I have been woodworking for the last 30 years or so. Over the years, I've created a few gizmos are are IMHO pretty cool.
Let's see what you got too.
Here's the first item... The Bench!
I designed/built this myself. A back-splash keeps items rolling off the back. Two layers of MDF for flatness and also, replaceable. I can unscrew a layer and put on a new one easily if it gets damaged. Heavy duty to stay put, but there's wheels on the back. To move, I have a hinge mounted on the front of the bench. The board laying in the front has the mating hinge with a while at the fulcrum. I leave it detached under the bench most of the time. But, if I need to move the bench, I just put the hinge pin in and push down on the board. I can easily wheel it about (to find screws ), sweep or whatever. There's three wheels in the back: solid steel with 3/4" shaft. I believe they are rated at 600lbs each....
Under the front you can barely see kickplates (pull outs from my employers old computer room). They are just wedged in there, but it keeps anything from shooting under there if I drop something. I pulled the center out to demo the lift.
There's also an overhead fluorescent and two swing arm lamps built into the table. The white one up front has a magnifying lens attached because ... I need it
The general vice on the corner I have is a beast I picked up at a garage sale for $5.
More to come.
faz
