(Topic ID: 165949)
Working on a Genco Argentine
By Toyguy
2 years ago
  • 56 posts
  • 11 Pinsiders participating
  • Latest reply 1 year ago by Toyguy
    There have been 29 images uploaded to this topic. (View topic image gallery).
    There are 56 posts in this topic. You are on page 1 of 2.
    #1 2 years ago
    I just picked up a project Argentine. I thought I'd start up a thread to keep questions and progress info in one place.
    Here's an overall view:
    Small areas of playfield wear and some loss of ink on the backglass, but not a complete loss by any means.
    Here you can see some of the corrosion on the wire forms and what looks like heat warping on the bumper skirts. Almost all of them are that way, so I'm thinking this sat in the sun at some point, though the colors really aren't all that faded. It's a bit odd.
    I did a little test cleaning with Novus 2 - looks like the playfield will clean up nicely:
    I'm going to try using the Shapeways part for these diamond posts:
    Most of mine have been replaced with improper round posts, like the one above the green bumper here. On a side note, anyone know of a source for half-round rubber as used on the outside of the playfield area?
    Now the first of the tech questions. The game is stone dead. Tomorrow I'm going to check the line cord and make sure I have AC at the transformer. Does anyone happen to know what a Genco transformer from 1940 would put out for voltages? I also know they used a rectifier, so if AC looks good I may look at swapping that out.
    Dave
    #2 2 years ago
    Looks pretty cool. Should be fun once you get it all sorted out!
    #3 2 years ago
    Quoted from Toyguy:
    There should be a label at the fuses that tells you the amp value and voltage. If I had to guess (and it's only a guess), you'll have 120, 30v and 6v.
    #4 2 years ago
    Quoted from Toyguy:
    If it has a disc style rectifier on top of the transformer, you're probably going to want to replace that with a modern silicon variety. Fuse one side of the AC input, too. The original rectifiers look neat, but they usually get worse and worse at their job (more and more AC voltage slips onto the DC line) until they fail catastrophically.
    I wonder if the pop bumper skirts would flatten back out if you sandwich them between a couple pieces of glass and stick them in the sun.
    #5 2 years ago
    This does not have a disc rectifier. It looks like a large black elongated cube. Once I see if the tranny is good, I should be able to see if it needs replacing. Probably does...
    #6 2 years ago
    OK , so I have determined that the power wiring in this machine is junk. It's falling apart in my fingers and is likely broken or shorted so it all needs to go.
    The transformer is marked Start on one lug then a bunch of voltage lugs like 115, 125 etc. with 125 connected. What I don't know is which power cord lead goes where. Anyone know whether the hot or neutral lead would go to Start?
    #7 2 years ago
    Usually the transformer could have a lug labelled 0 or something else (why not 'start'?) and a bunch of other lugs ranging from 110V to 115V, 120V...all the way to 240V. Best would be for you to post a picture if you are not comfortable with electrical circuits.
    Yves
    #8 2 years ago
    OK, here's what I have. This is the input side of the transformer.
    Leads were connected to Start and to 125 originally. There was a tag advising the operator to change the tap based on the line voltage and you can make out terminals for 115, 105, etc.
    The 125 wire had a ring terminal on it and went to a screw in the playfield that was used to connect the line cord wire to the transformer wire. I'm using a terminal block instead for a more reliable connection as well as to accommodate eventual grounding of the transformer case.
    The START transformer wire runs all the way around to the bottom of the playfield to another terminal strip that leads to the fuses. There was one more screw in the playfield that connected the second line cord wire to a wire that also ran up to the fuse block terminal strip. I know where everything goes on the playfield and transformer wiring and am replacing that all with new wire.
    What I am not sure of is which line cord lead went where. One or the other of them will have to go directly to the 125 transformer lug. The question is which one - hot or neutral? The START notation on the transformer label is less than helpful and no schematics exist that I am aware of.
    This is the output side of the transformer with the antique rectifier. I'll worry about converting that to a bridge later
    #9 2 years ago
    Great. So, obviously your transformer should be connected to Start and to the 110V lug (we are in the USA and the voltage is 110V). It will give you a slight little increase in flippers and pop-bumpers power.
