I was searching for a broken machine as a project donor and came across this Alien Poker about 3 hours away. I went and looked at it and picked it up. It was/is in rough shape. Cosmetically the cabinet is not too bad, but the playfield is pretty well worn. When plugged in, some of the backbox GI came on and the Player 1 and Match/Credit displays went into the Audit Cleared mode. Nothing else worked.
I fiddled with it a while tonight. Imagine my amazement when I discovered that the GI issue was simply that every single playfield and coin door bulb was burned out! It was obvious that this machine hadn't seen maintenance in many years but that took the prize. Of course, the rubbers are shot and the playfield is filthy. Many of the plastics are also broken or cracked, and the backglass is quite scratched up and flaking.
I have determined that there appear to be 2 big issues. The MPU needs some attention to remove the battery holder and wire in an off-board replacement. The existing one is corroded on one of the battery pads. Fortunately, the MPU itself seems free of corrosion, at least on the front side. I jumpered the broken battery pad and was able to get the MPU to boot and enter attract mode using the rapid power-off, power-on trick, as well as start a game once I coined it up, so I believe it is mostly OK. I'll know more tomorrow. There could still be a 5101 issue there.
The second issue is that no solenoids are firing except the flippers. I was initially thinking blanking signal, but then realized that the lamps and displays are all working, which rules that out. I ran out of time tonight but I am thinking solenoid power now. I did meter the fuses earlier and they were OK, but tomorrow I will need to check the bridge rectifier, varistor and caps in that circuit as well as the input power from the transformer.
Anyway, here are a few pics after tonight's lighting work. Sure looks a lot better than it did when I started!
