Hi all,
after a long time being happy with my Wizard of OZ software 5.05, I now updated to 7.02.
All went fine and is in pretty good shape.
Just all Slingshots and Bumpers are incredible strong.
I used to configure my Bumpers to 8 milliseconds and the slingshots to 4 ms.
Now the allowed range for Bumpers is 24 to 36 ms and for the slingshots it's 20 to 30 ms.
This is really strong and I avoid now playing, in fear the game will wear out faster than neccessary.
A restore of the settings didn't change anything and I am also not sure, if the range is correct defined by the software update.
Can someone please confirm, that those ranges are correct?
E.g, when I go to Full Menu -> Install Presets -> Game Presets -> Proto Coil Settings, I can see, that the Slingshots should be set to 8, but this doesn't work either, it changes the value to 20.
Or does anyone has an idea to get a workaround? I am quite ok in the IT World, so if you have a hint on a file to modify, I'd be also quite happy to give that a try.
Thanks in advance,
Ebe
