I have this board from a pinbot on the bench with GND, 5V and 12V. I've burned a Leon test rom for it and have it installed at U26.
I have all the PIAs pulled at this point except U38 (not socketed).
There is some previous rework U16, U28, U39, U43 (555), U55 all socketed. Work looks decent (although nasty flux remains). I have pulled and tested these chips with a little chip tester. The socket at U20 looks factory and the 7408 tests fine.
The 7 segment LED does not light at all. I get a little flash (very dim) out of it when I turn power off. The LED used for Leon's test burns constantly.
Blanking stays low, Reset starts low and quickly goes high. The clock signal measured at the processor is 3.99 mhz
The board has had the battery pack removed and while kind of grungy doesn't look battery damaged.
If anybody could give me some hints on what to try next I would appreciate it.
