Quoted from nitrojcrawf:Let me play Devils advocate here. Say we put on the full mylar sheet on the playfields known to have problems. When it comes time to remove it/ change it will it lift the clear and ink off the Playfield worse than just removing mylar?
JJP protector
DESCRIPTION
This custom Playfield Protector is the perfect solution for protecting and limiting any additional wear on the entire playfield for your game!
It includes a protector for the main playfield and the two upper playfields as well as 8 Rollover Adapter Slices.
The solution is a thin layer of clear protective polycarbonate that will protect the playfield as well as give it a glossy finish. Better alternative to cutting and sticking mylar or more time intensive clearcoating of playfield. A perfect solution for games on location as well for easy maintenance and cleaning of the playfield.
.75mm Makrolon product
Custom fit to the game layout
Brilliant look finish
Fast installing
Long time protection
Easily removable without any problems
