Getting more and more into my World Fair now that its working. I have been cleaning it up and trying to learn the rules of the game. Just came to the realization a few days ago that when the disc in the middle spins it is supposed to award you a rollover spot. Mine was not doing this, did some digging and realized I was missing a disc under the spinning disc mech that had been removed and was luckily put in the coin box, its in the first pic below, all it has is one switch with a spring around it. So I replaced it, but I am still not getting the spot rollover when it spins during the game.
However, there is a feature you can choose for the machine where at the start of the game you get a spot rollover for whatever number the disc is already on, and it does award that, just not during the game when you hit a bumper and spin it. Checked the two "spot award and spin" I believe they were J and K relays and the swicthes all were fine according to schematics. So I am a little stumped. I also turned that feature that gives it to you at start of game off by switching the little plug and it turns off, and worked again when I replaced the plug.
So to reiterate.
At game start you are spotted for whatever number the spinning disc is already on.
Once you start to play and you spin the disc it no longer rewards you the spot.
Once you start a new game it will do the same thing.
It seems like this means that the switch registers right? Can someone with a World Fair check something for me, see the pic below. In the first one you can see how the little switch lands, is it supposed to land between the two contacts, or on just one of them? How much back and forth play does your disc wiggle? Mine wiggles a little, sometimes after the disc rotates the little switch with the spring on it does not make good contact with those rivets. Also in the second pic, am I missing something here, the switch comes through this bakelite and then through a wire goes to that screw then goes back through another wire back to the switch, it kinda just makes a loop. Correct me if I am wrong as I am still learning, but to me that indicates the switch should be between both contacts so it acts as a link between them. Last picture may not be needed but I am including it as a better pair of eyes or someone that has this machine may see something different than mine.
Lastly, is there a way that this feature may have been turned off because it would be considered gambling as it leaves it up to chance? Is there a plug I am missing that lets you choose that?
