Quoted from rockrand:If you are the original owner you can get on the list for full buffered replacement for about 700.00 and that should be pretty reliable,I did it and it has been great
I'm pretty sure all the boards I had were the latest revision. The more frustrating part was out of the say maybe 10 replacement boards I received NIB 8 of them worked. So I had to send back the broken ones this happened almost every time I ordered multiple boards. At that point I was being extremely cautious in my handling.
I love the game, it was just a shame that it had so many led board issues. Like I said I've had it in my house for a little while now and haven't had one issue with those boards. As soon as I finish with a few things I'll be bringing it back through the rotation and if it continues to cause problems, I'll probably sell it or retire it for home use. Maybe some locations got lucky, but I've heard of plenty of other operators retiring their WOZ due to this. Maybe because it was on 16-20 hours a day everyday, maybe static, maybe a combinations of other factors.
I'm well aware that no company is perfect and I don't fault them for it. I try to do everything in my power to mitigate the damage. EX. Almost all of my golden tees freeze up on a somewhat regular basis causing me issues and lots of frustration. The ones that don't freeze probably would if they got the same amount of playtime. I spent over 30hrs going through each affected cabinet verifying the there were no loose connections that the air flow was good, voltages and anything else I could think off. I even added more ram into every mobo. Finally concluded that there was nothing I could do about it, since it was more then likely software related. sometimes they go 6 months without issue, and sometimes one or more freeze 3 times a day for a week straight.
So your basically left two options sell it or put up with it. With both these items I wish there was a 3rd option.
