New! Dark mode!
(Topic ID: 195271)
Woodrail Play field Glass Removal
By SteveinTexas
  • 12 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by SteveinTexas
    #1 3 years ago
    I have a 1958 Williams Short stop I am restoring, the observation is the glass does not slide out the front as my other Williams games before and after this game.
    The front of the game is about 3/32" higher than the side rails. The cabinet front and body have the same serial # so the parts are from the same game. The wooden side rails have screws that make them removable but I can't tell if they were added later or original.
    Did some games have a removable side rail to get the glass out as this correct for this game?
    #2 3 years ago
    On my 1959 Golden Bells the wooden lockdown bar is unscrewed from the underside wing nuts and then lifted off. After that, the glass slides out fairly easily.
    #3 3 years ago
    I've never owned this title but it should slide out the front? I would think anyway? Every P&B and pinball game I've owned except Bally Dixieland has slid out the front.
    #4 3 years ago
    I,as well as a friend of mine,have this game and the glass slides out the front on both of them.
    #5 3 years ago
    Quoted from novaguy:
    That is very good to know. If I may ask is your game the same as I describe or is the front panel top flush with the adjacent side rails?
    The fix is straightforward. I have already used my router to deepen the front panel bottom board slot. This allows the front panel to sit lower and flush with the top . The bolt holes will need a slight mod with a drill bit but otherwise we are all good.
    #6 3 years ago
    Quoted from AlexF:
    That Star Slugger slides out the back. Pia. Great game though
    #7 3 years ago
    Really? So you have to take the head off every time you want to get in there. That is a pia. Still, having a Star Slugger seems worth the trouble.
    #8 3 years ago
    Quoted from AlexF:
    I have had a few games where the glass (and playfield) slide out the back. Keeney Birdland is one of them. The head does not have to be removed. Still a pia as you have to pull the game out from a wall.
    The board with the two wing nuts is removed to pull out the playfield and glass.
    http://mirror2.ipdb.org/images/5747/image-27.jpg
    #9 3 years ago
    Quoted from DennisDodel:
    I have had a few games where the glass slides out the back. Keeney Birdland is one of them. The head does not have to be removed. Still a pia as you have to pull the game out from a wall.
    Had to look that one up. And your game is on IPDB. Very interesting.
    #10 3 years ago
    Quoted from AlexF:
    I don't have to take the head off. But I do have to pull the game out about five feet. Then lift the coffin lid all the way up. Remove a trim piece, and it slides vertically out the back. And that's why my pf needs cleaning bad!
    #11 3 years ago
    Sorry for the late reply Steve.I forgot to mention that my boss also has the same game and the glass slides out as it should just like it would on a pin.and yes the front panel is flush.if you have any other questions feel free.
    Ted
    #12 3 years ago
    Ted
    Thanks for the update. I need to repaint so I visited with the gals that mix the auto paints this afternoon. They enjoy the pinball talk as a change to cars. Color shades all agreed and final clear sheen. They will get the colors spot on ( not that one would really ever know) and it should be a fine restore.
    $ 9.95
    $ 195.00
    WOZ - OZ lanes Out of stock
    The Art of Pinball
    $ 160.00
    PinWorlds
    Lighting - Backbox
    $ 9.00
    Cabinet Parts
    Third Coast Pinball
    Great American Pinball
    $ 179.00
    $ 6.00
    $ 40.00
    G-Money Mods
    $ 299.00
    The MOD Couple
    $ 44.00
    $ 175.00
    Professor Pinball
    $ 29.00
    Bent Mods
    $ 19.95
    $ 40.00
    $ 18.00
    Pin Monk
    $ 80.00
    Back Alley Creations
    Filament Printing
    $ 42.00
    The MOD Couple
    $ 39.95
    $ 48.00
    $ 139.00
    Sparky Pinball