    Good idea to install a connector for the transformer.
    I would get rid urgently of that old rectifier. It is a pending disaster..... Also, add a fuse in the primary circuit of the transformer if you do not have one already. 2 Amps (2x110v = 220Watts) should be amply sufficient.
    Also, use shrink wraps around your primary connections (Start and 110V lugs). You do not want any of these in contact with your skin.
    Whether you connect the Line to Start or to 110V is not important as long as any of these wires are by themselves. The ground connection should be separate.
    You should wire the primary circuit (110V) independently of the playfield. The playfield should only receive the voltage for the bulbs (6.3 Volts) and for the coils (usually less than 48V).
    A clean and safe electrical circuit is essential to avoid fires, hazards and shocks.
    Yves
    #10 2 years ago
    This guy made some half round rubber for P&B machines. It might be a good option for your side rails.
    https://pinside.com/pinball/forum/topic/baseball-pitch-and-bat-d-shaped-playfield-rubber#post-2730462
    Also I can't find it now but somewhere Clay has some nice detailed info on replacing Genco selenium rectifiers with a modern bridge rectifier.
    You will have to skim pinrepair.com EM repair section to find it.
    #11 2 years ago
    Thanks guys.
    The plan is to definitely replace the old rectifier with a modern bridge once I can figure out how to do that. The power wiring will be mostly as it was from the factory, just with new wire. The primary is fused already and I'll be adding the ground to the transformer case. The rectifier output feeds the coils and there's a separate lead out from the transformer that I will guess is 6V. I'll be testing those outputs once I get the power wiring replaced.
    Thanks for the tip on the half-round Alex. I've emailed that pinsider directly.
    Dave
    #12 2 years ago
    The rectifier wiring should be pretty simple. Here is Clay's picture of it:
    http://www.pinrepair.com/em/genco1.jpg
    It's not identical to yours, but the same strategy should apply. The two outer wires from the transformer to your old rectifier are the AC lines, the middle line should be positive DC and the lug on the side of the rectifier should be negative DC. The new rectifier should have two corners labeled ~ that get the AC wires hooked to them (makes no difference which goes where), and one corner a piece labeled + and -. They get the + DC and - DC wires attached to them, respectively. You want to disconnect the AC and positive DC lines from the old rectifier altogether.
    This thread ( http://www.pinballcontrollers.com/forum/index.php?topic=1304.0 ) suggests the "Start" lug is the common, so it would get the neutral wire and the hot wire would go to one of the voltage inputs. I'd say high tapping it at 125 isn't really necessary since it's going to be DC rectified. I'd probably put it at 115 or 105.
    #13 2 years ago
    Need a little sanity check here. Here's a rough hand-drawn schematic of the power-side wiring as it currently sits:
    Everything shown connected is in fact connected that way on the factory wiring. I've replaced the power cord side and the wiring going to the 125 terminal on the transformer, as well as the wire ending in a question mark. Over the weekend I'll be replacing the rest.
    The sanity check is on that unconnected wire with the question mark. It was unconnected to anything and looks like it just broke away. That 6-position barrier strip is at the bottom of the playfield and the loose wire is just hanging there. I traced it by hand back to the 3 position barrier strip at the top of the playfield where the line cord connects.
    My gut says this has to go to position 4 on the 6-position strip, 4 being fourth from the left. It doesn't seem to make sense to put it on 6 where it's directly connected to the Start lead but who knows?
    Position 5 has nothing connected to it and 1-3 have small gauge signal wires going to the coin door connector so I don't think it would go there and there's no sign of anything else having been there. There's some good gobs of solder on 4 and 6 though.
    Anyone have any thoughts on this?
    #14 2 years ago
    Hmm. It would seem to make sense to put it on terminal 4. If the timer switch is closed, then it keeps neutral connected to Start. When the timer drops out, that connection drops out too. Do the wires to the coin door go to a start button/coin mech switch?
