New! Dark mode!
(Topic ID: 267215)
Wonka shooter rod problem help!
By jeffgoldstein2
5 months ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 5 months ago by jeffgoldstein2
#1 5 months ago
My shooter rod is making contact with the auto plunger everytime you pull it back. I can’t figure out how to either lower the rod slightly or raise the auto plunger. Is this a common issue? I’ve never come across this and I can’t figure this out. Any help on adjustments would be much appreciated. Thanks!
#2 5 months ago
Quoted from jeffgoldstein2:
Loosen the three screws inside cabinet on back side of shooter plate. That should allow plenty of adjustment move then tighten when aligned. Good luck.
#3 5 months ago
Quoted from Yelobird:
I will try that, thanks!
$ 7,500.00
$ 23.25
The MOD Couple
$ 99.00
Pinball Sales
$ 38.00
The MOD Couple
