as part of sourcing parts for the restoration of my CftBL, I've procured enough extra components to put together (4) WPC line filter assemblies (120v)
these include the following:
- the IEC 300 box & inlet plug (that your pinball cord plugs into the wall from)
- 14awg wire running from the IEC 300 box to the service outlet box
- service outlet box
- fuse holder
- line filter
- service plug outlet
- thermistor
- varistor
- power switch
- fuse and voltage rating stickers
- 14awg wire running from the service outlet box to the transformer (including the discontinued & no longer available molex connector)
all items used to construct this assembly are either brand new or NOS parts and everything has been assembled period correct (with the exception of the 3-conductor bonded wire running from the IEC to the service outlet box [which is no longer available])
3 of the assemblies have a factory zinc plated IEC 300 box and galvanized steel service outlet box
the 1 remaining assembly is slightly nicer and features nickel plated boxes (courtesy of Z-Plating)
marco specialties is the only place that I know that used to sell these but has been out of stock of them (and just about every component necessary to build them) for a few years now