    Just taking a guess, I'd say it goes on 4. The game is totally dead until you close whatever switch on the coin door wakes it up. It comes to life momentarily, long enough to engage the timer, which holds on the game through 4 and 6 on the terminal. When the timer runs out, the switch opens, neutral is disconnected, and the whole game would go dead.
    Do you happen to know if the timer is for sure original? Clay always seems to be removing timers from games in this era, where they were added by operators to keep people moving along.
    Oh, also, in case my description of hooking up the rectifier wasn't good enough, here is a Microsoft Paint illustration.
    Genco to Modern Rectifier Modification
    Obviously, you don't have to cut the wires where I put "Cut" just desoldering them will suffice.
    #15 2 years ago
    Thanks Joe.
    Yes, the timer is original and is operated by the coin slide via a push bar. The coin door switch is activated by a coil on the coin door that pulls in the blocking lever for the coin slide so it will push in without a coin inserted. The switch would be normally open when a coin was required and closed when a coin was not.
    With the loose wire on 4, the circuit would be completed when the timer switch closes. It would also remain completed if the "free play" coil was pulled in on the coin door, allowing the machine's lights to stay on, etc. even when the timer expires as long as credits are on the game.
    I think this makes sense electrically, and it would operate in the same way as my other flipperless game.
    Thanks VERY much for the bridge diagram. It was tough to make out from the photos on Clay's site and from IPDB. The bridge should be in shortly so I'll get that done too and hopefully be done with power.
    Dave
    #16 2 years ago
    I had completely forgotten about my adventure with the rectifier in Seven Up/WS43. Forgot why I made a bridge out of diodes, must have had the pieces. Anyway, here's a few pix...
    The wires from the transformer are really stiff and I didn't want to mess with them. What I did was to take the large through-bolt out of the old selenium rectifier, and replaced some of the metal washers in the stack with fiber insulators. This allowed me to use the old bridge as a terminal strip and not disturb the transformer wiring.
    Hmm.. Rectifier bridge made from diodes does look slightly less newfangled than packaged unit - maybe that's why. It looks like I used a terminal strip scrounged from '70s Williams, some wire from same, fuse and clips, and 6A05 diodes.
    The green wires are AC and the red is DC+
    Other questions....
    Voltages - I'm pretty sure Genco solenoids run around 18 volts. The lights are 6V. #40 bulbs will run cooler than #46
    The timer is probably a holdover from a few years earlier when pins ran on batteries. This seems more likely than the hurry-up thing that keeps getting repeated. The timer runs for five minutes or so - who couldn't finish a game in that time?? Seven Up only has one GI lamp in the whole game - another likely holdover from the battery era.
    Taco-shaped bumper skirts - plastic warped but paint not faded.. How does baked in a hot dark attic sound?
    D-shaped rubber - that black stuff looks ghastly. There is some D-shaped white rubber weatherstrip at the hardware store. It looks pretty good but has nearly no bounce(it's hollow). Watch the youtube video of Seven Up for a look at some.
    Here's some I made from GE bathroom silicone. Good bounce and looks like the real thing.
    #17 2 years ago
    Finally got the power-side wiring replaced and all hooked up. I lubricated the timer with some light Teflon oil and it's now working nicely and the timer switch connects and cuts off AC to the transformer as it should. I'm getting 120V AC across the 125 and Start terminals, so I may move that tap down to 115.
    No other signs of life yet but I've done nothing with the rectifier yet. That's on tap for tomorrow night.
    Anyone know what that single transformer tap is at the bottom center of the output side? Is that supposed to be 6V to the lamps?
    #18 2 years ago
    Quoted from Toyguy:
    Sounds about right.
    #19 2 years ago
    A little good news tonight
    Hooked the playfield back up to the backbox, cycled the slide bar and, yes!, we have some lights. Not many, but enough to know the transformer's 6V circuit is working. No other signs of life though, so I am guessing there's no solenoid power. That puts the bridge conversion to the top of the work list.
