Hi everybody! I have a question for you.
I'm trying to repair a sys7 mpu with the above errore code. This "8" is driving me Crazy..
Comparing signals with a working (with working I mean "zero" than go off as per manual), they are the same! Error code could be a bad CMOS or a bad memory protect circuit. Since the signals of ICs of mem circuit are ok, I try ti change several 5101 but nothing better happens. The eight Is always in front of me. With Leon, the test passed so.. where is the problem?!
In fact, with board installed, I cannot change audits from the coin door, so I think the problem Is correct.. something is protecting the values on the memory..
The mem protect circuit is composed by two ICs: a 4071 and 7408.
Thanks in advance for helping me!
