Have a RR with a couple if issues that were not there last time playing it. First issue is when the game boots up , the single door assembly will cycle open and close about 6 times even before a game is started. No error messages. Not sure if there is a switch in there for adjustment or not.
Second issue is the shaker motor does not sound good and is not spinning very fast. Tried adjusting in the settings and did not make much difference. Pulled the wiring connector off , no signs of damage, good pin fit. Took the cover off and the motor spins freely when manually turned. It was working as designed last time played.