    #20 2 years ago
    Bit more progress tonight. I made the conversion to a modern bridge and I now have solenoid power. Rollovers are advancing one of the units, and manually activating some of the backbox relays does other things. What I assume is the lock relay pulls in and holds and each of the bumper switches latches in a relay in the bank. One backbox unit is bound up, so that will need to be torn down and I'll need to go through the relay bank switches and make sure they all look good.
    After making the conversion I lost all my AC lights but I may know why. I cut the DC - lead from the old rectifier and I'm now wondering if it needs that connection and I should have just run a jumper over to the bridge.
    #21 2 years ago
    I think it needs that connection. See second pic in above post.
    #22 2 years ago
    If you put a meter lead on the one lug by itself and touch the other lead to each of the other three lugs and negative DC lead on the chassis, one at a time, one pair should give you 6VAC.
    #23 2 years ago
    Yeah, thanks Joe, looks like I'll need to do that. I popped a jumper wire in between the DC - on the bridge and the original spot that wire came from but no dice - lights are still out.
    #24 2 years ago
    On further reflection, it should be one of the AC lines. Here is another MS Paint special illustrating it. Two AC wires go together to give the AC voltage that the rectifier turns into DC to drive the solenoids. The one AC wire by itself and one of the other two AC lines gives you your six volts AC for the lights.
    #25 2 years ago
    I'm not quite sure how I'd hook this up. I've got the two outer wires on the transformer secondary hooked to the AC inputs on the rectifier. The center secondary wire goes to DC + and the wire from the rectifier frame is now on the DC -. Are you thinking I need to run a wire from one of the AC secondary leads to DC -?
    I should note that I removed the old rectifier completely.
    #26 2 years ago
    Gah, you're right. You are short a wire for that. Hmm. Well, I guess it's back to testing the wires with your meter.
    You could also check for continuity between the wires going to one of the lightbulbs. I see one side of the light socket going to that lone lug on the transformer. Where does the other side go? Find that out and you know what to hook back up to get back the lights.
    #27 2 years ago
    No luck yet. I know where the 6V is. It's between that lone bottom tap and the center lug at the top of the transformer, the DC+. I've run a jumper from that center lug to DC+ on the rectifier but nothing so far. I pulled the mechanical board out of the backbox and metered the socket back to the Jones Plug, then down into the cabinet. One side goes direct to that lone tap. The other, oddly, goes to a switch that is activated by the coin slide bar, but it's only momentary.
    Tomorrow I'll have to meter with power on to see if I am getting 6V at the Jones plug. If so, maybe all the bulbs just went. Seems odd but who knows. I'm going to jump the 6V direct to the mechanical panel and see what's what also. That way I can at least ensure all the bulbs are good.
    #28 2 years ago
    If you check for continuity between the other side of the lightbulb and the four wires on the new rectifier, are any of them connected?
    #29 2 years ago
    Yay! Lights are back. Turned out they did blow and putting in new ones didn't work because of socket corrosion. Looks like I'll either need to wirebrush or replace all of them. The two I cleaned with the brush are now working so I may be able to save some.
    Started rebuilding the steppers today. As usual, they are gummed up beyond belief. I had to pry the wheels off, they had so much dried grease on the shafts. The picture is after cleanup on the shaft but before polishing. I still needed to clean the grease from the backplate in this shot.
    It was actually a good thing I had to disassemble them as both had broken leads on the wiper rivets. Very difficult to see with them assembled so I may have missed it otherwise.
    One all re-assembled, the other in progress. Interesting that only one has an end of stroke switch.
    Anyway, tomorrow the mech board goes back in once I get the backglass out. That needs sealing and then some art repair. Fortunately it's an unlighted area so if I can get even close to the pale blue sky color, it should work out alright.
    #30 2 years ago
    Good luck. Hope it comes out awesome! Always been afraid to try back glass touch up after some of the nightmares I've seen. Lol. Post a pic after touch up.
    #31 2 years ago
    Just bad bulbs. Hilarious. Well, at least it's working now. Keep us updated on your progress.
