The late great Leon Borre posted a mod that can be found on PinWiki to use a single 2764 EPROM. It gets lost in translation a bit so i thought I would try and simplify the instructions.
This mod lets you use a single 2764 ROM in sys 3-4 MPUs. This includes FirePower on a single ROM.
To assemble the 8KB binary file for the 2764 EPROM you need the game ROM to be in the first 4KB half of the binary and the two flipper ROMs in the last half(flipper 1 then flipper 2) of the binary. For 2KB games(everything but firepower) double up the GAMEROM. For FirePower, use the FPCOMBO 4KB image found on planetary pinball.
So command prompt for combining the ROM binaries is going to look like this.
FirePower
copy /b fpcombo.732 + green1.716 + green2.716 fpcombo.764
All other games (timewarp example)
copy /b timewarp.716 + timewarp.716 + green1.716 + green2.716 timewarpcombo.764
To prep the board start with desoldering IC15.
Remove all ROMs.
Stack a 24 pin leaf socket on top of IC17(you may skip this step depending on socket styles). Stack another 28 pin leaf socket on top of IC17 again so pins 1,2, 27 and 28 are the extra ones hanging out of the 24 pin socket below. Also bend out pin 22 and pin 23 of the 28 pin socket so can have a lead soldered to them.
On the new IC17 28 pin socket, solder pins 1, 27, and 28 to +5v. I used the nearby bypass cap.
IC17(28pin) Pin 2 goes to IC15 Pin 13
IC17(28pin) Pin 22 goes to IC15 Pin 12
IC17(28pin) Pin 23 goes to IC15 Pin 14
I used a prototyping board and some socket headers to plug into a socket at IC15. That way the mod would be easily reversible. The leads could also be hard soldered in at IC15
All credit goes to Leon. Here is the link to his info.
