I'm no WPC-s expert, but I'm hoping that one of you who is can provide some guidance. Here goes:
It started with the "check fuse F114 and F115" error code. F114 was blown. Replaced it and it blew again. That led me to suspect BR1 had shorted, which it had. Replaced BR1 with a correct new one and assumed that I was done.
When I reinstalled the board and powered the game up, the LED's flashed in the correct sequence (D19 on and off, D20 constant flash, D21 constant lit). However, only the GI circuit was lit and the DMD display only showed one vertical bar across part of the display. After staring at the machine for a few minutes, the board rebooted itself and went into attract mode, ostensibly suggesting a successful game start. However the DMD still displays just the vertical line. I tried the obvious, like reseating all the connections and ensuring all were keyed correctly.
Any ideas on what is causing the delayed start and the unhappy display? TIA!
