(Topic ID: 205097)
WoZ 6.60 Delta update available now
By vireland
2 years ago
  • 17 posts
  • 14 Pinsiders participating
  • Latest reply 2 years ago by KingPinGames
#1 2 years ago
They just posted the 6.60 update for WoZ. Fixes Toto lights and some other things...
Available here:
http://159.203.76.48/woz/woz_update_660.zip
Reminder: This is a DELTA update, so you only have to copy the folder in the zip to the root of a USB drive, put it in WoZ, and select "USB Update" from the utilities menu. Takes like 10 seconds.
== Version 6.60 December 12, 2017 ==
=== Game Code
* Improved initialization for 2.0 LED system on older motherboards
* Fixed lamp effects on Skill Shot and Toto Escapes
* Tweaked lamp color in TNPLH to be more sepia-ish
* Don't show Today's High Scores page if there are none to show
* Removed adjustment to kick out locked balls at game over (always ON now)
* Toto Escapes: drop target now stays up (just like TNPLH)
+ Added some sounds to a few targets that were silent
+ Added some speech in a few places
* Winkie Drop target knockdown coil hit softer on first kick
=== Core Code
* Fixed audio mixing issue that resulted in distorted sounds
* Fixed ball tracking error caused by losing ball from lockup during ballsaver
+ Added CUSTOMIZATION sub-menu under UTILITIES in Diagnostics
* Fixed a drain/tilt condition that could cause a game to hang
* Suppress knocker when Match is skipped via start button (on free play only)
+ Added check for switches stuck closed/open at power up
+ Added check for any opto switch working at power up; multiball devices will
not kick if no opto switch working
+ Added display message at power up if Test Report error detected
* Trough will abandon kicking after a while
+ Added check for all trough switches closed (including jam); trough will not
kick when this condition detected (likely a failure of the trough board);
game will not start during this condition, and a Trough Error message is
displayed
* Multiball devices will abandon kicking with coin door open now; abandoned
devices will kick when door is closed
+ Added Knocker Strength adjustment
* Turned on Test Report "dot" Paid Play preset
* Turned off Today's High Scores for Paid Play preset
* Fixed "Last Game Scores" displaying after Factory Reset
* Removed erroneous "Coin Door Open at Init" logger event when exiting Diag
* Hide Pindemption presets when not enabled via dongle
+ Added Status Report Start Time adjustment
* Allow main screen scale/offset adjustment on all monitor types
=== OS
* Fix for screen freezing with older motherboards.
#2 2 years ago
what was the last version?
#4 2 years ago
I installed on my Woz and it still says 6.50 did this happen to you?
#5 2 years ago
Quoted from Djsandoz:
Nope. Mine says 6.60 on the system menu.
#6 2 years ago
Heck yes been waiting for the lamp effects to return - WOZ should be done!!!
#7 2 years ago
Nope, my WOZ now shows it as 6.60 as the version number after the update. Did you restart your WOZ after the update?
Gord
#8 2 years ago
Thanks jjp. Updates are like getting random presents when you least expect them...giddyup.
#9 2 years ago
Make sure the directory name in the root directory is correct or the game won’t see it.
#10 2 years ago
I know it’s JJP’s best seller still but it is amazing they are still posting updates for this game!!!
#11 2 years ago
Ding Dong The Witch is LIT!!!
#12 2 years ago
Really good update this. Made the best game even better now. The twinkle affect is back. Better lightening and even more call outs. Merry Xmas JJP
#13 2 years ago
Is this what should be on my usb
#15 2 years ago
Strange to see little action here on this. TWD was another surprise update recently and it generated tons of forum talk. I understood WOZ to be a very popular pin here.
#16 2 years ago
Honestly, I'm very satisfied with my jjp games both woz and Hobbit. They are more than I can handle.
I don't think I'll do any updates at this point.
#17 2 years ago
Quoted from dzoomer:
guess the people that updated their woz are just too busy PLAYING them to come back and post about it.
Gweem's Mods
$ 22.50
Magazines/books
Pinball Magazine
$ 95.00
Pinball Mod Co.
$ 11,500.00
