Ok so I finally got my CPU board (from a Dirty Harry) and while waiting for the security PIC to arrive I thought I'd have a google around to see if on the off chance there was a hack for WPC and to my surprise and delight.. there is!! I used a little app called anypic (google anypic.exe) which patched my rom and let me use the dirty harry chip!
Anyway, now it works (mostly) I've a list of issues I've come across:
1. Saucers are weak and "spongy". The don't even kick out about half the time. The saucer by the goal is also permanently stuck up. I can push it down but it slowly raises all the way back up. The others are similar and it happens even when off. Could the coils be screwed or might a clean (no lube on the sleeve) help?
2. The goalie is ALWAYS on from the moment I hit the power switch. In test when you activate him it does sound like the motor ramps up slightly. No idea on this one.
3. The lock sound never plays, it just keeps playing the main theme?? I think this might actually somehow be to do with the fliptronic board as the previous owner said it did strange things with his fish tales' audio. Any idea why?
4. However much I tighten the left flipper it just keeps shifting up, as if it's not tight enough?? Also I get a nasty shock every time I go to adjust it, even with the power unplugged from the wall, normal???
5. I didn't get any backglass or playfield glass with this, just the translite insert. What do I need to finish it off? I'm sure just sticking a bit of glass up the top won't do, seems like there should be some plastic parts and something to hold it in? Also what dimensions/thickness/glass type do I want?
Sorry for the large post, hopefully someone can help me out, I've been waiting to play this for months and now I just want to get it finished or at least playable!!