    #32 2 years ago
    Glass out, mech board back in. Tested a little and a surprising number of the lamps are now working. Still a large number to replace and new ones should be here any day now. Tested the one unit with a reset and that's working fine on game start. I've got a problem with the lock relay not holding though - it seems like it pulls in but won't stay in while the timer bar is being cycled, but if I press the armature by hand afterward, it will lock on and hold. Some sort of timing thing I suspect so I'll have to hunt that down.
    Glad to have the power conversion out of the way though - that's working nicely.
    I have to say I don't get the scoring on this thing from looking at the backglass. There's the main score numbers visible at the top, for 1,000-9,000 then 10,000 to 70,000. That makes sense. There's also a row of hidden numbers in the green strip at the bottom of the glass that run from 1,000 to 7,000 on the left side and 100-900 on the right side. You only see the ones that are currently lit, sort of like a match digit. I've no idea what they are for or why they'd be needed and the instruction card is no help whatsoever. There are also some lights for A & B and the bumpers 1-6 plus the three dance lights, but they all make sense too. If anyone's got any thoughts on why there would be that series of numbers at the bottom, I'd love to know. They seem to be driven by the stepper without a reset.
    #33 2 years ago
    I would think that it's a match unit. Since it's on a continuous stepper, just like later match units, and the numbers correspond to the first four digits of the lowest to the highest possible scores. Are the hidden numbers lit up all the time, though, rather than just in Game Over?
    #34 2 years ago
    It seems like one number is lit up all the time and as I advance the unit it will count down, or up, depending on which way I go - for example, 6800, 6700, 6600 etc. It also rolls over appropriately, 6900 to 7000 or 6000 to 5900 going the other way.
    I got to wondering if it's not some form of credit counter disguised to not look like one. If you discarded two zeros, you'd end up with a range 0-79 and that would make payout simple - just multiply by 5 for a nickel machine or 10 for a dime machine. Since there's no provision for hundreds in the main score area, it would be pretty hard to match anything. If the taxman was around, it would just look like some other score counter.
    Only other thing I can think of, but the instruction card makes no mention of it, is some kind of variable bonus but it isn't at all random, strictly linear.
    The machine has no credit recording method that I can see in any other form. The only counter in the game is the coin counter, which currently doesn't work too.
    #35 2 years ago
    Quoted from Toyguy:
    The 100-900 lights are probably for 100,000 to 900,000. The 100 would light after 99,999 etc.
    #36 2 years ago
    Quoted from Toyguy:
    I got to wondering if it's not some form of credit counter disguised to not look like one. If you discarded two zeros, you'd end up with a range 0-79 ..
    That would be it. There's a button-like thing under the cabinet that you push to zero the credit counter.
    #37 2 years ago
    Quoted from DennisDodel:
    That would almost make sense except for the duplicated 1000-7000 lights at the bottom where the 100-900 are. There are 1,000 to 9,000 and 10,000 to 70,000 dedicated lights at the top of the backglass.
    Since it isn't quite working yet, I can't tell if anything actually scores by 100 but the instruction card doesn't mention it and all the playfield markings are in thousands.
    #38 2 years ago
    Quoted from balzofsteel:
    Cool - I forgot all about that button. I can actually test it that way and see if those digits in the green area count down as I run off credits.
    #39 2 years ago
    Almost everything scores 100 except for the stuff that scores 1000 when lit.
    Added over 3 years ago: oops.
    #40 2 years ago
    If it has no regular credit unit, I imagine it would make no sense to have a match feature, since it can't award free games to anything. If it has a knockoff button, then you are probably on to the solution.
    4 weeks later
    #41 2 years ago
    I finally made some good progress on the Argentine flipperless earlier this week. The playfield's been stripped, cleaned up and some of the bumpers have been replaced. I'm not really liking the white bumper bodies though. I may have to try dying some with RIT.
    Also got my new supply of bulbs and have swapped them all out while I have the backglass out for touchup work. Lotta bulbs on this gal...
