(Topic ID: 146243)
WoZ 6.00 code
By FalconPunch
  • 378 posts
  • 108 Pinsiders participating
  • Latest reply 3 years ago by ramsfan
  • Topic is favorited by 21 Pinsiders
There have been 7 images uploaded to this topic. (View topic image gallery).
There are 378 posts in this topic. You are on page 5 of 8.
#201 3 years ago
You could always buy a jukebox ☺
#202 3 years ago
If it wouldn't cause a ton of problems. I'd love to buy a woz and downgrade the OS to the earlier revisions. Play for a week, then upgrade to the next revision. Keep going until you're current. It'd be a great way to relive playing the game as updated were coming and basically seeing the game unfold and develop.
#203 3 years ago
FYI ... version 6.06 is now in beta test mode and Keith hopes it will be the final fix for release after another round of testing. Great support and coding from Keith!
== Version 6.06 ==
=== OS
* Fix 26" monitor display.
== Version 6.05 ==
=== Game Code
* 27" monitor scaling/offset adjustment effects are now shown in real-time.
* No-Hold Flippers Crystal Ball mode takes effect after the intro effect.
* HSTD 1-8 now on one page.
* Status report now killed at start of TNPLH.
* Toto Escapes timer now extended for trough kicking issues.
* Fix outlane multiball ballsavers from re-enabling after an add-a-ball
resurrection (as opposed to a new multiball resurrection).
* Fix enter initials cursor position after entering.
* Fix ball lock icons after Rescue Multiball starting.
* Toto/TNPLH add-a-balls are now ballsavers instead. This is more fair and
less abusive.
=== Core Code
+ Boot (and boot reason) audits.
* Coil settings now take effect in real-time to make testing devices easier.
* Fixed issue where quick, soft double-plunging would cause the autolaunch
to kick the ball.
* Special audit now chalked correctly.
* Remove HSTD reset suggestion when switching between 3/11 characters.
* Delayed speech calls no longer interrupt each other.
+ Add video adapter info to HW Info.
* Fix calculation of Average Ball Time (reporting low because of incomplete
games).
* Fix rare crash that could occur if you tilted during certain lamp effects.
* Fix ball serve code that could be kept alive for extended periods of time
if balls drained during serving balls.
* Fix settings backup/restore.
+ Dump Stats - creates a file on USB stick with human-readable audits,
adjustments, etc.
=== OS
+ JJP logo.
#204 3 years ago
sounds like we are getting close.
#205 3 years ago
FYI - Keith said the 6.06 version might be released/rolled out for everyone early next week if the beta testing this weekend checks out ok with no major issues.
#206 3 years ago
Great News, thanks for the update.
#207 3 years ago
I played about 10 games on the latest code (6.06) - upgraded from 5. Have had no issues.
Awesome update.
Startup time is reduced!
I liked the enhanced Glinda lighting effects and a bunch of other code changes are appreciated.
Keith mentioned possible release early this week.
#208 3 years ago
New code has just been released by Keith via the JJP google group
#209 3 years ago
Quoted from goren1818:
download link?
25
#211 3 years ago
We are pleased to announce the full availability of WOZ v6.06!
This is a full installation. It will rewrite everything on your game's SSD. We STRONGLY suggest you backup your settings before proceeding with the installation.
The basics:
Download the WOZ 6.06 iso from this link: http://we.tl/jWu1ZJ7lmn The file is about 3.21G in size.
If you wish to test the file, the md5 checksum is: 9ba0111a76e8b03af0792a8928601d66
The release notes are available at: http://we.tl/WK8Vsr4U7bThis file is about 59K in size.
