Hi everybody! I'm facing another sys 6 cpu with another trouble
It was installed on a Time Warp, some acid around battery pack, completely blocked.
So I started with the usual first steps: remove all the damaged components, clean the tracks and stopped the oxide with water/vinegar solution. Once replaced the ICs it's time to perform the test: with both test roms (Leon and Andre Boot) the board is ok, also the rams and roms are ok, but... once in the pin, the game is freeze: no controlled lights on the playfield, all the display shown zeroes, and I cannot use the diagnostic button on the coindoor.
At the bench I noticed that with the multimeter setted to "check continuity" the pin 20-21-22 of IC19 has continuity when the battery are installed. Of course I've done all the test without battery, new 5101, check tracks... but the game still freezy as described above: no lights and display blocked with all zeroes.
Some suggestions about where to check and act?
Thanks as always!