    1 month later
    #42 2 years ago
    Been a while since I posted on this one, but I've been slowly plugging away at it. I really couldn't stomach the white bumpers, so I have taken to painting them. There's no GI at all on the playfield so it won't be missing any light from the opaque paint and the caps will still illuminate as they are supposed to. There's simply no source of colored dead bumper bodies that I could find, so this will do until I can hopefully scrounge some by buying up some old playfields from the 1940s. The ball never seems to touch the body at all, hitting the skirt and rubber first so I am hopeful they'll hold up. The only worry is the purple skirts, since the ball will have to contact those. With no source of that shade of purple available I had no option but to paint them. I tried RIT but it didn't work well on the bodies at all. I had to cut the spikes off the new bumper skirts and drill them for the wire contacts used on these old-timers.
    A local collector helped me out with replacement diamond posts, so I now have enough. At the top of the photo you can see the two Shapeways 3D printed parts. I'll keep those as spares. I'm only replacing them since they don't have the marbling of the old parts. I need to paint a couple more bumpers and either paint or scrounge 4 purple posts. The corrosion on the lane guides was treated and they were then reinstalled.
    The last item on the playfield will be the side rubber. I have black half-round on hand but I think I may try slicing some white rubber rings in half as the black looks terrible.
    Anyway, almost ready for some playtesting after a couple of tweaks to the backbox mechanism board.
    #43 2 years ago
    With the playfield now done and back in the game, the lack of schematics for these old timers is starting to hurt. I've got a number of issues to work out now and it sure would be nice to know what drives what.
    The list of problems in no particular order:
    1. The Lock relay pulls in when the coin slide bar is activated, but does not lock. It will lock if I subsequently close the armature plate by hand so something is releasing power to it during the game start sequence.
    2. If the playfield is down in playing position, there's no solenoid power and the Lock relay will trip off. With the playfield up in service position, it works fine and solenoid power remains on. I suspect either a Tilt flaw or the trip bank actuator arm is applying some gravity pressure to one of the relays.
    3. The "A" rollover light doesn't work.
    4. Game logic is suspect but I'm not really sure what the rules are yet anyway so this is low priority.
    5. Some of the bumper lights aren't being triggered.
    Next up, I think, is just toggling relays by hand to see what they do. Might even have to go to toggling individual switches. The wiring harness is stapled in with these big industrial strength staples and I'm not inclined to unwind it but it may come to that.
    #44 2 years ago
    Little bit of progress so far today. I've identified 6 of the trip bank relays but have 6 more to go. I've also resolved the issue with the Lock Relay. A lot of the startup sequence is driven by the position of various bits of metal on the slide bar. I was able to identify which one pulled the relay in and which cut the power and adjust those so they were activated in the right order.
    Now it's looking like my score unit is bound up again so that mech board will have to come out again. Can't do any more testing until I get a look at that. Seems odd it's all bound up again but we'll see.
    #45 2 years ago
    Figured out the score unit stepper issue - hard to believe I missed it the first time around :0
    The gear wheel had apparently broken before and one of the spokes had been poorly welded. The weld is holding but the gear wheel was clearly warped from the heat. I got it onto a flat piece of steel and hammered it flat, hoping it wasn't going to break. It didn't, and now it's moving freely. I also found another broken wire on one of the rivet head pins that contact the scoring disc and noticed the rivets and pins were slightly out of alignment. Threw it back in and things are looking much better. Still some bugs though...
    Started touching up the backglass for now, unit I can get a digital scan made and do some photoshopping before making a translite. Since most of the glass is unlit except the scores and such, I think a translite will be fine. Not like anyone is going to re-screen one of these anyway.
    #46 2 years ago
    Finally got to play this old gal. Identified a few minor issues and there's still a good deal of uncertainty on what's supposed to trigger what but in general it's looking pretty good. I have a few bumper lights that never come on and the red triangle is supposed to light though I am not sure exactly how. It hasn't so far yet so it may bear some investigation but could be normal. I have a couple playfield switches not working when the ball hits them, though they work by hand so I'm sure that's just an adjustment.
