(Topic ID: 306976)
WMS Jungle Lord issue/s
By Vintage-Pinball
2 years ago
  • 8 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by frunch
#1 2 years ago
My JL was working fine until I turned it on today for some play. It has Rottendog boards in it ( not sound) which I fitted some 8 odd years ago and up until today, absolutelyno issues with them..
This is what its doing: Starts normally, does its speech thing, serves the ball and begins play. However, when any drop target is hit, its silent and doesnt register a score nor do the lower drop targets give a magna-save credit. If the ball goes into either kick-out hole, it doesnt eject the ball. When the ball drains, the targets will reset but the same cycle happens again. All the connections are nice and tight throughout and fuses are good.
Any ideas welcome. Thanks.
#2 2 years ago
Quoted from Vintage-Pinball:
Switch strobes... Broken switch strobe wires...etc. If all continuity is good then,
bad IC to/for the switch strobes on the IO board.
1) logic probe or oscilloscope would help trouble shoot the board input/output logic.
#3 2 years ago
Thanks for replying. Excuse my ignorance, but how, or where, would I find these cables? Are they the ones that live on the bases of the drop targets? I dont own a logic probe/scope but I'll overcome that problem if need be. Thanks again.
#4 2 years ago
1st, do you have the playfield switch matrix chart?
2nd, check in switch test what does and does not work.
3rd, check the IO board. you should have 0 ohm resistors
--- for the switch drives.
#5 2 years ago
I agree with @vec-tor, sounds like a switch matrix issue. First, you'll want to grab a copy of the switch matrix chart, which is in the Jungle Lord instruction manual which can be downloaded from ipdb here: https://www.ipdb.org/files/1338/Williams_1981_Jungle_Lord_Operators_Handbook.pdf
You can find more technical documents, schematics, etc free to download for your game at ipdb.org.
Anytime you discover multiple switches aren't working, you want to see if you can find a pattern on the switch matrix chart. Most commonly, you may discover all the switches in a vertical "column" or a horizontal "row" may stop working. There's a couple common reasons for a column or row of switches to stop working. Often, it can be a broken wire that daisy-chains between the switches, or a broken diode at any of the switches on the faulty row or column. It could also be a connector problem somewhere between the playfield and driver board/MPU. Considering you have an aftermarket mpu, we'll assume that it's ok for now...but there are tests that will help us narrow down the source of the issue.
That said, it sounds like you have at least one vertical "column" out on the switch matrix. Here's the switch matrix chart from the instruction manual I linked above:
Note all the drop targets are on 2 vertical columns, column 4+5. The upper and lower eject holes are also on column 5.
To keep it orderly, let's start with column 4. Looking at the top of the chart, you'll see the wire color codes for each column of switches. Looking at column 4, green/yellow is the wire color that you should find on one side of each of the 8 switches listed on that column. The chart also tells us where that daisy-chained green/yellow wire comes from: 2J2-6 (Plug J2, pin 6 on the driver board -- the lower-left board in the backbox).
So, to put this info all together: a green/yellow wire originating from pin 6 of connector J2 of the driver board runs down to the playfield at one of those 8 switches and attaches to one of the switches solder lugs. Another green/yellow wire runs from that same solder lug over to the next switch in the same column, and again and again until all 8 switches are sharing the green/yellow circuit (that's called a "daisy chain"). If you set your meter for continuity/beep test, you should find you have continuity between the green/yellow solder lugs on all the switches, and between the green-yellow lug from all the switches up to the green/yellow wire at the wiring connector 2J2 pin 6. If you don't get continuity between all them, you probably have a broken wire somewhere at one of the 8 switches on that column. In this case, the switches for column 4 include: all 6 lower drop targets, the right kicker/slingshot scoring switch (does the game score 10 points when the right kicker/slingshot above the lower right flipper activates?), and the rollover up at the top left of the upper playfield. The instruction book also shows the locations of each of the switches, it's very helpful since the switches aren't always easy to locate.
Again--you'll note most of the switches have 2 wires--a green/yellow wire coming from the previous switch, and a green/yellow wire headed for the next switch (the daisy-chain). There will only be one green/yellow wire at the end of the daisy-chain. You may find 1 or 2 wires broke off at a switch, and just needs to be reattached. While hunting for a broken wire at any of those switches, you also want to check the diode on each switch. If either leg of the diode on any switch should break off, it can also cause problems for multiple switches on the same row or column. A gentle tug on both legs will reveal if they're broken/loose.
One last thing important thing to note: the daisy-chain of switches at the drop targets may look a little different. Instead of finding a green/yellow wire at each of the column 4 drop target switches, you may see one green/yellow wire at one of the switches and a couple single-color wires used to carry the green/yellow circuit over to the other adjacent switches. On my Black Knight, thin yellow wires were used to carry the daisy chain to the other drop target switches. If you find one or more of those yellow wires broken, you probably found your culprit. Take pics if you find anything questionable and we'll help figure it out. As far as column 5, you can refer to the switch matrix chart for wire colors, which switches to check, etc. Same procedure as you did for column 4, just different wire colors going to different switches.
I hope this wasn't too much info --feel free to ask if you need any further clarifications.
#6 2 years ago
Wow, thank you both for the help! Now I know where to start looking. I'll let you know how I get on. Fingers crossed that I can resolve it easily enough.
#7 2 years ago
It's fixed! I found the yellow daisy chained wires had a break in it. Soldered it one and Bingo. "You, Jungle Lord"
#8 2 years ago
Excellent!!!! Good work!
$ 12.50
RoyGBev Pinball
$ 44.99
Pinball Shark
$ 65.00
Tools
Pincoder Store
1,600 (OBO)
Langhorne, PA
$ 42.95
2,500
Marietta, GA
$ 36.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/wms-jungle-lord-issue-s and we tried optimising it for printing. Some page elements may have been deliberately hidden.
