefer the older version. In certain situations (not all) if you plunge prior to auto plunge auto plunge still fires. It didn't do this prior. Great work otherwise Keith.
I'm running the update fine on my standard built 3/5/14.
Just came home after a long business trip and did the update. I love the floating scores and balls in reserve. I'm a bit disappointed in the fact that they took some of the light show away after making the save Toto shot. The lights used to flash white in a pattern to mimic Toto running. I always thought that was such a cool touch. Maybe they took it away by mistake and will add it back . . . . (I hope!)
Updated last night and didn't have time to play much. I think I have some bugs. I watched my wife play a game today and she got Grand champion with ease. I thought that was a bit strange because she really didn't do much out of the ordinary. So after she was done (and I let her take off somewhere...) I played a game and noticed I get the skill shot almost every time the ball is launched into the shooter lane from the trough. It appears to key off the shooter lane switch. I got the skill shot on 1st,2nd 3rd not 4th but when I lost the ball and it gave me a ball save 4th and 5th balls.
Ok I have another bug. The shaker motor started shaking and wouldn't stop for a longgg time. I don't notice when the shaker motor started. The next couple of games all worked as it was supposed to. I haven't had the game long so I am not sure if there is a mode or situation that would cause the shaker to run a very long time like that but I don't think so and it never happened til I updated.
Quoted from whthrs166:Updated last night and didn't have time to play much. I think I have some bugs. I watched my wife play a game today and she got Grand champion with ease. I thought that was a bit strange because she really didn't do much out of the ordinary. So after she was done (and I let her take off somewhere...) I played a game and noticed I get the skill shot almost every time the ball is launched into the shooter lane from the trough. It appears to key off the shooter lane switch. I got the skill shot on 1st,2nd 3rd not 4th but when I lost the ball and it gave me a ball save 4th and 5th balls.
which skill shot is it awarding you? there are 4 of them available
top lane(s)
which
haunted forest target
BALL target
i am going to take a guess and say it is the witch target and that you might need to adjust the witch sensor a little. i copied Ltgs instructions from a previous post, but they might apply here too.
This page was printed from https://pinside.com/pinball/forum/topic/woz-code-update-65/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
