New! Dark mode!
(Topic ID: 224269)
WOZ Battery Replacement
By GPS
2 years ago
  • 12 posts
  • 7 Pinsiders participating
  • Latest reply 2 years ago by 3pinballs
  • Topic is favorited by 7 Pinsiders
#1 2 years ago
Hi All
Wanting to replace the battery in my WOZ and followed the aittuxtions in the manual with using tape etc. question is how do I manipulate the holder to release the battery? Know this weds to be done with the machine on and DO NOT want to f anything up.
Thank you for the guidance
G
#2 2 years ago
Firstly, Don't EVER follow the aittuxtions in the manual
#3 2 years ago
Isn't just a coin cell battery on the motherboard?
Those are usually good for about 10 years.
But, if you really need to replace it, there is usually a tab or lever of some sort that can release the battery, and you can lift it out (preferably with something non-conductive).
#4 2 years ago
If it fails, you won't be able to boot the game, so JJP recommends it be replaced every 3 years. You also have to replace it with the machine on, otherwise again the game won't boot. There is a little tab on the bottom. Gently pull back on that, and the coin battery should lift out with the tape. It took me a few tries before I noticed the tab. Don't force it. If you find the tab and gently pull back, the battery will lift out easily.
Mind the whirling open fan next to your fingers! I cut myself on it.
#5 2 years ago
Thank you all. Well got it done. While the battery MAY last ten years it appeared to be the original and according to the WOZ manual it says to replace every three years. Don’t want any issues with the game not booting up as it sits turned off the vast majority of the time and hence the battery gets more use.
Yes, I too experienced the whirring fan. Oh well no blood so it is all good. Thanks fellas
G
#6 2 years ago
What number was that coin cell battery?
#7 2 years ago
I haven't replaced this battery since I've had the game.....what battery is it and where is it located?
I just need to remember to have the game powered on so I don't lose my settings!
#8 2 years ago
Quoted from 3pinballs:
There are instructions in the manual that talk you through it. Unfortunately, the instructions don't mention the tab or the fan blade (did I mention I cut my finger?).
It is also not just about losing your settings. If you replace the battery without the power on, you won't be able to boot.
#9 2 years ago
Quoted from Nokoro:
Whoah. How the heck do you fix that? Just picked one up with a four year old battery, better get on it!
#10 2 years ago
Quoted from GorillaBiscuits:
There’s a way but I think you need to hook up a keyboard to the computer and do magical computer stuff. JJP can talk people through it I believe. It just isn’t a hassle you want.
#11 2 years ago
Quoted from Vyzer2:
The battery in the machine is a CR2032 Lithium coin type battery. You can get two at CVS or Walgreens for $7. The battery is located in the back of the processor box just to the right of center. It is all the way in the back though. Yes be warned of the fan rotating. Squeeze the little metallic tab on the front side (players position) and then use the tape method detailed in the manual. Quite helpful that manual. Was worth every dime I paid for it!! Highly recommend if you don't have one. Make sure and ground yourself by touching the lockdown bar area prior to inserting your hands into the machine The components are static sensitive.
G
#12 2 years ago
Hi LTG ....any idea what page the battery schematic is on? thx Tony
$ 50.00
$ 265.00
Pinball Mod Co.
Greenville, SC
$ 279.95
Pin Stadium Pinball Mods
$ 95.00
Pinball Mod Co.
