The winged monkey on my WoZ 75th. is becoming a bit noisy at certain points when he travels down to pick up the ball, so I figured it needs a little lubrication.
I have the super lube oil with Teflon from Marco Specialties (here is the direct link: https://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=lube), and I was hoping if anyone could comment on if this would be a good lube to get my monkey up to speed again, before I start messing something up.
I was also wondering if I put some lube on the threaded rod, should I also put some on the little "pipe" that the monkey is attached to? I'm guessing that "pipe" is there to hold the monkey in place, but just to be sure.
Thanks for any advice.