    I still haven't figured out what lights the hidden values in that green bar at the bottom of the backglass, though some have appeared at times. They seem rather intermittent too, so some new sockets may be needed there. The purple bumpers do not score currently, but they do rotate playfield and backglass lights so I'm not at all sure they are supposed to score. I'll have to investigate that further.
    Some of the bumpers are sluggish to respond so I may have to look into cleaning the carbon rings. I cleaned up the contact wires on the skirts but left the rings alone. That may have been a mistake but it's easy to do.
    All in all, a good night's work and I'm happy to see her all lit up again for the first time in who knows how long.
    #47 2 years ago
    Quoted from Toyguy:
    I enjoy following your in-depth resto!
    I'm not big on electrical unfortunately so I don't follow much. But I love your dedication to bringing a toasted game back to life!
    Also I get a lot of amusement that it says "Genco MFG Co. NOT INC." Must have had a near identical competitor aha!
    #48 2 years ago
    Final cosmetic work on the playfield is done. Using my heat gun, I was able to flatten and somewhat re-shape the original bumper caps, with the exception of one of the purples. If you look closely at the full-size image, you can make out the melted top edge on the third one from the left. Hopefully I can find one someday. At least it's a blank!
    I also changed out the 2 Shapeways 3D printed diamond posts for 2 originals from my local friend, so now I have the Shapeways parts as spares. At some point, I may go through the bother of slicing some white rubber rings in half to line the sides of the playfield but I'm not terribly worried about it.
    I'm now trying to save the coin door, which was badly damaged when it was pried open, due to the lack of a key I presume. I may just have to make a new one though - the damage is pretty severe. On the plus side, the coin slide lockout coil ohms out at 55 ohms, so I'm thinking it's good. I have one last bit of crumbled AC wiring to replace on the door.
    Operationally, there are only two potential issues. I say potential as I'm not sure what's normal
    So, on a real longshot, has anyone played one of these? I'd like to determine if the 4 purple bumpers are supposed to score or not? Currently they do not but they do cycle features on the playfield so the bumper contact is working. When lit, the appropriate Specials are awarded also. The other bumpers all seem to score 1000 points when hit. It seems odd that the purples don't but I also don't see any obvious wiring or switch issues, and all switches have been cleaned and adjusted.
    The other possible problem is with the credit takeoff system. Currently it just tilts the game but it looks like the coin door wiring may also be involved here so I'm withholding judgement on that one for now.
    The hidden numbers in the green bar at the bottom of the backglass are definitely the number of replays times 100. Earning one replay will lite the 100 light in that green area. Looks like it tops out at 65 replays. I assume having the replays look like scores in the hundreds or thousands may have been some sort of gambling subterfuge, or I guess you could just add the replay score to your score if you were competing in a place where replays weren't paid out.
    #49 2 years ago
    Finally put the glass on her late tonight and calling it done for now. Only one problem remains and that's the credit takeoff function. No big deal. I've decided that it seems like it would be far too easy to earn replays if the 4 purple bumpers scored so whether they should or not, I'm deciding that they don't. It takes good plunging and nudging skills now to make any replays and I like it just fine.
    Here's a shot from earlier tonight, falling 1,000 points short of the first replay target.
    After putting the glass on, I played a few games and managed a 44,000, earning 3 replays. Yes!!
    #50 2 years ago
    Nicely done! Looks good, and sounds like it's playing well. ENJOY!
    $ 27.99
    Lee's Parts
    € 339.00
    Displays
    GermanGamingSupplies.com
    $ 999.00
    $ 9,000.00
    Operation Pinball
    Yorktown Parts and Equip
    $ 17.99
    $ 24.95
    The MOD Couple
    $ 123.00
    $ 48.00
    £ 89.00
    PinballToys
    € 197.00
    Displays
    PINBALLSP
    $ 29.99
    € 9.95
    Multigame
    $ 299.00
    $ 54.00
    $ 1,000.00
    Playfields
    Pinball Playfields
    $ 89.95
    $ 26.50
    The MOD Couple
    $ 109.99
    PinballBulbs
    $ 1,000.00
    Playfields
    Pinball Playfields
    Lighting - Backbox
    $ 39.00
