(Topic ID: 159779)
World Fair sling shot adjustment question
By phillyfan64
7 years ago
#1 7 years ago
I have a World Fair machine. I recently purchased a new set of plastics from Pinball Rescue. Before I install them I'm trying to figure out what to do about these sling shots. As you can see from the picture the center arm appears to be too high and it has scratched and warped the old plastics. I looked underneath and I don't see how to lower this. Can anyone give me an idea on what to do here? Thank you.
#2 7 years ago
For a quick fix......Raise the plastic by adding some washers or spacers under the plastic. You will have to take out the two screws to do this.
#3 7 years ago
Phillyfan................You should have 2 different size metal posts on your game. You have the incorrect ones at the slings. Look around the playfield, you should have slightly taller posts under each plastic and the stainless steel rebounds at mid-playfield, (reference the database). The 4 white and 2 yellow rollover guides should have the shorter posts such as what you currently have under the slings.
#4 7 years ago
Straighten your plastics after finding the correct posts. GREAT EM.
#5 7 years ago
Ron's observation would be one way of solving the issue.
However, neither of my 60's wedgeheads had the C-8174 High Caps (see diagram below from the Gottlieb 1968 parts catalog) on the slingshots.
It also appears your game may not have the correct A-8857 fastening screw with the thick platform head. That should raise your plastics by about 1/8".
Try either of those potential solutions.
Lee
#6 7 years ago
Quoted from Runbikeskilee:
Lee
I restored one of these, no screw posts and caps on mine, from the pics the jewel posts under the slings appear to the tall ones. Game is gone unfortunately.
#7 7 years ago
I didn't even realize I had two different sized posts but I sure did. I'm switching them out now. Thank you guys!
#8 7 years ago
By '68, Gtb. was moving away from metal posts. The only domestic game I could find in the database using metal posts in '68 was Palace Guard and sample Royal Guard games. Referencing the database, Palace Guard clearly uses both sizes.
The fastening screw shown, (A-8857), did not show up until '65, when Gtb. started using acorn nuts to secure the plastics, (Kings & Queens, Hi Dolly). World Fair uses a fastening screw with a slotted top that screws down flush with the plastic.
#9 7 years ago
From the photos on ipdb, I think that Ron was completely correct with his observation regarding the high cap being the correct part for the slings for World Fair.
OTOH, I have two wedgeheads from 1965 and both (B-A-B and K&Q) came to me with the C-8173 low cap and the A-8857 fastening screw. That config also serves to raise the plastic height. Not to say that photos on ipdb are always 100% correct, but the photos of my '65 machines seem to agree. Gottlieb probably figured out they could save a penny or so by subbing the screw for the higher cap???
#10 7 years ago
Thanks again everyone. I switched everything out. Great job by Pinball Rescue on the new plastics. My machine has a total of 10 of the higher caps. I now have 6 of them on the sling shots, the other 4 are on the long vertical metal bumpers on the far left and far right of the machine. Everything else has the shorter caps. I also purchased a new plastic wheel but I haven't installed it yet. It doesn't come with the metal rim around it so I'm not sure if I want to use it.
#11 7 years ago
Your old one looks fine but you can move the ring over if you can press rivets.
#12 7 years ago
Yeah I think I want to keep the metal ring. I guess I would have to drill out the old rivets. I'm not sure I even want to risk that.
Cabinet Parts
Space Coast Pinball
Cabinet Parts
$ 29.00
Pinball Photos LLC
This page was printed from https://pinside.com/pinball/forum/topic/world-fair-sling-shot-adjustment-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
