As a follow up, I may still have an unresolved issue with the interaction between the Alltek MPU and the factory sound board. At least the -50 one for Paragon.
I never did work out this issue on why the sounds were slightly different since I have a limited amount of skill and testing equipment, and up to this moment I had concluded that it was attributable to slightly higher than normal voltage readings on the power rectifier board having an effect on the -50 sound board, or that the -50 board I have is out of spec.
But I have been speaking with another pinsider about his results on swapping in a new 9.1 version Alltek MPU and he is also noticing a difference in sounds between the original MPU and the Alltek one.
What I personally found curious is that when I plug in the Embryon sound board and playfield set up, the sounds are the same (to me) between the original mpu and the Alltek one. With the Paragon -50 sound board the sounds are an octave off.
This is my "pin2k minus 20" setup, so everything else is the same and as I need to have the ability to easily go between game roms I have accepted it as a side effect of the Alltek.
Quoted from NJGecko:Curious to hear this as well...the sound on my Paragon is not quite right too, but I haven't even looked into it since the entire machine is about to get blown apart for restore.
Could also be the capacitors on the sound board?
