Quoted from ForceFlow:You want to loosen the screws to extend them out, rather than tighten them.
Extending them out pushes them against the lockbar, which should help stabilize it.
Sorry, but this isn't correct.
The screws are to adjust the receiver bar which locks to the tabs on the lock bar. The end of the brass screws push down the receiver. Check the photo attached.
Tightening the screws (clockwise) pushes down the receiver, making the lock lever harder to move but pulls down the lock bar tighter against the glass and cabinet trim.
Loosening the screws (counterclockwise) loosens the receiver, making the lock lever easier to move but doesn't pull down so hard against the glass and cabinet.
Sometimes you need to muck around for ages to get it right.
rd
