yup, i'm well aware of the relationship between impedance (not resistance in the case of speakers, speakers are not a purely resistive load, with the exception of electrostats) and current... it would be interesting to see (purely from an academic standpoint) what the impedance curve of the speakers is... i suppose i could measure it, but i don't care that much... but yes, adding resistance before it hits the speaker will do what you are saying, and would be a workaround...
everyone skip the following if you don't care about speaker/audio theory...
the temptation to digress on this topic is strong, but i will resist digressing much, and will leave out the gory details... but keep in mind that a "nominal 6 ohm speaker" is simply that, nominal... the actual impedance curve will tell you more than the nominal rating... combine that with phase angles, and it will tell you whether a speaker is "friendly" or not... take that in conjunction with the efficiency of the speaker (how much spl for a given "power" input), and you can make a judgment on what your amplifier (really, the power supply of the amplifier, the "amplifier" itself really doesn't care) will drive... there are 8 ohm nominal speakers that are far harder to drive than 4 ohm nominal speakers (note: below 4 ohms isn't a dead short)...
also keep in mind that what many refer to as "bass", especially in a pin, is really "mid-bass"... and that bass (as well as lower mid-bass) is a function of your room... you can take the baddest ass subwoofer in the world (i have a relatively badass one in my room, a seaton submersive, that produces "flat" reference level bass to 16hz at my listening position, and usable bass below that) and stick it in a bad room/bad location and it doesn't matter how much power you feed it, you won't get "good bass"... as an example, in a 2000 cubic foot room, frequency reproduction below 120hz is a function of room modes... put a sub in a bad spot (or similarly, sit in a bad spot or have a bad room) and it won't matter how much air a sub is pushing, you won't hear anything... as a side note, this is one reason why putting a subwoofer in a pin is a bit of a fool's errand (the other being that a pin cabinet is nowhere near inert or sealed enough to properly "woof", let alone properly sized)... you may get a boom or two, but you won't get "good bass"...
also keep in mind that low frequencies are what really take a lot of "power" to produce... and you aren't gonna produce much of those low frequencies with a 8/10" driver, no matter how hard you try, it is physically impossible... even a 12" driver will struggle to produce "usable" bass... and because of the way we "hear" (see: fletcher/munson curves) you need to produce a BOATLOAD of bass in order for it to be usable...
also keep in mind that you rarely, if ever, will use more than 1 watt, with the exception of subwoofage...
ok, i digressed a bit more than planned (although as promised, i did leave out the gory details ).. the upshot is that a "nominal" rating doesn't tell you a whole lot, and that bass is trickier than it appears on the surface...
don't get me started on the concept of getting "stereo" and/or "good" sound out of a pair of speakers that are essentially co-located with a big huge reflective surface between them and you (not to mention other factors)...