You will need a program called unetbootin to make the iso into a bootable usb stick. Check the bottom of this page: http://www.jerseyjackpinball.com/game-specific-downloads/
More detailed steps:
1. Download unetbootin.
2. Download the iso linked above. Note that this file is NOT zipped. Saves a step from before.
3. Put a minimum 4G usb stick into your computer, preferably clean (no data on it).
4. Start unetbootin.
5. Specify diskimage of type ISO and select the woz iso you downloaded via the "..." button.
6. Make sure unetbootin picked the correct drive that refers to your usb stick.
7. Hit OK. This will start copying onto your stick.
8. Wait. No, seriously, wait a pretty long time. It will look like the process is stuck around 23% or so, but it's copying a gigantic file. It will finish eventually, I promise.
9. After it's done, eject/safely remove your stick.
[This section is OPTIONAL but HIGHLY RECOMMENDED! If you don't want to backup, go to #13]
10. Turn on your pinball machine. After the game is loaded, insert the memory stick.
11. Back up your settings. In diagnostics, Utilities->Settings Backup->Settings Backup. Yes, it's ok to use the same stick as the installer is on.
12. After it's done, turn your game off and wait 10s or so. Leave the stick in.
13. If your usb stick isn't in the game yet, put it in now.
14. Turn on your pinball machine.
15. Wait for process to complete.
16. Remove USB stick and turn off your game.
17. Wait a few seconds, turn game back on.
18. [Optional] Restore your settings by putting the stick back in and choosing settings restore similar to above. Remove stick when done.
19. Enjoy 6.06 now!
Let us know if you have any questions or issues!
#212 3 years ago
Quoted from JerseyJen:
The basics:
19. Enjoy 6.06 now!
Thanks Jen!
Glad to have you still around
#213 3 years ago
Sweet! Now if it would just download faster!
#214 3 years ago
blocks here even before update starts... What to do?
tried 2 different usb sticks
#215 3 years ago
Well worth the wait!!! It's a whole new game since 4.x. Thanks Kieth and JJP.
#216 3 years ago
Quoted from gawcol:
Believe there's a few of those. You should see this soon unless of course this is after you did the update?
#217 3 years ago
seems like it's stuck... I don't see any activity on the usb stick led and the screen on my picture stays...
how long should the update take normally?
#218 3 years ago
Ahhhhhh! I just left for vacation. Now I have to wait til next week to update. Why couldn't you wait 1 week to release it???
Seriously though, thanks to everyone at JJP for this! The game keeps getting better and better.
#219 3 years ago
Quoted from gawcol:
Corrupt or incomplete download? Verify the ISO md5 checksum is: 9ba0111a76e8b03af0792a8928601d66.
#220 3 years ago
The update itself usually 5 mins or so I believe.
#221 3 years ago
Any release log?
#222 3 years ago
Quoted from Tekman:
I've run the uneboottin, selected the WOZ file, installed to the proper drive.
I'm not sure if it fully installed onto my USB stick.
How can I check this?
I did a properties check on the thumb drive,
It says 3,448,520,704 bytes.
#223 3 years ago
Quoted from indypinhead:
On Windows, go to Computer, look if there is 3.12gb on the USB drive.
#224 3 years ago
Installed without issue!
#225 3 years ago
Quoted from LTG:
Mine is showing it has 3.21 GB
#226 3 years ago
Thanks for the help guys. It was indeed a corrupted download. I checked the file with winmd5free,
that could be found here http://www.winmd5.com/
The checksum should be 9ba0111a76e8b03af0792a8928601d66
#227 3 years ago
My power is out. Ugh!!!!
#228 3 years ago
You got it, throw it in the game.
#229 3 years ago
Ive had issues when doing a full update if I don't empty the trash with the old code in it. Once the trash is emptied it will fully download.
#230 3 years ago
Just installed the update.
I went from version 4 software to 6.00
Before playing a game, I re-installed my settings, then went into utilities and changed the high score settings to accept 11 characters.
Played a game...got high score #8...put in my name...then noticed that the high score screen showing my name isn't centered...the left side was cut off.
Never noticed that before using version 4 w/ the 3 character setting.
#231 3 years ago
Code, won't fully download from WeTransfer. Craps out at around 269MB. Tried emptying trash, but still won't download fully. Any ideas?
