I am running 1.18 and am having some issues and am curious if others are see problems and what they are.
1. If player 1 gets Dorothy captured, the ball stays behind the single door. If player 2 gets Dorothy captured the second ball just captured sits behind the single door leaving 2 balls behind the single door. The game will now go through ball search, the single door will never be opened and the glass has to be removed to get the two balls out from behind the single door.
2. I've noticed a few times during a game, when a new ball is ejected out of the ball trough outhole into the shooter lane waiting to get manually launched by the ball shooter the machine will go through a ball search after about a minute. I've noticed this when walking away from the machine to do something in-between balls and then hear the machine searching for balls.
3. There has been a number of times where a ball would get behind the castle double doors and with the doors closed the game will go through ball search. The problem is that the castle door VUK will try to kick the ball out when the doors are closed and does not try to kick the ball out when the doors are opened. The glass needs to be removed and the doors have to be opened to get the ball out.
4. While the game is set for free play, I've hit the start button and the game will ask to insert quarters. I can go into settings and see that the game is set for free play. Power fail the game will resolve issue.
