Almost directly under the winged monkey on the main playfield there is a roll over switch (I assume for the orbit) and the ball keeps getting stuck there. If coming up from the left side (through the pops) and it doesn't have enough speed it will get stuck or even with a decent amount of speed from the right side can still get the ball to stop there. Can't wiggle it out either, even a good amount of force and pushing back and forth won't give it enough to get past the switch. Is this just a common "bend the wire" kind of manual manipulation that needs to happen or is there something special to fix there?