-Steve
#232 3 years ago
I had trouble going to the 5.05 code my solution was the buying the updated stick from Rob Anthony. I'm not even going to try the kids couldn't do it.
#233 3 years ago
Worked 1st time for me. Download took about 12 minutes. Putting it onto the USB with unetbootin took a little longer but all good and it up and running on the game.
#234 3 years ago
Trying to download the update now. I am using a mac. About halfway through the install i get a message saying the stick wont work on a mac and try again on a pc. Any way to fix this?
#235 3 years ago
Just played a few games on it, things I'm really liking:
Faster startup time, and not just a little faster! The new display information when the ball is on the castle mini PF is great, tells you if you still have to capture Dorothy, how many balls are locked and how many hits to the castle doors are left before they open. New Glinda animations are pretty sweet, although some may complain about all the pink lights. I didn't read through to see if it's a setting but I was also awarded a Rescue lock from the Throne Room before I restored all my settings, that was a cool surprise. Audio clipping sounds to be greatly reduced from 5.05 as well.
Thanks to the JJP for the continued awesome support of this game!
#236 3 years ago
Quoted from bobukcat:
Agreed, way faster startup.
#237 3 years ago
Finally downloaded fully (4th times the charm). Love the new castle animations, though only one castle door is opening for me. It looks like the right door is trying to open but won't, even hitting it with the ball won't nudge it open. Anyone else having this problem?
-Steve
#238 3 years ago
Download is excruciating. 5th failure and downloading at about 80Kbps even though my cable speed is 17Mbps. Must be too much traffic. I'll wait a few days until the crowd disperses. Maybe rent some space on Amazon servers?
#239 3 years ago
Quoted from TimeBandit:
I had the same issues. And I got it in beta... So nothing to do with traffic. I might see if I can rehost it for you but would take a while to upload
Not sure why it's not hosted with them
#240 3 years ago
Timing was perfect...got my RR yesterday and played it for a bit with the 4.11 installed code and noticed this on the website. Took about 30 mins to download, but other than that the install went smoothly. Played well into the night...with what little play I had before, I can tell the new code is going to be sooooooooo much better. Thanks
#241 3 years ago
Alright...got the code installed. I'm speechless...this game is so polished...so awesome... the subtle touches added to the lighting experience is superb...especially the effects associated with the rainbow letters.
If you haven't played WOZ recently, this new code is going to rock your little pinball world.
A+ stuff, JJP. Well done.
#242 3 years ago
Agreed. Why does it feel like I'm trying to download a pirated game from one of those sketchy download services?
#243 3 years ago
IF Hobbit gets the same love and attention that Woz gets, I think a lot of people are going to have to eat some HUGE plates of crow.
#244 3 years ago
My download went fine. Thanks JJP!
#245 3 years ago
Guys I can't seem to get this to work. Each time I download the file, and I walk away and let it go as long as it takes, I can't ever get it to download at the 3.21 gigs that the JJP website says it should be. Tried 2 times last night and it "finished" but was under a gig. THis morning I got a 1.3 gig file. Any suggestions?!?
#246 3 years ago
Quoted from cscmtp:
Have you tried a different browser and / or clearing your browser cache? Also make sure you delete the failed downloads before starting another one.
#247 3 years ago
Quoted from cscmtp:
I think it's just hit and miss. I was able to download the previous (5.05?) with no issues, but this one I've tried from both home and work and get the same kind of results. I'm up to 1.0GB on my current attempt. Good luck.
#248 3 years ago
Tried using IE after it not working with firefox several times. same result.
#249 3 years ago
Not sure why downloads are failing so bad. You can get a pre-imaged USB stick from the Products page of my site, with the latest code...
www.LockWhenLit.com/Products.htm
Keep trying to get the download on your own, because it does work, but if you just can't, there is another option.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
#250 3 years ago
My "other option" will be to stop by DCFAN's house on the way home from work.
6,995
Milford, CT
$ 114.95
Blacklick, OH
Gweem's Mods
$ 28.00
