This is a little tread for the Stern TMNT Channel 6 building and the Pizza Shop mods that I am making.
The Channel 6 building will fit all levels of machine trims, the Pizza Shop however is ONLY for the PRO version.
The channel 6 building mod replaces some of the factory plastic on the right side of the playfield adjacent to the shooter lane. The owner of the machine does not have to make any physical modifications and can always revert back to stock easily. Some plastics need to be removed and some of the hardware is reused.
The existing flasher that is located in the removed red dome is either installed inside of the Channel 6 building and will let the blue windows slightly flash when it goes off OR the user can relocated the flasher LED and use the new provided LED mount and relocate it to the front of the building. When the flasher is mounted outside and in front of the building you get a much better effect as it lights up the front of the building and draws your eye to it when the spinner is hit.
I have only 20 units made at this time and not sure if or when I might do more. Asking $75 each. Shipping to the US or Canada is $12 usd. I can and have shipped all over the globe so don’t be afraid to ask.
